It's been like this from time to time, im just trying to casuually run npx create-react-app or npm install {module or anything} and it almost always fails, and no i do not use proxies and it can't be my network as when i tried switching back to windows, these commands work properly while still in the same network.
No pictures from terminal output.
The solution is in the error message.
I close the topic.
Read
please.
Check if network is active.
Maybe another moderator will open the topic again, although it will fall into unsupported software.
Don’t be that guy:
Hi @alphaxexia , copy that terminal output and paste here.
Just pm any moderator/ admin, if you want thread to be reopened.
And btw, you forgot sudo before npm
You have to use sudo before npm before installing any thing through it.
