garuda is up to date
core is up to date
extra is up to date
community is up to date
multilib is up to date
chaotic-aur is up to date
--> Refreshing mirrorlists using rate-mirrors, please be patient..π΅
garuda downloading...
core downloading...
extra downloading...
community downloading...
multilib downloading...
chaotic-aur downloading...
:: Replace mangohud-common with extra/mangohud? [Y/n] y
:: Replace qgpgme with core/qgpgme-qt5? [Y/n] y
warning: reflector-simple: local (2.0-1.1) is newer than garuda (2.0-1)
resolving dependencies...
warning: removing 'python-xdg' from target list because it conflicts with 'python-pyxdg'
error: unresolvable package conflicts detected
error: failed to prepare transaction (conflicting dependencies)
:: mangohud and mangohud-common are in conflict`
it doesn't let me choose whether or not I want to replace mangohud, and I consequently can't update
ββcrisperz@ARGAMA in ~ as π§ took 10ms
[π΄] Γ sudo garuda-inxi
root=UUID=dfeea324-85c7-445c-bc20-30d213ecf1a6 rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.4 tk: Qt v: 5.15.9 wm: kwin_x11 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z790 AORUS ELITE AX DDR4 v: x.x
serial: N/A UEFI: American Megatrends LLC. v: F5 date: 03/07/2023
Info: model: 13th Gen Intel Core i7-13700KF socket: U3E1 bits: 64
type: MST AMCP arch: Raptor Lake gen: core 13 level: v3 note: check
built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
stepping: 1 microcode: 0x113
Topology: cpus: 1x cores: 16 mt: 8 tpc: 2 st: 8 threads: 24 smt: enabled
cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32 KiB, 8x64 KiB
L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 3304 high: 3400 min/max: 800/5300:5400:4200
base/boost: 3400/8500 scaling: driver: intel_pstate governor: powersave
volts: 1.0 V ext-clock: 100 MHz cores: 1: 3400 2: 3400 3: 3400 4: 3400
5: 3400 6: 3400 7: 1100 8: 3400 9: 3400 10: 3400 11: 3400 12: 3400
13: 3400 14: 3400 15: 3400 16: 3400 17: 3400 18: 3400 19: 3400 20: 3400
21: 3400 22: 3400 23: 3400 24: 3400 bogomips: 164044
vendor: Tul / PowerColor driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: DP-1,DP-3 empty: DP-2,HDMI-A-1 bus-ID: 03:00.0
chip-ID: 1002:73df class-ID: 0300
s-diag: 1052mm (41.43")
Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,left
model: Dell G2422HS serial: <filter> built: 2022 res: 1920x1080 hz: 60
dpi: 93 gamma: 1.2 size: 527x296mm (20.75x11.65") diag: 595mm (23.4")
Monitor-2: DP-3 mapped: DisplayPort-2 pos: right model: Dell G2422HS
serial: <filter> built: 2022 res: 1920x1080 hz: 60 dpi: 93 gamma: 1.2
size: 527x296mm (20.75x11.65") diag: 595mm (23.4") ratio: 16:9 modes:
API: OpenGL v: 4.6 Mesa 23.0.3 renderer: AMD Radeon RX 6700 XT (navi22
LLVM 15.0.7 DRM 3.49 6.2.13-zen-1-zen) direct-render: Yes
Device-1: Intel vendor: Gigabyte driver: snd_hda_intel bus-ID: 1-11.1:4
v: kernel alternate: snd_sof_pci_intel_tgl chip-ID: 1235:8211 class-ID: 0102
bus-ID: 00:1f.3 chip-ID: 8086:7a50 serial: <filter> class-ID: 0403
pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-3: Focusrite-Novation Scarlett Solo (3rd Gen.) type: USB
driver: snd-usb-audio
API: ALSA v: k6.2.13-zen-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 0.3.70 status: n/a (root, process) with:
Device-1: Intel driver: iwlwifi v: kernel port: N/A bus-ID: 00:14.3
chip-ID: 8086:7a70 class-ID: 0280
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 3000 bus-ID: 07:00.0
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-14:8
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 4.21 TiB used: 10.37 GiB (0.2%)
ID-1: /dev/nvme0n1 maj-min: 259:3 vendor: Samsung model: SSD 980 1TB
lanes: 4 type: SSD serial: <filter> rev: 1B4QFXO7 temp: 34.9 C scheme: GPT
SMART: yes health: PASSED on: 179d 1h cycles: 1,854
read-units: 61,249,899 [31.3 TB] written-units: 60,286,565 [30.8 TB]
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Kingston model: SNV2S2000G
lanes: 4 type: SSD serial: <filter> rev: SBM02103 temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 82d 18h cycles: 626
read-units: 7,345,266 [3.76 TB] written-units: 9,333,116 [4.77 TB]
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: ST500LM012 HN-M500MBB
family: Seagate SpinPoint M8 (AF) size: 465.76 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 3.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 0010 temp: 28 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 89d 13h cycles: 3448
model: WD10JPVX-00JC3T0 family: Blue Mobile size: 931.51 GiB block-size:
physical: 4096 B logical: 512 B sata: 3.0 speed: 6.0 Gb/s type: HDD
rpm: 5400 serial: <filter> rev: 1A01 temp: 30 C scheme: PMBR
SMART: yes state: enabled health: PASSED on: 2y 127d 12h cycles: 5179
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk model: Ultra
size: 115.69 GiB block-size: physical: 512 B logical: 512 B type: N/A
used: 10.37 GiB (2.2%) fs: btrfs block-size: 4096 B dev: /dev/sda2
maj-min: 8:2
used: 576 KiB (0.2%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
maj-min: 8:2
maj-min: 8:2
maj-min: 8:2
ID-1: swap-1 type: zram size: 31.18 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 26.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
mem: 38.0 C
Processes: 457 Uptime: 35m wakeups: 0 Memory: 31.18 GiB
used: 3.51 GiB (11.2%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1787
libs: 517 tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.26
System install date: 2023-05-27
Last full system update: 2023-05-27
Is partially upgraded: Yes
Windows dual boot: Yes
