[Manual intervention required] Package conflict between pipewire-media-session & wireplumber
Hey guys! :slight_smile:
Currently while updating, there is a package conflict going on between pipewire-media-session and wireplumber while updating which prevents finishing the update successfully as Pacman can’t handle this type of conflicts.
Wireplumber is a drop-in replacement for pipewire-media-session, which is going to be featured by Garuda from now on as Arch made it possible (thus being dependency of our pipewire-support meta package). While the replacement is seemless, this package conflict still needs to be solved prior to updating.
So, what does this mean for you?
Update! :blush:
  1. If you are on one of the newer version of Garuda Update: just run update as usual. The command will take care of everything by itself (namely, removing pipewire-media-session and updating afterwards)
  2. If you aren’t on one of the newer versions of Garuda Update: sudo pacman -Sy garuda-update && update (the same as before, just updating the script beforehand)
  3. If you prefer to do things manually: sudo pacman -Rdd pipewire-media-session && sudo pacman -Syu
Keep it rolling! :dragon: :fire:
warning: cannot resolve "pipewire-session-manager", a dependency of "pipewire-common-v4l2-git"
warning: cannot resolve "pipewire-v4l2", a dependency of "pipewire-support"
:: The following package cannot be upgraded due to unresolvable dependencies:
      pipewire-support
:: Do you want to skip the above package for this upgrade? [y/N]
you have -git package remove them and install normal ones
I thought so but I don't actually have pipewire-common-v4l2-git installed, it's trying to pull it I guess as a new dependency of pipewire-support
Edit: SOLVED
  • Cloned pipewire-common-v4l2-git
  • Edited its PKGBUILD to depend on wireplumber instead of pipewire-session-manager (line 180 btw)
  • Built pipewire-common-v4l2-git
  • Reinstalled pipewire-support successfully
Still don't know if this is an edge case caused by some -git packages I didn't notice I had, but whatever, audio works now. If anyone else faces this do report
Try this:
sudo pacman -S pipewire-media-session
Then:
sudo pacman -Syu
This worked for me
Used this without flaws here.
Here is a fix to an issue that's been happening.
Then do:
sudo pacman -Syu
running update doesn't automaticly take care of this for me here is my output
 update
 core is up to date
 extra is up to date
 community is up to date
 multilib is up to date
 chaotic-aur is up to date
warning: garuda-update-1.2.4-1 is up to date -- skipping
 there is nothing to do
Refreshing mirrorlists..
[2021-10-25 14:40:40] WARNING: failed to rate http(s) download (https://mirror.theash.xyz/arch/community/os/x86_64/community.db): HTTP Error 403: Forbidden
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --latest 5 --age 2 --fastest 5 --protocol https --sort rate --save /etc/pacman.d/mirrorlist
# When:       2021-10-25 18:40:40 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2021-10-25 18:40:05 UTC
# Last Check: 2021-10-25 18:36:35 UTC
Server = https://america.mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.telepoint.bg/archlinux/$repo/os/$arch
Server = https://europe.mirror.pkgbuild.com/$repo/os/$arch
Server = https://asia.mirror.pkgbuild.com/$repo/os/$arch
Server = https://mirror.theash.xyz/arch/$repo/os/$arch
 core        138.8 KiB  1461 KiB/s 00:00 [-----------------------------------------------------------------------------------------------] 100%
 extra        1572.2 KiB  9.54 MiB/s 00:00 [-----------------------------------------------------------------------------------------------] 100%
 community        5.8 MiB  18.4 MiB/s 00:00 [-----------------------------------------------------------------------------------------------] 100%
 multilib        150.9 KiB  1257 KiB/s 00:00 [-----------------------------------------------------------------------------------------------] 100%
 chaotic-aur        1569.1 KiB  2.33 MiB/s 00:01 [-----------------------------------------------------------------------------------------------] 100%
Checking for keyring update before starting full system update..
warning: garuda-hotfixes-1.0.0-2 is up to date -- skipping
warning: archlinux-keyring-20210902-1 is up to date -- skipping
warning: chaotic-keyring-20210617-1 is up to date -- skipping
resolving dependencies...
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: wireplumber and pipewire-media-session are in conflict
Read first post carefully again, please.
