Performance issues and cpu having strange behaviour after dualbooting
Hello Garuda users.
root=UUID=5bba9487-ae20-4ab6-9163-01e896351984 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Desktop System: HP product: OMEN by HP Obelisk Desktop 875-0xxx v: N/A
Mobo: HP model: 84FD v: 00 serial: <superuser required> UEFI: AMI v: F.26
date: 05/28/2020
Info: model: Intel Core i7-9700F bits: 64 type: MCP arch: Coffee Lake
model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xFA
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 2 MiB desc: 8x256 KiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 900 min/max: 800/4700 scaling: driver: intel_pstate
governor: powersave cores: 1: 900 2: 900 3: 900 4: 900 5: 900 6: 900 7: 900
8: 900 bogomips: 48000
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: Hewlett-Packard
driver: nvidia v: 545.29.02 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2023-10; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f82 class-ID: 0300
Device-2: Microdia JOYACCESS JA-Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-8:6
chip-ID: 0c45:89a0 class-ID: 0102 serial: <filter>
alternate: fbdev,nouveau,nv,vesa gpu: nvidia display-ID: 0
Monitor-1: Unknown-1 res: 1920x1080 size: N/A modes: N/A
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia wayland:
drv: swrast x11: drv: swrast inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: llvmpipe (LLVM 16.0.6 256 bits)
device-ID: ffffffff:ffffffff memory: 15.13 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 1 device: 0 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: nvidia v: 545.29.02
device-ID: 10de:1f82 surfaces: xcb,xlib
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10fa
Device-3: Kingston HyperX 7.1 Audio
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 0951:16a4 class-ID: 0300
Device-4: Microdia JOYACCESS JA-Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.6.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
lanes: 1 port: 4000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:7 chip-ID: 0bda:b00b
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 4.2
lmp-v: 8 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.14 TiB used: 8.97 GiB (0.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: ADHA0102 temp: 58.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA100
tech: HDD rpm: 7200 serial: <filter> fw-rev: A8L0 scheme: GPT
ID-1: / raw-size: 79.7 GiB size: 79.7 GiB (100.00%) used: 8.89 GiB (11.1%)
used: 84.3 MiB (32.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 79.7 GiB size: 79.7 GiB (100.00%)
used: 8.89 GiB (11.1%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 79.7 GiB size: 79.7 GiB (100.00%)
ID-5: /var/tmp raw-size: 79.7 GiB size: 79.7 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 73.0 C pch: 51.0 C mobo: N/A
Processes: 252 Uptime: 10m wakeups: 0 Memory: total: 16 GiB
available: 15.5 GiB used: 2.88 GiB (18.6%) Init: systemd v: 254
pm: pacman pkgs: 1222 libs: 346 tools: octopi,paru Shell: fish v: 3.6.1
Garuda (2.6.19-2):
System install date:     2023-11-15
Last full system update: 2023-11-15
Yesterday I was trying to dual boot garuda linux alongside windows that I’ve been using for about 3/4 years. I’ve never had performance issues while using windows OS but somehow since I installed garuda in my PC it is having many performance issues, fps are low, mouse stutters (it only happens when using garuda). I realized my CPU usage was very inconsistent and sometimes it jumps to around 80% of usage just by being in the desktop with nothing running. I first thought it was because I used a HDD (120 Gb) partition but then I changed to SSD (80 Gb) because some people were having the same issue with HDD, but the problem remains.
I’ve tried uninstalling the OS and reinstalling some times but nothing changed. I also noticed this issue doesn’t happen while using the flash drive. Aside from this my hz are stuck at 60 in the display settings and I cannot change to 165 (my monitor max).
I really enjoy using this OS (I’ve used it on my laptop for a while and never had issues with it), so I would really like to solve this problem. Any help would be appreciated, thanks for reading.
Try this (x11 session or kernel boot parameter in Wayland):
Different symptoms but possibly same root cause.
Most likely related:
Thanks, I don’t really understand how but this solved it! Even the issue related to the monitor.
It’s due to the use of Nvidia drivers in Wayland.
Quite recurring lately.
