So a few weeks ago I installed updates like normal, rebooted my system, and after logging back in noticed my primary monitor keeps blanking repeatedly. The screen goes black for about a second and a half, then it comes back and it displays the “Display Port” message like it had just switched inputs or turned back on. After a few seconds it repeats. After messing around with a few things I just rolled the update back and it was back to working normally. I waited a few days hoping maybe there was a bad package or something and retried the update to the same result. At various times over the last couple weeks I’ve repeated this, as well as checked the output of various logs to see if there was some kind of obvious error message I could look for fixes for, but there’s absolutely no errors I can find I the logs that seem relevant.
I initially suspected this was an issue with Hyprland or one of its dependencies, so I swapped over to Plasma and that did initially seem to fix the issue, but when I enabled variable refresh rate in the plasma settings it started exhibiting the same behavior. I thought that if I just keep that disabled it would fix the problem, but once I started attempting to game it started happening semi-randomly, usually when cutscenes played, although I could also trigger it by simply focusing a window in my second monitor (which has been working perfectly this entire time). So this might be something related to either changes to refresh rate, or possibly mode line. It seems to happen fairly infrequently in Plasma (but it still happens), where as Hyprland it triggers very very often. By disabling VRR in my Hyprland config I can reduce it, but it still occurs far more often than it does in Plasma.
I’m honestly a little stumped on what to do next as I’m not even sure of what component is to blame. It could by the GPU driver, it could be the compositor, it could even be the monitor hardware itself I suppose, although the fact the issue goes away if I rollback to an earlier state seems to suggest it’s software and not hardware.
At this point, if someone doesn’t have an idea what the issue is I’d like to hear suggestions of logs to check to help debug. I checked dmesg and nothing jumps out there, and I checked Hyprlands logs and likewise nothing looks out of the ordinary there. I’m considering once again rolling back to my last known good state, but since it’s been weeks since then I’m not thrilled with that idea. I’d prefer staying up to date with my software if I can, but with my primary monitor being nearly useless because of this bug I’m not sure if I can actually do that.
Kernel: 6.13.1-arch1-1-znver4 arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver4
root=UUID=1370fb7d-5f33-4b95-9dd2-7ddfcba26fe7 rw rootflags=subvol=@
resume=UUID=b7305021-7806-494b-becc-291170d3e056 loglevel=3 splash quiet
wm: kwin_wayland tools: avail: hypridle, hyprlock, swayidle, swaylock vt: 1
Type: Desktop System: Gigabyte product: X870E AORUS MASTER v: N/A
Mobo: Gigabyte model: X870E AORUS MASTER v: x.x
Megatrends LLC. v: F4g date: 11/12/2024
Device-1: hidpp_battery_0 model: Logitech MX Master 3S serial: <filter>
charge: 20% rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 9700X bits: 64 type: MT MCP arch: N/A level: v4
note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
microcode: 0xB404023
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 4970 min/max: 600/5581 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 4970 2: 4970 3: 4970
4: 4970 5: 4970 6: 4970 7: 4970 8: 4970 9: 4970 10: 4970 11: 4970 12: 4970
13: 4970 14: 4970 15: 4970 16: 4970 bogomips: 120587
Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 [Radeon RX 7900 XT/7900
XTX/7900 GRE/7900M] vendor: XFX RX-79XMERCB9 driver: amdgpu v: kernel
arch: RDNA-3 code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie:
gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,HDMI-A-1
empty: DP-2,DP-3,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:744c
vendor: Gigabyte driver: amdgpu v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 ports: active: none empty: DP-4, DP-5, HDMI-A-2, HDMI-A-3,
Writeback-2 bus-ID: 7b:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 39.0 C
gpu: amdgpu d-rect: 4480x1440 display-ID: 0
Monitor-1: DP-1 pos: primary,left model: RDD0013 serial: <filter>
built: 2021 res: mode: 2560x1440 hz: 120 scale: 100% (1) dpi: 92 gamma: 1.2
size: 708x399mm (27.87x15.71") diag: 813mm (32") ratio: 16:9 modes:
max: 2560x1440 min: 640x480
Monitor-2: HDMI-A-1 pos: right model: ASUS VZ279 serial: <filter>
built: 2017 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
navi31 LLVM 19.1.7 DRM 3.59 6.13.1-arch1-1-znver4) device-ID: 1002:744c
memory: 23.44 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.303 layers: 14 device: 0 type: discrete-gpu name: AMD
Radeon RX 7900 XTX (RADV NAVI31) driver: N/A device-ID: 1002:744c
surfaces: xcb,xlib,wayland device: 1 type: integrated-gpu name: AMD
Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: N/A device-ID: 1002:13c0
de: kscreen-console,kscreen-doctor gpu: corectrl wl: kanshi, wayland-info,
wdisplays, wlr-randr x11: xdpyinfo, xprop, xrandr
speed: 16 GT/s lanes: 16 bus-ID: 7b:00.1 chip-ID: 1002:1640 class-ID: 0403
lanes: 16 bus-ID: 7b:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.13.1-arch1-1-znver4 status: kernel-api with: aoss
Device-1: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn driver: ath12k_pci v: N/A modules: ath12k pcie: gen: 3
speed: 8 GT/s lanes: 1 link-max: lanes: 2 bus-ID: 0f:00.0
chip-ID: 17cb:1107 class-ID: 0280
IF: wlp15s0 state: up mac: <filter>
Device-2: Realtek vendor: Gigabyte driver: r8169 v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 1 port: e000 bus-ID: 10:00.0 chip-ID: 10ec:8126
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
wpa_supplicant
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:3 chip-ID: 0489:e10d
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 5.3
lmp-v: 12 sub-v: 43fb hci-v: 12 class-ID: 6c0104
Info: acl-mtu: 1024:8 sco-mtu: 240:4 link-policy: rswitch hold sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 5.46 TiB used: 1.77 TiB (32.3%)
ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Crucial model: CT4000T705SSD3
size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 126 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: PACR5111 temp: 43.9 C
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-1: / raw-size: 3.57 TiB size: 3.57 TiB (100.00%) used: 1.77 TiB (49.4%)
fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:6
ID-3: /home raw-size: 3.57 TiB size: 3.57 TiB (100.00%)
used: 1.77 TiB (49.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:7
ID-4: /var/log raw-size: 3.57 TiB size: 3.57 TiB (100.00%)
ID-5: /var/tmp raw-size: 3.57 TiB size: 3.57 TiB (100.00%)
ID-1: swap-1 type: partition size: 68.65 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:8
ID-2: swap-2 type: zram size: 60.44 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.8 C mobo: N/A
GPU: device: amdgpu temp: 39.0 C device: amdgpu temp: 51.0 C mem: 60.0 C
fan: 0 watts: 40.00
Memory: total: 60 GiB note: est. available: 60.44 GiB used: 7.86 GiB (13.0%)
Processes: 521 Power: uptime: 3m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 24.15 GiB services: org_kde_powerdevil,upowerd
Packages: pm: pacman pkgs: 2939 libs: 639 tools: pacseek,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi
default: Zsh v: 5.9 running-in: alacritty inxi: 3.3.37
Garuda (2.6.26-1.1):
System install date: 2024-10-04
Last full system update: 2025-02-02