Use 2. or 3.
yeah option 3 worked for me I was just reporting that using garuda update doesn't I tried installing the latest garuda update first with sudo pacman -Sy garuda-update && update and that game pretty much the same output
[sudo] password for zany130:
 core is up to date
 extra is up to date
 community                                         5.8 MiB  26.5 MiB/s 00:00 [-------------------------------------------] 100%
 chaotic-aur                                    1569.0 KiB  2.12 MiB/s 00:01 [-------------------------------------------] 100%
warning: garuda-update-1.2.4-1 is up to date -- reinstalling
Packages (1) garuda-update-1.2.4-1
Total Installed Size:  0.00 MiB
Net Upgrade Size:      0.00 MiB
(1/1) checking keys in keyring                                               [-------------------------------------------] 100%
(1/1) checking package integrity                                             [-------------------------------------------] 100%
(1/1) loading package files                                                  [-------------------------------------------] 100%
(1/1) checking for file conflicts                                            [-------------------------------------------] 100%
(1/1) checking available disk space                                          [-------------------------------------------] 100%
==> root: 432
(1/1) reinstalling garuda-update                                             [-------------------------------------------] 100%
( 1/10) Arming ConditionNeedsUpdate...
( 2/10) Refreshing PackageKit...
( 3/10) Foreign/AUR package notification
air-for-steam 2019_0917-1
android-bash-completion r43.c1b0656-1
android-sdk-build-tools r31-2
apk-preview 1.3.2-3
apk-thumbnailer 1.0-2
app-outlet-bin 1.3.4-4
archlinux-artwork 1.6-6
archlinux-themes-sddm 2.0-1
awesome-terminal-fonts-patched 1.0.0-2
base-devel-meta 2021.08.07-1
betterdiscord-installer 1.1.1-1
chiaki-git 2.1.1.r8.g796a128-1
cod 0.1.0-2
compleat-git r121.8cf2bcd-1
ddd-ftn 3.3.12-13
dolphin-megasync-bin 3.6.6-2
dotpac 0.4-4
dracula-gtk-theme v2.0-1
emojify 2.2.0-1
etcher-bin 1.6.0-1
findbrokenpkgs 1.1-1
flareget 5.0.0-2
fluent-cursor-theme-git 2021.10.07.r0.g6399706-1
fluent-decoration-git r33.5655249-1
fluent-icon-theme-git 2021.10.07.r0.g6399706-1
fluent-kde-theme-git r47.f1ac81e-1
font-victor-mono 1.4.2-1
fontconfig-emoji-git r15.3706c6c-1
fusesmb 0.8.7-4
fzf-extras 0.3.1-1
g810-led-lib 0.4.2-1
g930-battery-percentage-git r15.0b1e831-1
gamescope-session-git r14.a1a7a18-1
hastebin 1.4.0-1
i2c-tools-git r384.eacb6a4-1
imgcat 1.2.0-2
isl 0.24-2
kcm-colorful-git 1.0.5.r0.g411e8c9-1
kcm-grub2-git 0.6.4.r87.g024abc7-1
kcm-uefi 0.1-1
kde-thumbnailer-apk 1.1-1
kvantum-theme-adapta 20180828-1
kvantum-theme-arc 20180614-3
kvantum-theme-chromeos-git r35.a6c9349-1
kvantum-theme-fluent-git r17.890a450-1
kvantum-theme-sunset-dark-git r4.d21b6a1-1
kwin-effect-shapecorners-git r15.c7e6fe8-1
kwin-scripts-parachute 0.9.1-1
lib32-ncurses5-compat-libs 6.2-1
libdbusmenu-qt4 0.9.3+16.04.20160218-1
libffi6 3.2.1-1
libmagick6 6.9.12.25-3
libpng15 1.5.30-1
libsndio-61-compat 1.3.0-1
ludusavi 0.10.0-3
material-cursors-git 20210524-1
mono-basic 4.8-1
mons 0.8.2-1
mpd-discord-rpc-git v1.2.0.r13.gb58c98e-1
mpv-discordrpc 1.4.1-1
mymc 2.6-11
nano-syntax-highlighting-git 2020.10.10.r10.g1aa64a8-1
netcoredbg 1.2.0_786-1
