This guide is a copy (today 2021-01-07T22:00:00Z) of the original instructions for building aguslr/mbusb "Multiboot USB" project.
Using this guide, you can create a USB Drive that will be able to boot to UEFI and MSDOS/Legacy BIOS systems and to a long list of Linux (and more) distributions ISOs, which you only need to copy to the isos folder in the USB Drive.
Unfortunately, the developer stopped supporting new distributions and possible issues, but luckily it is forked by hackerncoder, who continues a limited but important enough support.
Preparing the multiboot USB
Getting the configuration files
Using Git
If we have Git installed on the system, we can get the files directly from the repository:
git clone https://github.com/aguslr/multibootusb
After this, every time we want to update the files we do:
cd multibootusb && git pull
Without Git
If Git is not installed, we can still get the files as long as we have a basic Unix environment available:
wget https://github.com/aguslr/multibootusb/archive/master.tar.gz -O - | tar -xzv --strip-components 1 --exclude={README.md,docs}
Creating new USB drive
We must have the files for targets i386-pc (e.g. package grub-pc-bin in Debian/Ubuntu) and x86_64-efi (e.g. package grub-efi-amd64-bin in Debian/Ubuntu) available in the system, usually in /usr/lib/grub/.
Manually preparing the drive
Creating a bootable USB drive
Follow the instructions to create a Hybrid UEFI GPT + BIOS GPT/MBR boot from the ArchWiki.
Copying the configuration files to the USB drive
Set variables to avoid errors:
export mntusb=<mountpoint> partusb=<partition>Where
<mountpoint>is any directory you want the partition to be mounted at (e.g. /media/usb), and<partition>is the name of the data partition (e.g. /dev/sdh3). Rundmesgto get this information. -
Mount the data partition:
mount --target $mntusb $partusb -
Create a directory named boot to store GRUB’s configuration files and a directory named isos for the kernel/ISO files:
mkdir -p $mntusb/boot/{grub/mbusb.d/,isos} -
Copy the necessary GRUB files:
cd multibootusb && cp -rf mbusb.* $mntusb/boot/grub/ -
Copy the provided
grub.cfg:cp -f grub.cfg.example $mntusb/boot/grub/grub.cfg -
Download MEMDISK from kernel.org:
wget -qO - 'https://www.kernel.org/pub/linux/utils/boot/syslinux/syslinux-6.03.tar.gz' | tar -xz -C $mntusb/boot/grub/ --no-same-owner --strip-components 3 'syslinux-6.03/bios/memdisk/memdisk'
Using the script
Simply run as root:
./makeUSB.sh <device>
Where <device> is the name of the USB device (e.g. /dev/sdh). Run mount to get this information.
WARNING: This will delete all data in the device, so make sure you pick the right one.
These are the options for the script:
Script to prepare multiboot USB drive
Usage: makeUSB.sh [options] device [fs-type] [data-size]
device Device to modify (e.g. /dev/sdb)
fs-type Filesystem type for the data partition [ext3|ext4|vfat|ntfs]
data-size Data partition size (e.g. 5G)
-b, --hybrid Create a hybrid MBR
-c, --clone Clone Git repository on the device
-e, --efi Enable EFI compatibility
-i, --interactive Launch gdisk to create a hybrid MBR
-h, --help Display this message
Adding to existing USB drive
If you already have your own bootable USB drive that uses GRUB to boot, you can simply add the following lines into your custom grub.cfg:
# Load MBUSB configuration
if [ -e "$prefix/mbusb.cfg" ]; then
source "$prefix/mbusb.cfg"
fi
And then copy the project’s configuration files to your drive’s GRUB directory:
Get bootable files
Once you have a bootable USB drive, it only remains to copy the bootable files (ISO or kernel) to the pendrive. See the list of supported files for download links and then save them into $mntusb/boot/isos.
Testing USB drive with QEMU
To test the newly created USB drive in a virtual environment with QEMU, run:
qemu-system-x86_64 -enable-kvm -rtc base=localtime -m 2G -vga std -drive file=<device>,readonly,cache=none,format=raw,if=virtio
Resources
- Hybrid MBRs
- Hybrid UEFI GPT + BIOS GPT/MBR boot
- grub.cfg · Jimmy-Z/grub-iso-boot
- Man page of SGDISK
- MultiBoot USB with Grub2 (boot directly from iso files)
- QEMU Emulator User Documentation
- Super Grub Disk Wiki - Loopback.cfg
- Transform a USB stick into a boot device packing multiple Linux distros
- Tuning KVM - KVM
- Using Syslinux and memdisk
