Kernel: 6.0.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=62f24ed7-81ec-4c6c-aec8-a039b2cfc0be
rw rootflags=subvol=@ quiet quiet splash rd.udev.log_priority=3 vt.global_cursor_default=0
Desktop: KDE Plasma v: 5.26.2 tk: Qt v: 5.15.7 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: MEDION product: MD35261 v: N/A serial: <superuser required> Chassis:
type: 3 serial: <superuser required>
Mobo: MEDION model: B460H6-EM v: 1.0 serial: <superuser required> UEFI: American Megatrends
v: 460H6W0X.107 date: 11/16/2021
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake gen: core 10 level: v3
note: check built: 2020 process: Intel 14nm family: 6 model-id: 0xA5 (165) stepping: 3
microcode: 0xF0
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4000 high: 4008 min/max: 800/4300 scaling: driver: intel_pstate
governor: powersave cores: 1: 4002 2: 3996 3: 4000 4: 3999 5: 3994 6: 4001 7: 4000 8: 4000
9: 4006 10: 4001 11: 3999 12: 4008 bogomips: 69597
Type: spectre_v2 mitigation: Enhanced IBRS, IBPB: conditional, RSB filling, PBRSB-eIBRS: SW
sequence
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: ZOTAC driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 520.xx+ status: current (as of 2022-10)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2489 class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.5 compositor: kwin_x11 driver: N/A
Screen-1: 0 s-res: 1920x1080 s-dpi: 93 s-size: 524x292mm (20.63x11.50") s-diag: 600mm (23.62")
Monitor-1: DP-4 res: 1920x1080 dpi: 94 size: 521x293mm (20.51x11.54") diag: 598mm (23.53")
modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 520.56.06 renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
direct render: Yes
Device-1: Intel Comet Lake PCH-V cAVS vendor: MEDION AG driver: snd_hda_intel bus-ID: 1-9:4
v: kernel chip-ID: 0d8c:0012 alternate: snd_sof_pci_intel_cnl class-ID: 0300 bus-ID: 00:1f.3
chip-ID: 8086:a3f0 class-ID: 0403
Device-2: NVIDIA GA104 High Definition Audio vendor: ZOTAC driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.1
Device-3: C-Media KLIM PUMA type: USB driver: hid-generic,snd-usb-audio,usbhid
Sound API: ALSA v: k6.0.7-zen1-1-zen running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: MEDION AG driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168
Hardware-1: Intel Device driver: ahci v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:a386 rev:
class-ID: 0104
Local Storage: total: 942.7 GiB used: 61.25 GiB (6.5%)
ID
-1: /dev/sda maj-min: 8:0 vendor: Phison model: S11-512G-SSD-B27 size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: J1.3 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 4B6Q
ID-1: / raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 11.87 GiB (2.5%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 608 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 11.87 GiB (2.5%) fs: btrfs
ID-4: /var/log raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 11.87 GiB (2.5%) fs: btrfs
ID-5: /var/tmp raw-size: 476.64 GiB size: 476.64 GiB (100.00%) used: 11.87 GiB (2.5%) fs: btrfs
ID-1: swap-1 type: zram size: 15.43 GiB used: 72.5 MiB (0.5%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 42.0 C mobo: N/A gpu: nvidia temp: 30 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 36%
Processes: 329 Uptime: 21m wakeups: 0 Memory: 15.43 GiB used: 4.28 GiB (27.8%) Init: systemd
v: 251 default: graphical tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1418
libs: 409 tools: octopi,paru Client: shell wrapper v: 5.1.16-release inxi: 3.3.23
Garuda (2.6.9-1):
System install date: 2022-11-07
Last full system update: 2022-11-07 ↻
Hello,
I'm unable to launch Octopi, even after a reboot and uninstalling/reinstalling Octopi.
I launched it from the Terminal, and it says that :
octopi: symbol lookup error: octopi: undefined symbol: _ZN11QTermWidget20setScrollBarPositionENS_17ScrollBarPo
sitionE
I tried to search what the error was, but I couldn't find anything..
