appu
15 April 2021 11:06
1
why this is happening?
i am using garuda Linux for 2 months..... this is never happened before..
after a update............it's happens
i restart my pc ........ again it shows.
and i also check network wire....it is ok.....
then i added another connection ............. but it could not solve.
what to do?
I have already mentioned my efforts So that you can't say I don't check anything
like my previous questions
please help ..... internet is very essential.
Err, is your internet working? (how did you post)?
As always some system info is useful
inxi -Fxxxza
tbg
15 April 2021 19:08
4
Start with the basics, have you restarted your router?
If so, I would ssuggest resetting your router back to the factory default.
If this happened after an update check your pacman log for any internet related packages that were updated that may have caused this.
Post a list of any Internet related packages that you found in the update that resulted in this problem.
Have you tried rolling back your system to before this problem occurred?
Have you tested a live boot disk to see if the problem exists in the live environment?
Please answer all my questions to the best of your ability and post your system specs as requested if you wish further assistance.
appu
16 April 2021 04:53
7
tbg
16 April 2021 05:11
8
Yes, that was why I suggested it twice.
Nice of you to credit yourself with the solution, but itβs really not a long term solution. The problem will likely come back if you update.
You can wait for a week or so, then update and see if a fix has come through.
The most proactive method is to sequentially update one at a time the network packages involved to isolate the update that broke things.
This command will help identify the packagers that might have caused the problem:
cat /var/log/pacman.log | grep -i "d systemd (\|ed linux\|mware\|twork\|dkms ins\|a-nm\|nm-c\|ufw\|dhc\|dns\|tlp\|wpa\|vnc\|ifplugd\|regdb" | grep -v "head\|nvidia" | tail -n 30
This will output a list of packages that were updated on your system recently that can affect networking.
Please post the output of the command above. This information will help others as well as yourself.
appu
16 April 2021 05:28
10
another question....
should i reinstall garuda Linux to solve my problems?
i am using it from 2 month and .............there are so many junk files........and unwanted apps........and my storage is almost full ( i had created 70GB partition for garuda linux) in my system.
and when i uninstall a app its data can't be remove.....when i reinstall those apps i see it's started from there where i left before.
so, i want to reinstall my garuda Linux... to get a fresh and new operating system ...... what is your opinion ?
tbg
16 April 2021 05:33
11
No pics only post output as text.
tbg
16 April 2021 05:38
13
Can't read worthless pics.
Use USB phone tethering for an internet connection to post proper textual outputs.
We cant help you if you dont follow instructions anyway. Once again, pictures are worthless for several reasons - we need the text output pasted instead.
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
Itβs especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your β¦
The main problem is that you don't post the inxi -Fxxxza output.
appu
16 April 2021 15:16
20
β°βΞ» cat /var/log/pacman.log | grep -i "d systemd (\|ed linux\|mware\|twork\|dkms ins\|a-nm\|nm-c\|ufw\|dhc\|dns\|tlp\|wpa\|vnc\|ifplugd\|regdb" | grep -v "head\|nvidia" | tail -n 30
[2021-04-10T19:21:03+0530] [ALPM] upgraded linux-zen (5.11.11.zen1-1 -> 5.11.12.zen1-1)
[2021-04-10T19:21:11+0530] [ALPM] upgraded sof-firmware (1.6.1-1 -> 1.7-2)
[2021-04-10T19:21:44+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-10T19:21:50+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-10T19:21:52+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-10T19:21:52+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-10T19:22:03+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-10T19:22:08+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-10T19:22:09+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-10T19:22:09+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-10T19:34:38+0530] [ALPM] removed garuda-network-assistant (1.0.0-1)
[2021-04-10T19:34:38+0530] [ALPM] installed garuda-network-assistant-git (r29.571422f-1)
[2021-04-11T13:15:08+0530] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m v4l2loopback-dc -v 1.7.2 -k 5.11.12-zen1-1-zen
[2021-04-11T13:15:25+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-11T13:15:35+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-11T13:15:36+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-11T13:15:37+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-13T21:20:44+0530] [ALPM] upgraded kdnssd (5.80.0-1 -> 5.81.0-1)
[2021-04-13T21:20:56+0530] [ALPM] upgraded linux-zen (5.11.12.zen1-1 -> 5.11.13.zen1-1)
[2021-04-13T21:21:03+0530] [ALPM] upgraded networkmanager-qt (5.80.0-1 -> 5.81.0-1)
[2021-04-13T21:21:39+0530] [ALPM-SCRIPTLET] ==> dkms install --no-depmod -m v4l2loopback-dc -v 1.7.2 -k 5.11.13-zen1-1-zen
[2021-04-13T21:21:54+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-13T21:22:01+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-13T21:22:02+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-13T21:22:03+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-13T21:22:13+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-13T21:22:18+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: aic94xx
[2021-04-13T21:22:19+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: wd719x
[2021-04-13T21:22:20+0530] [ALPM-SCRIPTLET] ==> WARNING: Possibly missing firmware for module: xhci_pci
[2021-04-14T17:57:31+0530] [PACMAN] Running 'pacman -Su --needed appmenu-gtk-module ark bluedevil breeze breeze-gtk colord-kde dolphin dolphin-plugins drkonqi filelight gimp gwenview kactivitymanagerd kamoso kate kcalc kcron kde-cli-tools kdeconnect kdecoration kde-gtk-config kdeplasma-addons kdf kdialog keditbookmarks kfind kgamma5 khelpcenter khotkeys kinfocenter kio-extras kio-fuse kio-gdrive kleopatra kmenuedit kompare konsole krdc krename krfb krita krita-plugin-gmic kscreen kscreenlocker ksshaskpass ksysguard ksystemlog kwalletmanager kwallet-pam kwayland-integration kwayland-server kwin kwrited libkscreen libksysguard librewolf-extension-xdm-browser-monitor milou okular opencolorio oxygen partitionmanager plasma-browser-integration plasma-desktop plasma-disks plasma-firewall plasma-integration plasma-nm plasma-pa plasma-systemmonitor plasma-thunderbolt plasma-vault plasma-workspace plasma-workspace-wallpapers polkit-kde-agent powerdevil qbittorrent quota-tools spectacle systemsettings vivaldi vivaldi-ffmpeg-codecs xdman yakuake'
