I hope I’m in the right forum area, if not, please move.
After I updated my system this morning, I later discovered that Octopi could no longer be started.
What have I tried? First I uninstalled Octopi and reinstalled Octopi using the Garuda Setup Assistant, but Octopi still doesn’t want to start. Here is my inxi.
╰─λ garuda-inxi
Kernel: 6.9.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=76d36b6c-d531-4de0-9a2c-d3ea38611f74 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Desktop Mobo: ASUSTeK model: PRIME X370-PRO v: Rev X.0x
UEFI: American Megatrends v: 6203 date: 07/27/2023
Info: model: AMD Ryzen 7 1800X bits: 64 type: MT MCP arch: Zen level: v3
note: check built: 2017-19 process: GF 14nm family: 0x17 (23) model-id: 1
stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2489 high: 3848 min/max: 2200/3850 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3848 2: 2200
3: 3196 4: 2130 5: 2472 6: 2133 7: 2200 8: 2133 9: 3337 10: 2195 11: 3200
12: 2170 13: 2139 14: 2133 15: 2152 16: 2200 bogomips: 123201
Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: ASUSTeK
active: DP-1,DP-2 empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 0b:00.0
chip-ID: 1002:73bf class-ID: 0300
Device-2: Logitech QuickCam Pro 9000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 5-1:2
chip-ID: 046d:0990 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 23.2.7
s-diag: 1055mm (41.54")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,right model: VG248
serial: <filter> built: 2021 res: 1920x1080 dpi: 92 gamma: 1.2
Monitor-2: DP-2 mapped: DisplayPort-1 pos: left model: VG248
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi
navi21 LLVM 17.0.6 DRM 3.57 6.9.1-zen1-1-zen) device-ID: 1002:73bf
memory: 15.62 GiB unified: no
API: Vulkan v: 1.3.279 layers: 9 device: 0 type: discrete-gpu name: AMD
Radeon RX 6900 XT (RADV NAVI21) driver: mesa radv v: 24.0.7-arch1.3
device-ID: 1002:73bf surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.7-arch1.3 (LLVM
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0b:00.1 chip-ID: 1002:ab28
v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0e:00.3
Device-3: Logitech QuickCam Pro 9000 driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.9.1-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 07:00.0
Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 0b05:190e
Local Storage: total: 8.19 TiB used: 2.93 TiB (35.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST31000524AS
tech: HDD rpm: 7200 serial: <filter> fw-rev: JC45 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2UB102
ID-3: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST2000DM008-2UB102
ID-4: /dev/sdd maj-min: 8:48 vendor: Western Digital
model: WD10EZEX-75ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s tech: N/A serial: <filter> fw-rev: 0A80
scheme: MBR
ID-5: /dev/sde maj-min: 8:64 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-6: /dev/sdf maj-min: 8:80 vendor: Seagate model: ST2000DM001-1CH164
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC27 scheme: MBR
used: 756.52 GiB (81.2%) fs: btrfs dev: /dev/sde2 maj-min: 8:66
used: 584 KiB (0.2%) fs: vfat dev: /dev/sde1 maj-min: 8:65
System Temperatures: cpu: 34.5 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 44.0 C
Memory: total: 32 GiB available: 31.25 GiB used: 5.51 GiB (17.6%)
Processes: 475 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: 2008 pm: pacman pkgs: 1944 libs: 528 tools: gnome-software,
octopi, pamac, paru pm: flatpak pkgs: 64 Compilers: clang: 17.0.6
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-05-17
Last full system update: 2024-05-18 ↻
Since yesterday Skype couldn’t access the KDE Wallet password storage to log in, I was able to fix the problem by uninstalling SKype and installing it via Octopi’s AUR, then it worked, luckily I did this morning at 00:025 did.
Ther can see what an important tool Octopi is.
Wouldn’t have worked after that.
