Hello
I installed Dr460nized KDE Gaming Garuda linux about a month and a half ago, but in the last month I have been unable to play videos of any kind on the laptop. Sometimes, just after a reboot, videos will play properly for a few minutes. Plugging in an external USB audio card or DAC also allows videos to play correctly. What's more audio won't work at all while videos won't play. I have read the thread [Manual intervention required] Package conflict between pipewire-media-session & wireplumber and implemented the steps to remove pipewire-media-session. I would appreciate any advice or help I can get fixing this issue. Thank you.
System: Kernel: 5.14.16-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=c037df3f-7e68-4a73-90e8-49b948ea20ec
systemd.unified_cgroup_hierarchy=1 resume=UUID=f9595c82-c97f-421f-a764-16f9e0979e2d loglevel=3
Desktop: KDE Plasma 5.23.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: LENOVO product: 80R4 v: Flex 3-1580 serial: <filter> Chassis: type: 10
Mobo: LENOVO model: Flex 3-1580 v: SDK0J40709 WIN serial: <filter> UEFI: LENOVO v: D3CN28WW
date: 05/09/2016
Battery: ID-1: BAT0 charge: 33.7 Wh (83.0%) condition: 40.6/45.0 Wh (90.3%) volts: 11.2 min: 11.1
model: SMP L14M3P21 type: Li-poly serial: N/A status: Discharging
CPU: Info: Dual Core model: Intel Core i7-6500U bits: 64 type: MT MCP arch: Skylake family: 6
model-id: 4E (78) stepping: 3 microcode: EA cache: L2: 4 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 20799
Speed: 2499 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 2499 2: 2500 3: 2500 4: 2500
Graphics: Device-1: Intel Skylake GT2 [HD Graphics 520] vendor: Lenovo driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:1916 class-ID: 0300
Device-2: NVIDIA GM108M [GeForce 940M] vendor: Lenovo driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1347 class-ID: 0302
Device-3: Acer Lenovo EasyCamera type: USB driver: uvcvideo bus-ID: 1-5:2 chip-ID: 5986:0670
OpenGL: renderer: Mesa Intel HD Graphics 520 (SKL GT2) v: 4.6 Mesa 21.2.4 direct render: Yes
Audio: Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl bus-ID: 00:1f.3 chip-ID: 8086:9d70 class-ID: 0403
Sound Server-1: ALSA v: k5.14.16-zen1-1-zen running: yes
Network: Device-1: Intel Dual Band Wireless-AC 3165 Plus Bluetooth driver: iwlwifi v: kernel
bus-ID: 02:00.0 chip-ID: 8086:3166 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Lenovo driver: r8169
v: kernel port: c000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 1-8:4
chip-ID: 8087:0a2a class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 2 state: down bt-service: enabled,running rfk-block:
hardware: no software: no address: <filter>
Drives: Local Storage: total: 465.76 GiB used: 226.92 GiB (48.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: Western Digital model: WDBNCE5000PNC size: 465.76 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 00RL
Partition: ID-1: / raw-size: 456.7 GiB size: 456.7 GiB (100.00%) used: 226.92 GiB (49.7%) fs: btrfs
dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 562 KiB (0.2%) fs: vfat
dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 456.7 GiB size: 456.7 GiB (100.00%) used: 226.92 GiB (49.7%) fs: btrfs
ID-4: /var/log raw-size: 456.7 GiB size: 456.7 GiB (100.00%) used: 226.92 GiB (49.7%) fs: btrfs
ID-5: /var/tmp raw-size: 456.7 GiB size: 456.7 GiB (100.00%) used: 226.92 GiB (49.7%) fs: btrfs
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 7.56 GiB used: 84.5 MiB (1.1%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 65.0 C mobo: 46.0 C
Info: Processes: 243 Uptime: 15m wakeups: 1 Memory: 7.56 GiB used: 4.12 GiB (54.5%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1922 lib: 536
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.08