noto-fonts-emoji-flags 20200120-1
nro-thumbnailer-git 0.0.2.r0.gdc57dfc-1
nx-udev 0.1.1-1
opencolorio1 1.1.1-3
organize 1.10.1-1
osl 0.9.2-2
pinta-git r1974.09147832-1
pkg2zip-fork 2.2-2
plasma5-applet-awesome-widgets 3.4.3-1
plasma5-wallpapers-wallpaper-engine-git r337.f504ea8-1
plasmoidviewer-debug 5.15.0-1
plymouth-kcm 5.23.1-1
pnputils-git 0.1.3.r56.g81e685a-1
polkit-qt4 0.112.0+git20180107-1
protondb-tags 1.1.1-1
pug-hook-git 20200107.e4bb973-1
python-exifread 2.3.2-1
python-simplematch 1.3-1
python-smbus-git r384.eacb6a4-1
remoteplaydetached-bin v0.4.1-1
retrosmart-kvantum-theme 1.0b-1
sddm-elegant-theme-git r34.732499b-1
semantik 1.2.7-1
speedtest++ 1.14.r68.1877803-1
sssm 1.2.1-1
steamtinkerlaunch-git 6.18.323.r493.5b18af2-1
strace-analyzer 0.3.1-1
sunset-dark-kde-git r4.d21b6a1-1
systemd-kcm 1.2.1-5
terminal_dimensions-git r2.8e34b6f-1
termpdf-git r151.651506e-1
ttf-twemoji-color 13.1.0-1
uget-integrator 1.0.0-2
uget-integrator-chromium 1.0.0-4
uget-integrator-firefox 1.0.0-4
unified-remote-server 3.10.0.2467-1
vim-dracula 2.0.0-4
virtio-win 0.1.208.1-1
vivaldi-widevine 1:4.10.2209.0-1
win11-gtk-theme-git r10.62225c3-1
win11-icon-theme-git r128.a148adf-1
xdotool-gui 1.2-2
xrasengan 1.0.0-5
zenmonitor 1.4.2-2
zsh-systemd-git r2.d9fea29-1
zsh-you-should-use 1.7.3-1
( 4/10) Orphaned package notification...
chrpath 0.16-3
extra-cmake-modules 5.87.0-1
ffmpeg3.4 3.4.9-1
ghostpcl 9.55.0-2
ghostxps 9.55.0-2
gtkmm 1:2.24.5-4
inkscape 1.1.1-2
jbigkit 2.1-5
xorg-xcursorgen 1.0.7-2
yarn 1.22.17-1
( 5/10) Checking for .pacnew and .pacsave files...
( 6/10) Updating pkgfile database...
( 7/10) pug.hook
:: Processing gists update...
( 8/10) Checking which packages need to be rebuilt
( 9/10) Performing snapper post snapshots for the following configurations...
==> root: 433
(10/10) Syncing all file systems...
 core is up to date
 extra is up to date
# When:       2021-10-25 19:15:06 UTC
# Retrieved:  2021-10-25 19:14:57 UTC
# Last Check: 2021-10-25 19:07:05 UTC
Server = https://arch.mirror.square-r00t.net/$repo/os/$arch
Server = https://mirror.f4st.host/archlinux/$repo/os/$arch
Server = https://archlinux.mailtunnel.eu/$repo/os/$arch
Server = https://archlinux.thaller.ws/$repo/os/$arch
 core                                            138.8 KiB   313 KiB/s 00:00 [-------------------------------------------] 100%
 extra                                          1572.2 KiB  3.12 MiB/s 00:00 [-------------------------------------------] 100%
 community                                         5.8 MiB  9.34 MiB/s 00:01 [-------------------------------------------] 100%
 multilib                                        150.9 KiB   370 KiB/s 00:00 [-------------------------------------------] 100%
 chaotic-aur                                    1569.0 KiB  2.24 MiB/s 00:01 [-------------------------------------------] 100%
doing it manually worked ofc
Packages (1) pipewire-media-session-1:0.3.38-1
Total Removed Size:  0.40 MiB
:: Do you want to remove these packages? [Y/n] y
==> root: 434
Removed /etc/systemd/user/pipewire-session-manager.service.
Removed /etc/systemd/user/pipewire.service.wants/pipewire-media-session.service.
(1/1) removing pipewire-media-session                                        [-------------------------------------------] 100%
(1/9) Arming ConditionNeedsUpdate...
(2/9) Refreshing PackageKit...
