I love this distro but i would like to find another one that’s easier to use and maybe I will come back later with more experience in what I’m actually doing my system is a UEFI I’m using a past topic that was closed as a reference as to what to include
╭─bam2126@bam2126 in ~
╰─λ inxi -Fxxxza
cat /etc/fstab
sudo parted -l
System: Kernel: 5.11.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/timeshift-btrfs/snapshots/2021-03-15_19-00-01/@/boot/vmlinuz-linux-zen
root=UUID=2a81d935-7a85-4588-863a-28db8d261f8f quiet splash rd.udev.log_priority=3
rootflags=defaults,noatime,space_cache,autodefrag,compress=zstd,subvol=timeshift-btrfs/snapshots/2021-03-15_19-00-01/@
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Desktop Mobo: Micro-Star model: MAG B550 TOMAHAWK (MS-7C91) v: 2.0 serial: <filter>
UEFI: American Megatrends LLC. v: A.61 date: 02/26/2021
CPU: Info: 6-Core model: AMD Ryzen 5 3600X bits: 64 type: MT MCP arch: Zen 2 family: 17 (23)
model-id: 71 (113) stepping: N/A microcode: 8701021 L2 cache: 3 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 91200
Speed: 3597 MHz min/max: 2200/4542 MHz boost: enabled Core speeds (MHz): 1: 3597 2: 3599
3: 3595 4: 3608 5: 4236 6: 4110 7: 4358 8: 4338 9: 4053 10: 3603 11: 3609 12: 3600
mitigation: Full AMD retpoline, IBPB: conditional, STIBP: conditional, RSB filling
Graphics: Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: Micro-Star MSI driver: nouveau v: kernel
bus ID: 2b:00.0 chip ID: 10de:2484 class ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: modesetting,nouveau
alternate: fbdev,nv,vesa display ID: :0 screens: 1
Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
Monitor-1: HDMI-1 res: 3840x2160 hz: 60 dpi: 61 size: 1600x900mm (63.0x35.4")
diag: 1836mm (72.3")
OpenGL: renderer: llvmpipe (LLVM 11.1.0 256 bits) v: 4.5 Mesa 20.3.4 compat-v: 3.1
direct render: Yes
Audio: Device-1: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus ID: 2b:00.1
chip ID: 10de:228b class ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus ID: 2d:00.4 chip ID: 1022:1487 class ID: 0403
Sound Server: ALSA v: k5.11.1-zen1-1-zen
Network: Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel bus ID: 04:00.0 chip ID: 8086:2723
class ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Micro-Star MSI
driver: r8169 v: kernel port: e000 bus ID: 05:00.0 chip ID: 10ec:8168 class ID: 0200
Device-3: Realtek RTL8125 2.5GbE vendor: Micro-Star MSI driver: r8169 v: kernel port: d000
bus ID: 2a:00.0 chip ID: 10ec:8125 class ID: 0200
IF: enp42s0 state: down mac: <filter>
Bluetooth: Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus ID: 1-2.3:6
chip ID: 8087:0029 class ID: e001
Message: Required tool hciconfig not installed. Check --recommends
Drives: Local Storage: total: 931.51 GiB used: 32.61 GiB (3.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G size: 931.51 GiB
block size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD
serial: <filter> rev: S5Z42105 temp: 28.9 C scheme: GPT
Partition: ID-1: / raw size: 186.26 GiB size: 186.26 GiB (100.00%) used: 32.61 GiB (17.5%) fs: btrfs
ID-2: /boot/efi raw size: 500 MiB size: 499 MiB (99.80%) used: 560 KiB (0.1%) fs: vfat
ID-3: /home raw size: 186.26 GiB size: 186.26 GiB (100.00%) used: 32.61 GiB (17.5%) fs: btrfs
ID-4: /var/log raw size: 186.26 GiB size: 186.26 GiB (100.00%) used: 32.61 GiB (17.5%)
ID-5: /var/tmp raw size: 186.26 GiB size: 186.26 GiB (100.00%) used: 32.61 GiB (17.5%)
ID-1: swap-1 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-2: swap-2 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-3: swap-3 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-4: swap-4 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-5: swap-5 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-6: swap-6 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-7: swap-7 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-8: swap-8 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-9: swap-9 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-10: swap-10 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-11: swap-11 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-12: swap-12 type: zram size: 2.61 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 57.4 C mobo: N/A
Fan Speeds (RPM): fan-2: 849 fan-3: 959 fan-4: 954 fan-5: 936
Info: Processes: 327 Uptime: 1d 2h 18m wakeups: 0 Memory: 31.34 GiB used: 5.11 GiB (16.3%)
Init: systemd v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1331 lib: 411
Shell: fish v: 3.1.2 running in: konsole inxi: 3.3.01
# <file system> <mount point> <type> <options> <dump> <pass>
UUID=7FCB-1ADC /boot/efi vfat umask=0077 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f / btrfs subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /home btrfs subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /root btrfs subvol=@root,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /srv btrfs subvol=@srv,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /var/cache btrfs subvol=@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /var/log btrfs subvol=@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
UUID=2a81d935-7a85-4588-863a-28db8d261f8f /var/tmp btrfs subvol=@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
[sudo] password for bam2126:
sudo: timed out reading password
sudo: a password is required
I would put a screenshot of my partitions but the screenshot wouldn’t save
thanks for any help that might come my way but thanks to the people who had the patience to put up with my dumbass on past topics this mainly a decision for better support for my parts driver wise
I just wasn't up to the challenge just yet
