Hello. I am a not an complete noob in linux in general. But I am really new to Garuda. I ditched every other linux distro except this one. And I am amazed that the system feels really solid and stable. I didn't have to search a ton of stuff just to get the thing running correctly. I also like the theme a lot. Though I still have windows as my primary desktop system and because I am vey used to it, I want to change it a bit.
I am running dragonized kde desktop version.
I have kind of found solutions for kde, but garuda has different menus so they didn't really apply.
I have two questions, though they are somewhat related.
#1
How do I attach the titlebarmenu(topmenu, menubar?) (File, Edit, View... buttons that apps have etc.) to the actual titlebar on the window.
#2
How to make opened apps appear in the toolmenu(like in windows) instead of them shoving these titlebarmenu buttons, because I have no way of knowing what do I have opened and what not. (thus I open 3 terminals occasionally)
System: Kernel: 5.13.4-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=85c6b4f2-2c87-4216-916b-e06ea2ae41e5
Desktop: KDE Plasma 5.22.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Desktop Mobo: ASUSTeK model: B150M-PLUS v: Rev X.0x serial: <filter>
UEFI-[Legacy]: American Megatrends v: 2003 date: 09/21/2016
Battery: ID-1: hidpp_battery_0 charge: N/A condition: N/A volts: 3.8 min: N/A
model: Logitech G703 LIGHTSPEED Wireless Gaming Mouse w/ HERO type: N/A serial: <filter>
status: Discharging
CPU: Info: Quad Core model: Intel Core i7-7700 bits: 64 type: MT MCP arch: Kaby Lake family: 6
model-id: 9E (158) stepping: 9 microcode: EA cache: L2: 8 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 57600
Speed: 4099 MHz min/max: 800/4200 MHz Core speeds (MHz): 1: 4099 2: 4133 3: 4104 4: 4191
5: 4103 6: 4191 7: 4096 8: 4200
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: NVIDIA GP104 [GeForce GTX 1070] vendor: Micro-Star MSI driver: nvidia v: 470.57.02
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1b81 class-ID: 0300
Display: x11 server: X.Org 1.20.12 compositor: kwin_x11 driver: loaded: nvidia display-ID: :0
Screen-1: 0 s-res: 1920x1080 s-dpi: 95 s-size: 513x292mm (20.2x11.5") s-diag: 590mm (23.2")
Monitor-1: DVI-D-0 res: 1920x1080 hz: 60 dpi: 96 size: 510x290mm (20.1x11.4")
diag: 587mm (23.1")
OpenGL: renderer: NVIDIA GeForce GTX 1070/PCIe/SSE2 v: 4.6.0 NVIDIA 470.57.02
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK driver: snd_hda_intel
v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a170 class-ID: 0403
Device-2: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-3: Generalplus USB Audio Device type: USB driver: hid-generic,snd-usb-audio,usbhid
bus-ID: 1-7:5 chip-ID: 1b3f:2008 class-ID: 0300
Sound Server-1: ALSA v: k5.13.4-zen1-1-zen running: yes
Network: Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel port: f000
bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
Device-2: D-Link System DWA-125 Wireless N 150 Adapter(rev.A1) [Ralink RT3070] type: USB
driver: rt2800usb bus-ID: 1-5:4 chip-ID: 07d1:3c0d class-ID: 0000 serial: <filter>
IF: wlp0s20f0u5 state: up mac: <filter>
Drives: Local Storage: total: 1.02 TiB used: 794.92 GiB (76.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 111.79 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: 10.6
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM010-2EP102 size: 931.51 GiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter>
rev: CC43 scheme: GPT
Partition: ID-1: / raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 23.61 GiB (9.8%) fs: btrfs
dev: /dev/sdb4 maj-min: 8:20
ID-2: /home raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 23.61 GiB (9.8%) fs: btrfs
ID-3: /var/log raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 23.61 GiB (9.8%) fs: btrfs
ID-4: /var/tmp raw-size: 239.99 GiB size: 239.99 GiB (100.00%) used: 23.61 GiB (9.8%) fs: btrfs
ID-1: swap-1 type: zram size: 15.55 GiB used: 0 KiB (0.0%) priority: 100 dev: /dev/zram0
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sdb3
maj-min: 8:19
Sensors: System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: nvidia temp: 50 C
Info: Processes: 287 Uptime: 2h 57m wakeups: 18 Memory: 15.55 GiB used: 4.31 GiB (27.7%)
Init: systemd v: 249 tool: systemctl Compilers: gcc: 11.1.0 alt: 10 clang: 12.0.1 Packages:
pacman: 1480 lib: 473 Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole
inxi: 3.3.05
Sorry if I missed something.
