This problem is happening since I started Linux (in Linux Mint, Ubuntu, Manjaro and still in Garuda). Till now I haven't found a proper resolution. WiFi works fine until sometime, and then the connection drops and I need to disable and re-enable WiFi to make it work again for another while. Few months back I posted here, but the problem I found (may or may not be) that Intel doesn't want to continue developing drivers for linux (especially iwlwifi) (I read it somewhere by someone, I don't remenber where..). Now a days I work with Ethernet cable, got fed up with WiFi.
λ inxi -Fxxxza:
System: Kernel: 5.10.8-112-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=23773b4a-65c6-4ee3-8155-ee0f10eb3c2c rw rootflags=subvol=@ quiet splash
resume=UUID=fe6d3cf6-59f4-4e49-9ee6-b3eeeb6e0d66 loglevel=3
Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Laptop System: HP product: OMEN by HP Laptop v: Type1ProductConfigId
Mobo: HP model: 8257 v: 82.39 serial: <filter> UEFI: Insyde v: F.53 date: 12/12/2019
Battery: ID-1: BAT0 charge: 59.8 Wh condition: 59.8/59.8 Wh (100%) volts: 13.1/11.6
model: Hewlett-Packard Primary type: Li-ion serial: N/A status: Full
CPU: Info: Quad Core model: Intel Core i7-6700HQ bits: 64 type: MT MCP arch: Skylake-S
family: 6 model-id: 5E (94) stepping: 3 microcode: E2 L2 cache: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 41646
Speed: 1484 MHz min/max: 800/3500 MHz Core speeds (MHz): 1: 1484 2: 1511 3: 1522
4: 1481 5: 1756 6: 1454 7: 1437 8: 1459
Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional, IBRS_FW,
Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
Graphics: Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:191b
Device-2: NVIDIA GM107M [GeForce GTX 960M] vendor: Hewlett-Packard driver: nvidia
v: 460.32.03 alternate: nouveau,nvidia_drm bus ID: 01:00.0 chip ID: 10de:139b
Device-3: Cheng Uei Precision Industry (Foxlink) HP Wide Vision HD integrated webcam
type: USB driver: uvcvideo bus ID: 1-4:2 chip ID: 05c8:038e serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: modesetting,nvidia
alternate: fbdev,intel,nouveau,nv,vesa display ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 20.3.3
direct render: Yes
Audio: Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus ID: 00:1f.3 chip ID: 8086:a170
Sound Server: ALSA v: k5.10.8-112-tkg-bmq
Network: Device-1: Intel Wireless 7265 driver: iwlwifi v: kernel port: 4000 bus ID: 08:00.0
chip ID: 8086:095a
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus ID: 09:00.0
chip ID: 10ec:8168
IF-ID-1: anbox0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vethIa9Ep2 state: up speed: 10000 Mbps duplex: full mac: <filter>
Drives: Local Storage: total: 931.51 GiB used: 187.32 GiB (20.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
size: 931.51 GiB block size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
serial: <filter> rev: A3T0
Partition: ID-1: / raw size: 914.14 GiB size: 914.14 GiB (100.00%) used: 187.32 GiB (20.5%)
ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 560 KiB (0.2%)
fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw size: 914.14 GiB size: 914.14 GiB (100.00%) used: 187.32 GiB (20.5%)
ID-4: /var/log raw size: 914.14 GiB size: 914.14 GiB (100.00%)
used: 187.32 GiB (20.5%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw size: 914.14 GiB size: 914.14 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.08 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/sda3 maj-min: 8:3
ID-2: swap-2 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
ID-3: swap-3 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767
dev: /dev/zram7
Sensors: System Temperatures: cpu: 57.0 C mobo: N/A
Info: Processes: 352 Uptime: 4h 07m wakeups: 1769 Memory: 15.52 GiB used: 5.13 GiB (33.1%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.0.1 Packages: pacman: 1902
lib: 538 Shell: fish v: 3.1.2 running in: alacritty inxi: 3.2.01
I'll do a search on out how to deal with iwlwifi.conf.
