I had issues with all the Garuda Dragonized ISOs I tried
I have Ventoy configured on my USB, so I don’t have to flash the ISOs every time.
1) I tried this ISO first to have the latest packages installed: https://iso.builds.garudalinux.org/iso/garuda/dr460nized/240726/
And the ISO didn’t boot. It just got stuck at ‘Starting systemd-udevd version ****-arch’
2) Then I decided to try the linux-lts ISO, thinking it might be the Zen kernel’s issue:
The ISO booted, but the Calamares installer didn’t continue. It showed some errors like:
Can’t load modules due to distribution’s bad configuration. Modules not loaded are,
user@user
3) To give a last shot, I tried the garuda-dr460nized-linux-zen-240428.iso from the website itself.
The ISO booted, and the installation started, but around 90% through the installation, the installation failed with the error:
The bootloader could not be installed. The installation command
grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Garuda --force
returned error code 1.
I then had to chroot into the installation and run this command to install grub:
To note:
Interestingly, this command didn’t work:
And returned with the error:
Could not delete variable: No space left on device.
grub-install: error: efibootmgr failed to register the boot entry: Block device required.
I don’t know if everyone faces these issues or if they are specific to my device.
My garuda-inxi:
Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: Acer product: Swift SF314-43 v: V1.04
Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.04
date: 07/28/2021
ID-1: BAT1 charge: 4.9 Wh (12.5%) condition: 39.1/53.2 Wh (73.4%)
volts: 12.0 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter>
status: charging
Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A
status: N/A
Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP
process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608102
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1111 high: 1960 min/max: 400/4056 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 1397 3: 400
4: 1397 5: 400 6: 1397 7: 400 8: 1397 9: 400 10: 1397 11: 1397 12: 1960
bogomips: 50305
Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu
v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie:
active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
class-ID: 0300 temp: 47.0 C
Device-2: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:a094
class-ID: 0e02
Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
renoir LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:164c
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.4-arch1.2
device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: AMD Renoir Radeon High Definition Audio
vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor
vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel
alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s
lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: enp3s0f3u1c4i2 state: up speed: N/A duplex: N/A mac: <filter>
Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 04ca:3802
Local Storage: total: 476.94 GiB used: 144.3 GiB (30.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1
lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 43.9 C
ID-1: / raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 6.96 GiB (10.8%)
ID-2: /home raw-size: 64 GiB size: 64 GiB (100.00%) used: 312.3 MiB (0.5%)
ID-3: /var/log raw-size: 64.41 GiB size: 64.41 GiB (100.00%)
used: 6.96 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-4: /var/tmp raw-size: 64.41 GiB size: 64.41 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.11 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 57.0 C mobo: 36.0 C gpu: amdgpu temp: 48.0 C
Memory: total: 8 GiB note: est. available: 7.11 GiB used: 4.71 GiB (66.3%)
Processes: 391 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 2.83 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1266 libs: 366 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1
System install date:     2024-07-26
Last full system update: 2024-07-27
1 is a known problems of development builds.
2 I don’t know. I think it should work, but definitely 3 should, because all those builds are being used in new installations.
One thing that looks strange to me is that I can’t see your ESP mounted to /boot/efi there.
Maybe you should investigate the status of you ESP, which is needed exactly when you get those GRUB errors.
So now we know the root cause :wink:
Well, this issue that I opened here, only came up after I wrongly edited the fstab. I don’t think this caused the installation error.
Dump files accumulating in the /sys/firmware/efi/efivars should have contributed to the observed problem (referenced as point 3 in the original post).”
Yeah I don’t think it’s the entire cause. I also had issues booting dev builds and even from the website itself from Ventoy.
I was only able to get dr460nized from the website to boot after updating Ventoy to the latest version, dev builds still won’t boot as you said it’s a known issue.
It isn’t just Austin with the issue. :slightly_smiling_face:
I believe the error 3) was due to the dump files:
https://wiki.archlinux.org/title/Unified_Extensible_Firmware_Interface#Userspace_tools_are_unable_to_modify_UEFI_variable_data
Then, probably, when using no-nvram option and succeding (avoiding the step above) the fstab was updated and the other problem appeared.
But it doesn’t really matter now that everything is solved … :wink:
Dev builds should be used only by devs, testers, or anybody else aware that they are doing it at their own risk.
To clarify: it was actually my mistake, I edited the fstab wrongly.
Yes, sure, it was written in the other thread :smiling_face:
