Hello, I have linux kernel installed, my touchpad is working very bugged like sometimes on a small move it will go to the other end of the screen etc, and my optical usb mouse does light up but doesnt work, i restarted with them connected and it worked for a split sec but doesnt work now.
Edit - lsusb doesnt catch it
Post inxi -Fxxxza
System: Kernel: 5.12.5-arch1-1 x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux root=UUID=f32cff9d-4ac7-4fa6-99a3-336fbee054b7 rw rootflags=subvol=@
quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0 systemd.unified_cgroup_hierarchy=1 loglevel=3
Desktop: KDE Plasma 5.21.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: LENOVO product: 80TJ v: Lenovo ideapad 110-15ACL serial: <filter> Chassis: type: 10
Mobo: LENOVO model: Nano 5A8 v: SDK0J40679 WIN serial: <filter> UEFI: Lenovo v: 1QCN32WW date: 08/18/2016
Battery: ID-1: BATT charge: 2.6 Wh (55.3%) condition: 4.7/23.8 Wh (19.9%) volts: 11.8 min: 10.8 model: LENOVO LCFC
type: Unknown serial: <filter> status: Charging
CPU: Info: Quad Core model: AMD A8-7410 APU with AMD Radeon R5 Graphics bits: 64 type: MCP arch: Puma family: 16 (22)
model-id: 30 (48) stepping: 1 microcode: 7030105 cache: L2: 2 MiB
flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 17573
Speed: 2067 MHz min/max: 1000/2200 MHz boost: disabled Core speeds (MHz): 1: 2067 2: 2055 3: 2127 4: 2041
Type: spectre_v2 mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
Graphics: Device-1: Advanced Micro Devices [AMD/ATI] Mullins [Radeon R4/R5 Graphics] vendor: Lenovo driver: radeon v: kernel
alternate: amdgpu bus-ID: 00:01.0 chip-ID: 1002:9851 class-ID: 0300
Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 / Radeon 520 Mobile] vendor: Lenovo
driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0 chip-ID: 1002:6660 class-ID: 0380
Device-3: IMC Networks EasyCamera type: USB driver: uvcvideo bus-ID: 2-1.2:4 chip-ID: 13d3:a745 class-ID: 0e02
Display: x11 server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: ati,radeon unloaded: modesetting
Monitor-1: eDP res: 1366x768 hz: 60 dpi: 101 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: AMD KABINI (DRM 2.50.0 5.12.5-arch1-1 LLVM 11.1.0) v: 4.5 Mesa 21.1.0 direct render: Yes
Audio: Device-1: Advanced Micro Devices [AMD/ATI] Kabini HDMI/DP Audio vendor: Lenovo driver: snd_hda_intel v: kernel
bus-ID: 00:01.1 chip-ID: 1002:9840 class-ID: 0403
Device-2: Advanced Micro Devices [AMD] FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:14.2
chip-ID: 1022:780d class-ID: 0403
Sound Server-1: ALSA v: k5.12.5-arch1-1 running: yes
Sound Server-4: PipeWire v: 0.3.28 running: yes
Network: Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: Lenovo driver: ath10k_pci v: kernel
port: 2000 bus-ID: 02:00.0 chip-ID: 168c:0042 class-ID: 0280
Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Lenovo driver: r8169 v: kernel port: 1000
bus-ID: 03:00.0 chip-ID: 10ec:8136 class-ID: 0200
Bluetooth: Device-1: Qualcomm Atheros type: USB driver: btusb v: 0.8 bus-ID: 2-1.1:3 chip-ID: 0cf3:e360 class-ID: e001
Drives: Local Storage: total: 223.58 GiB used: 23.99 GiB (10.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDS240G2G0A-00JH30 size: 223.58 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 0000 scheme: GPT
Partition: ID-1: / raw-size: 30.64 GiB size: 30.64 GiB (100.00%) used: 23.95 GiB (78.2%) fs: btrfs dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 512 MiB size: 511 MiB (99.80%) used: 37.4 MiB (7.3%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 30.64 GiB size: 30.64 GiB (100.00%) used: 23.95 GiB (78.2%) fs: btrfs dev: /dev/sda5
maj-min: 8:5
ID-4: /var/log raw-size: 30.64 GiB size: 30.64 GiB (100.00%) used: 23.95 GiB (78.2%) fs: btrfs dev: /dev/sda5
maj-min: 8:5
ID-5: /var/tmp raw-size: 30.64 GiB size: 30.64 GiB (100.00%) used: 23.95 GiB (78.2%) fs: btrfs dev: /dev/sda5
maj-min: 8:5
ID-1: swap-1 type: zram size: 1.67 GiB used: 4.5 MiB (0.3%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 1.67 GiB used: 4.7 MiB (0.3%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 1.67 GiB used: 4.7 MiB (0.3%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 1.67 GiB used: 4.6 MiB (0.3%) priority: 32767 dev: /dev/zram3
Sensors: System Temperatures: cpu: 72.0 C mobo: N/A
GPU: device: radeon temp: 57.0 C device: radeon temp: 75.0 C
Info: Processes: 250 Uptime: 1h 47m wakeups: 2 Memory: 6.69 GiB used: 3.77 GiB (56.3%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1520 lib: 431 Shell: fish v: 3.2.2
running-in: konsole inxi: 3.3.04```
Is there a manufacturer's update for that dated 2016 BIOS?
No i dont think so, i checked my laptop has been discontinued even tho its pretty new
Couple of things to try:
- LTS kernel
- Check lenovo section of arch wiki.
- Determine touchpad driver and search
systemctlanddmesgoutputs with it to see what goes wrong.
For the touchpad, I think you’ll need synaptics drivers.
Please check this post:
so it does work like after 15 mins of leaving it connected
Sounds like a your system just needs time to sort itself out. You can check if your cpu usage spikes on connection by keeping htop on when connecting your mouse or using touchpad.
Maybe you could try loading the drivers for your touchpad and mouse in your initramfs.
I found the fix,
Get a new charger seriously it works on unplugging it
A new battery might also be in order.
