But its that the only issue? Although it would be nice, I don’t see it as a major problem. ( having to use the terminal to switch to kde-git, as it should not be the flagship main edition of Garuda for obvious reasons. Although I don’t see much issue in “making a checkbox” )
The only issue, is that if one installs dolphin-git from aur, at the next update, all mayhem will break loose ( because aur/dolphin-git uses stable kde, and pacman with chaotic will install all kde-git stack ).
this all comes from the naming. I think something like kde-neonized ( kde-n30n7z3d ?? ), coming from kde neon, which people already understand what it is.
Also, is there really demand for using dolphin-git ( as it was ) in garuda? There is, in my opinion, to much “gits” packages “without any real purpose”.
Depending if people actually like this ( and I have to say that kde git has been very good in terms of stability ), using the repo route, interesting thing can be done, like the:
- [kde-neonized-plasma] ( all kde git stack )
- [kde-neonized-stable-apps] ( kde gear stable apps compiled on top of [kde-neonized-plasma] , which of course need to be above the previous repo. This could be a repo for people that only want bleeding edge desktop/plasma.
The repo scheme could also be used to include any other app ( not under the kde umbrella ) but that breaks when using this stack.
( the package naming would be the same as the “normal ones”, so that people don’t mess up adding this package or removing another, or, mixing packages, as all hell would break loose. the selection would be based on “repo” configs on pacman.conf. Looking at it this way, creating the kde-neonized edition would be almost like just adding the pacman.conf repo config ( and of course, taking care of special cases, like theming or things that change on kde git versions ) )
I think its the most flexible and less error prone way. Of course, I can be wrong, as I never created a distro, much less one with as much use as garuda, so experience here matters, and I have none.
( I hope you read this as someone trying to give ideas, and not just complaining
