I have been encountering this boot failure, ever since I edited my fstab to add some partitions to automount.
I even tried reformatting the ESP partition and reinstalling grub from a live USB.
This again happened here, too.
# <file system> <mount point> <type> <options> <dump> <pass>
#UUID=6C5E-CE44 /boot/efi vfat default,umask=0077 0 2
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f / btrfs subvol=/@,defaults,noatime,compress=zstd 0 0
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /root btrfs subvol=/@root,defaults,noatime,compress=zstd 0 0
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /srv btrfs subvol=/@srv,defaults,noatime,compress=zstd 0 0
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /var/cache btrfs subvol=/@cache,defaults,noatime,compress=zstd 0 0
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /var/log btrfs subvol=/@log,defaults,noatime,compress=zstd 0 0
UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /var/tmp btrfs subvol=/@tmp,defaults,noatime,compress=zstd 0 0
UUID=9fa0b5ef-ad74-4a79-b3c0-4d10b51c9d3a /home btrfs subvol=@home,defaults,noatime,compress=zstd 0 0
tmpfs /tmp tmpfs defaults,noatime,mode=1777 0 0
UUID=586e1a3e-80c3-4057-81b6-bbfe7662c6ff /mnt/Linux_Data ext4 defaults,noatime 0 2
UUID=92d6a935-e46e-46fb-9e53-9b39bce48e6a /mnt/Storage ext4 defaults,noatime 0 2
I have been commenting out the ESP file system in the fstab to be able to boot without the above error.
> lsblk -f
NAME FSTYPE FSVER LABEL UUID FSAVAIL FSUSE% MOUNTPOINTS
zram0 [SWAP]
nvme0n1
├─nvme0n1p1 vfat FAT32 6C5E-CE44
├─nvme0n1p2 btrfs Garuda_Linux ad7b1d9f-bf7e-46fc-b711-fecabd29e65f /var/log
├─nvme0n1p3 btrfs Home 9fa0b5ef-ad74-4a79-b3c0-4d10b51c9d3a 61.7G 1% /home
├─nvme0n1p4 ext4 1.0 Linux_Data 586e1a3e-80c3-4057-81b6-bbfe7662c6ff 43.8G 25% /mnt/Linux_Data
└─nvme0n1p5 ext4 1.0 Storage 92d6a935-e46e-46fb-9e53-9b39bce48e6a 142.6G 44% /mnt/Storage
System: Kernel: 6.10.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1 clocksource: hpet avail: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=ad7b1d9f-bf7e-46fc-b711-fecabd29e65f rw rootflags=subvol=@ quiet loglevel=3 ibt=off Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Garuda base: Arch Linux Machine: Type: Laptop System: Acer product: Swift SF314-43 v: V1.04 serial: <superuser required> Mobo: LN model: Sake_CA v: V1.04 serial: <superuser required> part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 1.04 date: 07/28/2021 Battery: ID-1: BAT1 charge: 4.9 Wh (12.5%) condition: 39.1/53.2 Wh (73.4%) volts: 12.0 min: 11.6 model: COSMX AP20CBL type: Li-ion serial: <filter> status: charging Device-1: apple_mfi_fastcharge model: N/A serial: N/A charge: N/A status: N/A CPU: Info: model: AMD Ryzen 5 5500U with Radeon Graphics bits: 64 type: MT MCP arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23) model-id: 0x68 (104) stepping: 1 microcode: 0x8608102 Topology: cpus: 1x cores: 6 tpc: 2 threads: 12 smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB L3: 8 MiB desc: 2x4 MiB Speed (MHz): avg: 1111 high: 1960 min/max: 400/4056 scaling: driver: amd-pstate-epp governor: powersave cores: 1: 1397 2: 1397 3: 400 4: 1397 5: 400 6: 1397 7: 400 8: 1397 9: 400 10: 1397 11: 1397 12: 1960 bogomips: 50305 Flags: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm Vulnerabilities: <filter> Graphics: Device-1: AMD Lucienne vendor: Acer Incorporated ALI driver: amdgpu v: kernel arch: GCN-5 code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c class-ID: 0300 temp: 47.0 C Device-2: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 0408:a094 class-ID: 0e02 Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.1 compositor: kwin_wayland driver: X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi gpu: amdgpu display-ID: 0 Monitor-1: eDP-1 res: 1536x864 size: N/A modes: N/A API: EGL v: 1.5 hw: drv: amd radeonsi platforms: device: 0 drv: radeonsi device: 1 drv: swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi inactive: gbm API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2 glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi renoir LLVM 18.1.8 DRM 3.57 6.10.1-zen1-1-zen) device-ID: 1002:164c memory: 500 MiB unified: no display-ID: :1.0 API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.1.4-arch1.2 device-ID: 1002:164c surfaces: xcb,xlib,wayland device: 1 type: cpu name: llvmpipe (LLVM 18.1.8 256 bits) driver: mesa llvmpipe v: 24.1.4-arch1.2 (LLVM 18.1.8) device-ID: 10005:0000 surfaces: xcb,xlib,wayland Audio: Device-1: AMD Renoir Radeon High Definition Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403 Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Acer Incorporated ALI driver: snd_rn_pci_acp3x v: kernel alternate: snd_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps, snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480 Device-3: AMD Family 17h/19h HD Audio vendor: Acer Incorporated ALI driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403 API: ALSA v: k6.10.1-zen1-1-zen status: kernel-api tools: N/A Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse status: active 2: wireplumber status: active 3: pipewire-alsa type: plugin 4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl Network: Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter vendor: Lite-On driver: mt7921e v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280 IF: wlp1s0 state: up mac: <filter> IF-ID-1: enp3s0f3u1c4i2 state: up speed: N/A duplex: N/A mac: <filter> Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant Bluetooth: Device-1: Lite-On Wireless_Device driver: btusb v: 0.8 type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-4:4 chip-ID: 04ca:3802 class-ID: e001 serial: <filter> Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.2 lmp-v: 11 status: discoverable: no pairing: no class-ID: 6c010c Drives: Local Storage: total: 476.94 GiB used: 144.3 GiB (30.3%) SMART Message: Unable to run smartctl. Root privileges required. ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: OM8PDP3512B-AA1 size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: EDFK0S03 temp: 43.9 C scheme: GPT Partition: ID-1: / raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 6.96 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 ID-2: /home raw-size: 64 GiB size: 64 GiB (100.00%) used: 312.3 MiB (0.5%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3 ID-3: /var/log raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 6.96 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 ID-4: /var/tmp raw-size: 64.41 GiB size: 64.41 GiB (100.00%) used: 6.96 GiB (10.8%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2 Swap: Kernel: swappiness: 133 (default 60) cache-pressure: 100 (default) zswap: no ID-1: swap-1 type: zram size: 7.11 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0 Sensors: System Temperatures: cpu: 57.0 C mobo: 36.0 C gpu: amdgpu temp: 48.0 C Fan Speeds (rpm): N/A Info: Memory: total: 8 GiB note: est. available: 7.11 GiB used: 4.71 GiB (66.3%) Processes: 391 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 2.83 GiB services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical tool: systemctl Packages: pm: pacman pkgs: 1266 libs: 366 tools: octopi,paru pm: flatpak pkgs: 0 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35 Garuda (2.6.26-1): System install date: 2024-07-26 Last full system update: 2024-07-27 Is partially upgraded: No Relevant software: snapper NetworkManager dracut Windows dual boot: No/Undetected Failed units:
