Hello.
I am using Garuda Linux on another laptop for a while now and just bought this new one, and immediately installed garuda linux with dual boot windows 11.
There have been some stutters but all around its same as last installation, except for the wifi.
Wifi seems to randomly disconnect by itself. (I confirmed that it is not the modem's fault because my old laptop is sitting right beside this one and it is working perfectly.) Also the download speeds in this laptop are not that great. i have run Speed tests on both laptops from same spot but the other one always gets 45 mbps while this one gets 20 mbps. Download speeds are abysmal. They barely went above 200kbps in the last file i downloaded, while the same file from the old laptop gave about 1mbps- 2mbps average.
the only difference i could find between the two laptops regarding the wifi was the modem model, the old laptop has intel AX200 and newer one has Intel AX 201. i think the issue might be solved by reinstalling the driver because the windows 11 gives pretty good speeds from the same spot.
i found my relevant drivers from intel's website https://wireless.wiki.kernel.org/_media/en/users/drivers/iwlwifi/iwlwifi-qu-48.13675109.0.tgz.
i dont know and could not find a way to install the driver in linux.
â•─chris@Chris in ~
╰─λ inxi -Faz
System: Kernel: 5.14.9-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=873c951f-daf4-4fad-aecc-0961323840e3
Desktop: KDE Plasma 5.22.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Machine: Type: Laptop System: Micro-Star product: GF63 Thin 10SC v: REV:1.0 serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: Micro-Star model: MS-16R5 v: REV:1.0 serial: <filter> UEFI: American Megatrends
v: E16R5IMS.103 date: 05/14/2021
Battery: ID-1: BAT1 charge: 28.1 Wh (56.5%) condition: 49.7/51.3 Wh (96.9%) volts: 11.7 min: 11.4
model: MSI BIF0_9 type: Li-ion serial: N/A status: Unknown
CPU: Info: 6-Core model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake family: 6
model-id: A5 (165) stepping: 2 microcode: EA cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 4801 MHz min/max: 800/5000 MHz Core speeds (MHz): 1: 4801 2: 4801 3: 4800 4: 4801
5: 4801 6: 4800 7: 4800 8: 4798 9: 4801 10: 4852 11: 4798 12: 4551
Graphics: Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI driver: i915 v: kernel
bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: Micro-Star MSI driver: nvidia
v: 470.74 alternate: nouveau,nvidia_drm bus-ID: 02:00.0 chip-ID: 10de:1f9d class-ID: 0302
Display: x11 server: X.Org 1.20.13 compositor: kwin_x11 driver: loaded: modesetting
unloaded: nvidia display-ID: :0 screens: 1
Monitor-1: eDP-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x193mm (13.5x7.6") diag: 394mm (15.5")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.2.3 direct render: Yes
Audio: Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Sound Server-1: ALSA v: k5.14.9-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.38 running: yes
Network: Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
Bluetooth: Device-1: Intel AX201 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-14:3
chip-ID: 8087:0026 class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 5 state: up address: <filter>
Drives: Local Storage: total: 1.14 TiB used: 303.64 GiB (26.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3256B-AI1 size: 238.47 GiB
rev: EDFK0S03 temp: 50.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172 size: 931.51 GiB
serial: <filter> rev: 0001 scheme: GPT
Partition: ID-1: / raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 19.75 GiB (19.7%) fs: btrfs
ID-2: /boot/efi raw-size: 300 MiB size: 296 MiB (98.67%) used: 27.8 MiB (9.4%) fs: vfat
ID-3: /home raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 19.75 GiB (19.7%) fs: btrfs
ID-4: /var/log raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 19.75 GiB (19.7%)
ID-5: /var/tmp raw-size: 100.08 GiB size: 100.08 GiB (100.00%) used: 19.75 GiB (19.7%)
ID-1: swap-1 type: zram size: 7.59 GiB used: 815 MiB (10.5%) priority: 100 dev: /dev/zram0
Sensors: System Temperatures: cpu: 59.0 C mobo: N/A
Info: Processes: 405 Uptime: 12h 39m wakeups: 3 Memory: 7.59 GiB used: 6.25 GiB (82.4%) Init: systemd
v: 249 tool: systemctl Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: pacman: 1542 lib: 486
Shell: fish v: 3.3.1 default: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
thanks for reading and if you have any suggestions, please do tell.
