Hi All,
I downloaded Garuda KDE both normal Dragonized and the BlackArch versions, but failed to install both of them in my laptop. I have attached screenshot.
Steps Followed:
Download iso using torrent download
Write to USB Flash (32GB) drive using Rufus
Booted through USB mode
Tried both but same results
i. Select Boot using open source drivers
ii. Select Boot allowing proprietary drivers (NVIDIA)
Problem:
After booting just few white lines kept flashing on top of the screen leaving rest of the screen black, nothing visible.
System Specs:
Dell Inspiron15 7000
Intel i7-6700HQ 2.60GHz processor
16GB DDR4 RAM
500 GB SSD at M.2 slot
1 TB HDD at SATA slot
NVIDIA GeForce GTX 960M 4 GB Graphics
Intel HD 530 Graphics
My system works without any issues in Windows.
Any help? Thank you in advance
Regards,
Abhishek Mitra
SGS
20 March 2021 21:40
3
Please no picture from “Black Screen”.
AbhishekMitra:
using Rufus
Use dd or balena etcher or Ventoy.
Read
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It's especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy yo…
please
and post
inxi -Fxxxza
as text!
and
SGS
20 March 2021 21:44
4
Ahh, then it is easy to solve your problem
OT
My car runs well on petrol but fails when I fill up with diesel.
Specifically against the Garuda wiki which states… -
“Dont use Rufus to flash the iso to USB”
Tried with etcher, unfortunately same problem. Tried with Ventoy as well, same problem.
Tried Etecher and Ventoy, same problem.
By saying this "My system works without any issues in Windows." I wanted to mean that I do not have any hardware issues
Etcher and ventoy did not work either
SGS
20 March 2021 23:27
9
SGS:
and post
inxi -Fxxxza
as text!
Start reading too.
In BIOS remove secure and fastboot. Maybe root user is needed for that.
Hello. Welcome to the community
Here how I do with when I'm flashing my flash drive to become Live USB to install Garuda.
Download the .iso
Download the sha256.checksum
Make new folder and put it both inside it
Run Balena Etcher to flash my flash drive
Follow the directions from Balena Etcher
After done flashing, I restart my laptop and booting from my Live USB.
Choose the open source/free driver
I hope it help. Good luck
Hi,
I tried the exact same steps but it did not solve the problem.
Thanks,
Abhishek
I read as well but I don't have inxi since I am on windows Let me know what specific details are you looking for, I will try my best to post them here.
However your suggestion did not work, I checked the BIOS secure and fastboot options are already disabled.
Thanks,
Abhishek
Ok, one suggestion I have, is using RPi-Imager. It has worked for me in the past, when Balena didn't and is available for windows, from
Steps I took
Select Choose OS
Scroll down to Erase
wipe your USB drive.
Choose your ISO from Choose OS
selecting Use Custom
choosing your Garuda ISO and write it - then try installing it.
It is the only thing left for me, but the far better and far more knowledgeable brains here, may have other ideas for you.
Maybe try suse studio image writher.
sunda
21 March 2021 14:21
15
Drag 'n' drop und gut ist.
Hi,
I tried this, but it did not solve the problem.
Thanks,
Abhishek
Could you please share some more details?
Have you tried a different USB pendrive? This has resolved some problems encountered by others.
Tied this, but it did not solve the problem
Not yet, but I am able to load Manjaro with the same pen drive without any issues. Does Garuda allow network boot?
I have a Dell Inspiron15 7548. . . I'm going to try and install right now and see if I can recreate the problem.
Dragonized first.
Edit - I don't have nvidia graphics though. Either way, I'll give it a go.
FWIW, I generally use popsicle to flash usb drives. Either way, I'm about to give it a go.