(3/9) Foreign/AUR package notification
apk-preview 1.3.2-3
cod 0.1.0-2
ddd-ftn 3.3.12-13
dotpac 0.4-4
emojify 2.2.0-1
etcher-bin 1.6.0-1
flareget 5.0.0-2
fusesmb 0.8.7-4
fzf-extras 0.3.1-1
hastebin 1.4.0-1
imgcat 1.2.0-2
isl 0.24-2
kcm-uefi 0.1-1
libffi6 3.2.1-1
libpng15 1.5.30-1
ludusavi 0.10.0-3
mono-basic 4.8-1
mons 0.8.2-1
mymc 2.6-11
nx-udev 0.1.1-1
organize 1.10.1-1
osl 0.9.2-2
pkg2zip-fork 2.2-2
semantik 1.2.7-1
sssm 1.2.1-1
systemd-kcm 1.2.1-5
vim-dracula 2.0.0-4
xdotool-gui 1.2-2
xrasengan 1.0.0-5
zenmonitor 1.4.2-2
(4/9) Orphaned package notification...
chrpath 0.16-3
ffmpeg3.4 3.4.9-1
ghostpcl 9.55.0-2
ghostxps 9.55.0-2
gtkmm 1:2.24.5-4
inkscape 1.1.1-2
jbigkit 2.1-5
yarn 1.22.17-1
(5/9) Checking for .pacnew and .pacsave files...
(6/9) Updating pkgfile database...
(7/9) pug.hook
==> root: 435
 core is up to date
 extra is up to date
Packages (33) alsa-card-profiles-1:0.3.39-1  anbox-git-1:r1358.84f0268-2  android-tools-31.0.3-1  botan-2.18.2-1
              ceph-libs-15.2.14-2  exiv2-0.27.5-1  fish-autopair-1.0.3-2  gst-plugin-pipewire-1:0.3.39-1
              imagemagick-7.1.0.11-1  inxi-3.3.08.1-1  kwin-5.23.1-2  lib32-libsoup-2.74.1-1  lib32-mpg123-1.29.2-1
              lib32-pipewire-1:0.3.39-1  libsoup-2.74.1-1  libsoup3-3.0.2-1  lutris-git-0.5.9.1.r2.g5632d3b8-1
              lxc-git-4.0.0.r2102.g8dff29c6c-1  mpg123-1.29.2-1  omnisharp-roslyn-1.37.16-2  opencolorio-2.1.0-2
              pipewire-1:0.3.39-1  pipewire-alsa-1:0.3.39-1  pipewire-jack-1:0.3.39-1  pipewire-pulse-1:0.3.39-1
              pipewire-support-1-7  pipewire-v4l2-1:0.3.39-1  pipewire-zeroconf-1:0.3.39-1
              wine-tkg-staging-fsync-git-6.20.r0.g3fb6eb99-326  wireplumber-0.4.4-3  xemu-git-0.6.1.r24.g5ae39a321a-1
              yaml-cpp-0.7.0-2  yuzu-mainline-git-r19854.c0793f0cb-1
Total Download Size:   171.17 MiB
Total Installed Size:  814.34 MiB
Net Upgrade Size:       24.37 MiB
There's a few things going on here, but I think the main thing is that until wireplumber is installed and correctly provides for pipewire-media-session that it replaces, a bunch of other packages including kwin are going to want to hold on to the latter. That's why using -Rdd works, it ignores the broken dependencies
Update only takes care of this if you have media session and pipewire-support installed. If you manual set up your pipewire or something it won't take care of the conflict.
As I tried updating it by every method the same error accurse. All it did is uninstalling pipeware but I cant install Wireplumber
[🔴] × LANG=C sudo pacman -Syu
core is up to date
extra is up to date
community        5,8 MiB  10,1 MiB/s 00:01 [------------------------------------------------------------] 100%
multilib-testing is up to date
:: There are 2 providers available for pipewire-session-manager:
:: Repository extra
1) pipewire-media-session  2) wireplumber
Enter a number (default=1): 2
warning: cannot resolve "libcap=2.60", a dependency of "lib32-libcap"
lib32-libcap
:: Do you want to skip the above package for this upgrade? [y/N] y
:: installing libcap (2.59-1) breaks dependency 'libcap=2.58' required by lib32-libcap
That's a different error.
What does it mean and how can I fix it? I tried looking it up but only something with community testing came up.
my system came with pulse as my original install was a few months ago. I installed pipewire support by using the option in the garuda assistant which I belive just does sudo pacman -S pipewire-support and removes some pulse stuff.
Thank you for that! I am new to Linux and love Garuda Linux, thanks for all you all do and keep up the great work!!
Typical, when the conflict appeared a couple days ago, I went for removing wireplumber.
-Rdd pipewire-media-session then installing wireplumber appears to have worked for me to switch.
Props on the quick announcement, though in an ideal world, would have announcement prior to conflict arising.
Oh i see... @librewish made a typo in the script >.>
All fixed now, sorry about that everyone!
