Im hoping to use an xbox one controller wirelessly on my pc but in the bluetooth settings all it says is no bluetooth adapters found. i have bluetooth capabilities built into my motherboard
Kernel: 6.11.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=98337a5e-7d41-441c-aa61-b054de8972e4 rw rootflags=subvol=@
quiet resume=UUID=1fbfecb0-5cf4-42d7-afcd-dcc3e9733c79 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.2.2 tk: Qt v: N/A info: frameworks v: 6.7.0
Mobo: ASUSTeK model: TUF GAMING B550-PLUS WIFI II v: Rev X.0x
UEFI: American Megatrends v: 3610 date: 08/30/2024
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 550 min/max: 550/5619 boost: disabled scaling:
driver: amd-pstate-epp governor: performance,powersave cores: 1: 550 2: 550
3: 550 4: 550 5: 550 6: 550 7: 550 8: 550 9: 550 10: 550 11: 550 12: 550
13: 550 14: 550 15: 550 16: 550 17: 550 18: 550 19: 550 20: 550 21: 550
22: 550 23: 550 24: 550 bogomips: 201594
Device-1: Intel DG2 [Arc A750] driver: i915 v: kernel alternate: xe
arch: Gen-12.7 code: Alchemist process: TSMC n6 (7nm) built: 2022+ pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 ports: active: DP-1 empty: DP-2, DP-3,
DP-4, HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 09:00.0 chip-ID: 8086:56a1
Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
Screen-1: 0 s-res: 3840x2160 s-dpi: 216 s-size: 451x254mm (17.76x10.00")
s-diag: 518mm (20.38")
Monitor-1: DP-1 model: Roku TV built: 2020 res: 3840x2160 hz: 60 dpi: 122
gamma: 1.2 size: 800x450mm (31.5x17.72") diag: 1263mm (49.7") ratio: 16:9
modes: max: 3840x2160 min: 720x400
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.2.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc A750 Graphics (DG2)
device-ID: 8086:56a1 memory: 7.75 GiB unified: no
API: Vulkan v: 1.3.295 layers: 13 device: 0 type: discrete-gpu name: Intel
Arc A750 Graphics (DG2) driver: mesa intel v: 24.2.5-arch1.1
device-ID: 8086:56a1 surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
(LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.2.5-arch1.1 (LLVM
Device-1: Intel DG2 Audio driver: snd_hda_intel v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 0a:00.0 chip-ID: 8086:4f90 class-ID: 0403
lanes: 16 bus-ID: 0c:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: C-Media Blue Snowball driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-3.3:3
chip-ID: 0d8c:0005 class-ID: 0300 serial: <filter>
Device-4: Texas Instruments PCM2902 Audio Codec
lanes: 1 mode: 1.1 bus-ID: 3-3.4.4.4:9 chip-ID: 08bb:2902 class-ID: 0300
API: ALSA v: k6.11.5-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 05:00.0 chip-ID: 14c3:7961 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
IF-ID-1: wg0-mullvad state: unknown speed: N/A duplex: N/A mac: N/A
Local Storage: total: 3.87 TiB used: 154.26 GiB (3.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: SB-RKT4P-2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: R4PB47.4 temp: 39.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
tech: SSD serial: <filter> fw-rev: 046 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Patriot model: P210 256GB
tech: SSD serial: <filter> fw-rev: 4A0 scheme: GPT
ID-4: /dev/sdc maj-min: 8:32 vendor: Seagate model: ST1000DM003-1SB102
tech: HDD rpm: 7200 serial: <filter> fw-rev: CC63 scheme: GPT
ID-1: / raw-size: 1.79 TiB size: 1.79 TiB (100.00%) used: 154.26 GiB (8.4%)
used: 154.26 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-2: swap-2 type: partition size: 34.37 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 37.1 C mobo: 34.0 C
Memory: total: 32 GiB available: 31.25 GiB used: 3.98 GiB (12.7%)
Processes: 445 Power: uptime: 17m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.49 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1884 libs: 549 tools: octopi,paru Compilers:
clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date: 2024-10-18
Last full system update: 2024-10-30
Failed units: nmb.service
