I don't have optimus-manager-gitor any of its derivatives installed, unlike the recent solution presented in 1727. But I have the same problem, terminal output when running lutris:
File "/usr/bin/lutris", line 52, in <module>
from lutris.gui.application import Application # pylint: disable=no-name-in-module
ModuleNotFoundError: No module named 'lutris'
Tried re-installing, and installing lutris-git and building from AUR. No luck.
When using lutris, I get this error:
Fatal Python error: init_sys_streams: can't initialize sys standard streams
Python runtime state: core initialized
File "/usr/lib/python3.10/io.py", line 54, in <module>
ImportError: cannot import name 'text_encoding' from 'io' (unknown location)
inxi -Faz:
[🔴] × inxi -Faz
Kernel: 5.15.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=271f832d-09f2-4b21-a369-ae6519f69c12 rw rootflags=subvol=@
systemd.unified_cgroup_hierarchy=0 cgroup_enable=memory swapaccount=1
resume=UUID=bef431c9-3bd8-4fcc-9de0-55d0e0864379
Type: Desktop Mobo: ASUSTeK model: ROG STRIX B350-F GAMING v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 5603
date: 07/28/2020
Info: model: AMD Ryzen 7 1700 bits: 64 type: MT MCP arch: Zen
family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001138
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2780 high: 3205 min/max: 1550/3000 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 2832 2: 2602
3: 2721 4: 3108 5: 2644 6: 2728 7: 2700 8: 3182 9: 2549 10: 2702 11: 2560
12: 3047 13: 2789 14: 2558 15: 2559 16: 3205 bogomips: 95806
STIBP: disabled, RSB filling
Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: eVga.com.
driver: nvidia v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 07:00.0
chip-ID: 10de:1b06 class-ID: 0300
Device-2: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 1-2:2 chip-ID: 046d:0843 class-ID: 0102
loaded: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-dpi: 109 s-size: 802x333mm (31.6x13.1")
s-diag: 868mm (34.2")
Monitor-1: DP-2 res: 3440x1440 dpi: 109 size: 800x330mm (31.5x13.0")
diag: 865mm (34.1")
OpenGL: renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA GP102 HDMI Audio vendor: eVga.com. driver: snd_hda_intel
v: kernel bus-ID: 07:00.1 chip-ID: 10de:10ef class-ID: 0403
v: kernel bus-ID: 09:00.3 chip-ID: 1022:1457 class-ID: 0403
Device-3: Logitech Webcam C930e type: USB driver: snd-usb-audio,uvcvideo
Device-4: SAVITECH JDS Labs Element DAC type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-3:2 chip-ID: 262a:1048
class-ID: 0102
Sound Server-1: ALSA v: k5.15.10-zen1-1-zen running: yes
port: d000 bus-ID: 04:00.0 chip-ID: 8086:1539 class-ID: 0200
IF-ID-1: br-0dc7692bb377 state: down mac: <filter>
IF-ID-3: virbr0 state: down mac: <filter>
IF-ID-4: virbr1 state: down mac: <filter>
Supported mdraid levels: raid0
Device-1: md0 maj-min: 9:0 type: mdraid level: raid-0 status: active
Info: report: N/A blocks: 891025408 chunk-size: 512k super-blocks: 1.2
Components: Online:
0: sdb1 maj-min: 8:17 size: 425 GiB
1: sdc1 maj-min: 8:33 size: 425 GiB
Local Storage: total: 2.54 TiB used: 918.53 GiB (35.4%)
model: SSD 950 PRO 512GB size: 476.94 GiB block-size: physical: 512 B
rev: 2B0QBXX7 temp: 47.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:9 vendor: Samsung model: SSD 960 EVO 1TB
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 3B7QCXE7
temp: 26.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Crucial model: CT525MX300SSD1
size: 489.05 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: R060 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 860 EVO 500GB
ID-1: / raw-size: 121.64 GiB size: 121.64 GiB (100.00%)
used: 86.82 GiB (71.4%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-2: /boot raw-size: 400 MiB size: 400 MiB (100.00%)
used: 215.5 MiB (53.9%) fs: btrfs dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%)
used: 25.5 MiB (26.6%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /home raw-size: 250.86 GiB size: 250.86 GiB (100.00%)
used: 108.78 GiB (43.4%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-5: /var/log raw-size: 121.64 GiB size: 121.64 GiB (100.00%)
ID-6: /var/tmp raw-size: 121.64 GiB size: 121.64 GiB (100.00%)
ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.62 GiB used: 2.92 GiB (18.7%)
System Temperatures: cpu: 46.0 C mobo: 38.0 C gpu: nvidia temp: 58 C
Fan Speeds (RPM): cpu: 364 fan-2: 326 fan-3: 340 fan-4: 361 fan-6: 344
gpu: nvidia fan: 44%
Power: 12v: N/A 5v: N/A 3.3v: 3.31 vbat: 3.27
Processes: 514 Uptime: 10m wakeups: 0 Memory: 15.62 GiB
used: 4.95 GiB (31.7%) Init: systemd v: 249 tool: systemctl Compilers:
gcc: 11.1.0 alt: 10 clang: 13.0.0 Packages: pacman: 2251 lib: 546
Shell: fish v: 3.3.1 running-in: konsole inxi: 3.3.11
