update remote fix
eventually unjammed. Now itâs taking too long here. Jammed again.
--2024-05-30 10:12:29-- https://pkgbuild.com/~morganamilo/pacman-static/x86_64/bin/pacman-static
Loaded CA certificate '/etc/ssl/certs/ca-certificates.crt'
Resolving pkgbuild.com (pkgbuild.com)... 2a01:4f8:c2c:51e2::1, 78.46.178.133
Connecting to pkgbuild.com (pkgbuild.com)|2a01:4f8:c2c:51e2::1|:443...
Inxi
Kernel: 6.9.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=b3842975-a07f-4abe-a1f6-66b8fcf79638 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 40.7 Wh (100.0%) condition: 40.7/58.8 Wh (69.2%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 874 high: 900 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 800 4: 900
5: 800 6: 900 7: 900 8: 895 9: 800 10: 899 11: 900 12: 900 bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 550.78
alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 506x285mm (19.92x11.22")
s-diag: 581mm (22.86")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.1.0-arch1.1
device-ID: 8086:9bc4 memory: 7.54 GiB unified: yes
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
UHD Graphics (CML GT2) driver: mesa intel v: 24.1.0-arch1.1
device-ID: 8086:9bc4 surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 550.78
device-ID: 10de:1f15 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 17.0.6 256 bits) driver: mesa llvmpipe v: 24.1.0-arch1.1 (LLVM
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl, snd_soc_avs,
snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.9.2-zen1-1-zen status: kernel-api tools: N/A
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Report: btmgmt ID: hci0 rfk-id: 1 state: up address: <filter> bt-v: 5.2
Local Storage: total: 6.83 TiB used: 822.92 GiB (11.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 42.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1023 scheme: GPT
ID-1: / raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
used: 16.05 GiB (2.1%) fs: btrfs dev: /dev/nvme1n1p1 maj-min: 259:3
ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p3 maj-min: 259:5
ID-3: /home raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-4: /var/log raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-5: /var/tmp raw-size: 781.15 GiB size: 781.15 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 78.2 MiB (0.5%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 56.0 C pch: 66.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 5.36 GiB (34.7%)
Processes: 354 Power: uptime: 44m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.14 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1317 libs: 376 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-05-30
Last full system update: 2024-05-30 â»
The command above is running at an absolute snail pace with various connection timeouts
Connecting to pkgbuild.com (pkgbuild.com)|2a01:4f8:c2c:51e2::1|:443... failed: Connection timed out.
Connecting to pkgbuild.com (pkgbuild.com)|78.46.178.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 4606712 (4.4M) [application/octet-stream]
Saving to: â/tmp/tmp.U1KPsG7PjKâ
/tmp/tmp.U1KPsG7PjK 100%[=========================================>] 4.39M 1.03MB/s in 4.3s
2024-05-30 10:14:50 (1.03 MB/s) - â/tmp/tmp.U1KPsG7PjKâ saved [4606712/4606712]
.--. Pacman v6.0.1 - libalpm v13.0.1
/ _.-' .-. .-. .-. Copyright (C) 2006-2021 Pacman Development Team
\ '-. '-' '-' '-' Copyright (C) 2002-2006 Judd Vinet
This program may be freely redistributed under
the terms of the GNU General Public License.
--2024-05-30 10:14:50-- https://gitlab.com/garuda-linux/tools/garuda-tools/-/raw/master/data/pacman-default.conf
Resolving gitlab.com (gitlab.com)... 2606:4700:90:0:f22e:fbec:5bed:a9b9, 172.65.251.78
Connecting to gitlab.com (gitlab.com)|2606:4700:90:0:f22e:fbec:5bed:a9b9|:443... connected.
Length: 2514 (2.5K) [text/plain]
Saving to: â/etc/pacman.confâ
/etc/pacman.conf 100%[=========================================>] 2.46K --.-KB/s in 0s
2024-05-30 10:14:50 (5.31 MB/s) - â/etc/pacman.confâ saved [2514/2514]
--2024-05-30 10:14:50-- https://archlinux.org/mirrorlist/all/
Resolving archlinux.org (archlinux.org)... 2a01:4f9:c010:6b1f::1, 95.217.163.246
Connecting to archlinux.org (archlinux.org)|2a01:4f9:c010:6b1f::1|:443... failed: Connection timed out.
Connecting to archlinux.org (archlinux.org)|95.217.163.246|:443... connected.
Length: 55456 (54K) [text/plain]
Saving to: â/etc/pacman.d/mirrorlistâ
/etc/pacman.d/mirrorlist 100%[=========================================>] 54.16K 145KB/s in 0.4s
2024-05-30 10:17:05 (145 KB/s) - â/etc/pacman.d/mirrorlistâ saved [55456/55456]
--2024-05-30 10:17:05-- https://aur.chaotic.cx/mirrorlist.txt
Resolving aur.chaotic.cx (aur.chaotic.cx)... 2606:50c0:8002::153, 2606:50c0:8003::153, 2606:50c0:8000::153, ...
Connecting to aur.chaotic.cx (aur.chaotic.cx)|2606:50c0:8002::153|:443... failed: Connection timed out.
Connecting to aur.chaotic.cx (aur.chaotic.cx)|2606:50c0:8003::153|:443...
It eventually completed.
Re-running it jams all over again, so I still cannot use the Setup Assistant.
Another detail I found: in the console, the start logo is the ASCII logo, not the new graphical one.
