Hey Folks!
I have an NVIDIA issue…probably.
I try to be good about updating every time I start my PC.
Come home from work yesterday to only one of my monitors
displaying anything.
First thought: Check to make sure our drivers are running.
Sure enough, output of nvidia-smi is:
NVIDIA-SMI has failed because it couldn't communicate with the NVIDIA driver. Make sure that the latest NVIDIA driver is installed and running.
That’s weird, but not unduely so.
Go check my NVIDIA packages with pacman -Qs nvidia and see:
local/egl-gbm 1.1.2-1
The GBM EGL external platform library
local/garuda-nvidia-config 2:1.1.6-1.1
Meta configuration package for nvidia systems on Garuda Linux
local/gwe 0.15.9-1.1
A system utility for controlling NVIDIA GPUs
local/lib32-libvdpau 1.5-3
Nvidia VDPAU library
local/lib32-nvidia-utils-tkg 565.77-263
NVIDIA driver utilities and libraries for 'nvidia-tkg' (32-bit)
local/lib32-opencl-nvidia-tkg 565.77-263
NVIDIA's OpenCL implemention for 'lib32-nvidia-utils-tkg'
local/libvdpau 1.5-3
local/libxnvctrl 570.86.16-1
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 570.86.16.2-1
NVIDIA pci id list for MHWD
local/mhwd-nvidia-390xx 390.143-1
mhwd-nvidia-390xx PCI ID database
local/mhwd-nvidia-470xx 470.94-1
mhwd-nvidia-470xx PCI ID database
local/nvidia-dkms-tkg 565.77-263
NVIDIA kernel module sources (DKMS)
local/nvidia-egl-wayland-tkg 565.77-263
NVIDIA EGL Wayland library (libnvidia-egl-wayland.so.1.1.17) for 'nvidia-utils-tkg'
local/nvidia-settings-tkg 565.77-263
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils-tkg 565.77-263
local/opencl-nvidia-tkg 565.77-263
NVIDIA's OpenCL implemention for 'nvidia-utils-tkg'
local/xf86-video-nouveau 1.0.18-1 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
Now, I don’t exactly know what I’m looking at here.
But it looks to me like the drivers are installed correctly.
To double check, I go to Hardware Configuration in Garuda Settings Manager. Everything looks in order, but clearly isn’t so I reinstalled video-nvidia-dkmsvia the provided context menu in the GUI, then Reboot. No success there.
I then consulted the Forum, thinking perhaps someone recently had the same issue as I did. I found these posts:
Neither of which provided much in the ways of solutions to my problem although I did read through them and attempt installing linux-znver4-headers to see if that might fix the problem (as you can likely guess it has not).
I am, regrettably, at the end of my ability to solve this problem alone.
It is potentially (and I suspect likely) a simple oversight I have made
due to my comparative new-ness.
I beseech thee, oh wizards of Unix, what have I done wrong?
garuda-inxi as required by the rules:
Kernel: 6.13.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=bd08a06f-ec73-45e5-82d9-09344bfdd6f6 rw rootflags=subvol=@
Type: Desktop System: Micro-Star product: MS-7B86 v: 5.0
Mobo: Micro-Star model: B550 GAMING GEN3 (MS-7B86) v: 5.0
Megatrends LLC. v: P.91 date: 08/29/2024
Info: model: AMD Ryzen 7 5700X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 3
desc: 8x512 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3595 min/max: 550/4149 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 3595 2: 3595 3: 3595
4: 3595 5: 3595 6: 3595 7: 3595 8: 3595 9: 3595 10: 3595 11: 3595 12: 3595
13: 3595 14: 3595 15: 3595 16: 3595 bogomips: 95998
Device-1: NVIDIA TU102 [GeForce RTX 2080 Ti Rev. A] vendor: Micro-Star MSI
driver: N/A alternate: nouveau non-free: 550/565.xx+ status: current (as of
2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s bus-ID: 2b:00.0 chip-ID: 10de:1e07 class-ID: 0300
Device-2: webcamvendor NexiGo N60 FHD Webcam Audio
driver: snd-usb-audio,uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 1-1:2 chip-ID: 3443:60bb class-ID: 0102 serial: <filter>
alternate: fbdev,nv,vesa gpu: N/A display-ID: 0
Monitor-1: Unknown-1 res: mode: 1920x1080 hz: 60 scale: 178% (1.78)
to: 1080x1920 dpi: 96 size: 508x285mm (20x11.22") diag: 582mm (22.93")
modes: 1920x1080
API: EGL v: 1.5 platforms: device: 0 drv: swrast surfaceless: drv: swrast
wayland: drv: swrast x11: drv: swrast inactive: gbm
API: OpenGL v: 4.5 vendor: mesa v: 24.3.4-arch1.1 glx-v: 1.4
direct-render: yes renderer: llvmpipe (LLVM 19.1.7 256 bits)
device-ID: ffffffff:ffffffff memory: 30.53 GiB unified: yes
display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 16 device: 0 type: cpu name: llvmpipe
(LLVM 19.1.7 256 bits) driver: N/A device-ID: 10005:0000
Device-1: NVIDIA TU102 High Definition Audio vendor: Micro-Star MSI
link-max: gen: 3 speed: 8 GT/s bus-ID: 2b:00.1 chip-ID: 10de:10f7
Device-3: Medeli WMT800 Microphone
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 0a67:d061 class-ID: 0300
API: ALSA v: k6.13.1-zen1-1-zen status: kernel-api with: aoss
IF: enp42s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.64 TiB used: 1.47 TiB (40.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 870 EVO 2TB
model: WD10EACS-00ZJB0 size: 931.51 GiB block-size: physical: 512 B
logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: 1B01
scheme: MBR
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 1.47 TiB (80.6%)
fs: btrfs dev: /dev/sdb2 maj-min: 8:18
used: 584 KiB (0.2%) fs: vfat dev: /dev/sdb1 maj-min: 8:17
used: 1.47 TiB (80.6%) fs: btrfs dev: /dev/sdb2 maj-min: 8:18
ID-1: swap-1 type: zram size: 31.27 GiB used: 112.7 MiB (0.4%)
System Temperatures: cpu: 43.0 C mobo: N/A
Memory: total: 32 GiB available: 31.27 GiB used: 8.68 GiB (27.8%)
Processes: 337 Power: uptime: 20m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: 2714 pm: pacman pkgs: 2700 libs: 606 tools: octopi,paru pm: rpm
pkgs: 0 pm: flatpak pkgs: 14 Compilers: clang: 19.1.7 gcc: 14.2.1
Shell: garuda-inxi default: Bash v: 5.2.37 running-in: konsole
inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2023-08-06
Last full system update: 2025-02-05
