I downloaded GE-Proton10-20-rtsp19 so Vrchat will work , where do i move the folder to?
Hi Everyone,
I did download GE-Proton10-20-rtsp19 and unpacked the tar.gz File
so i got GE-Proton10-20-rtsp19 as a folder now.
I however cant find out where to move the folder so the GE-Proton10-20-rtsp19
will show in Steam under compatibility so i can choose it to make VRChat run propperly.
I did find a folder called .local/share/Steam/compatibilitytools.d/ but moving the folder there did not show the GE-Proton10-20-rtsp19 in the compatibility menu sadly.
I as well did try to move the GE-Proton10-20-rtsp19 Folder in
/home/shiny/.local/share/Steam/steamapps/common/ but sadly as well without
success.
Would be super if one of you would know where i need to move the folder so it works :smiley:
Many Thanks in Advance :smiley:
Please post your garuda-inxi as requested by the template.
Why? GE_Proton10_20_rtsp19-2 (proton-ge-custom-rtsp-bin) is available as a binary in the AUR. You can install it with:
paru -S proton-ge-custom-rtsp-bin
hi,
please post all time your garuda-inxi again with a new topic.
What is wrong if you just install VRChat with Steam? Normally Steam select the right packages for you to install to get it running .
Just as a look into the protondb website. 2 Post about rtsp versions arent good in performance so why you want this version?
We dont know which VR your using maybe there a issue with the right driver or missing dependencies ?
Hi Duke,
Yes the video & Song players are the reason why i did try out the latest GE-Proton-10-20-rtsp-19 but when i tryed not only did the song & video player still not work and the selfy Cam tracking ( what is at the only my only way of moving my arms and upper boday and such around in VRC) did not work neither ( so far it does not work with any Proton version though, but i as well could not even went to other worlds to meet friends. VRChat froze and had a black screen whenever i tryed.
For everyone who might have the same Issue ,
i use the Protogen 10.0-2 (beta) at the moment
Selfy Cam tracking - not working
World joining - working
Vid players - now and then working
copying and pasting youtube urls : not working
with the issues that Cam tracking is not working at all and Video / song players are only working now and then ( what is especially strange to me since why would it not work for the first couple of Youtube videos , then all of a sudden work for one and then again does not work for the next couple more videos ) . Joining Friends in other VR Worlds however luckily works again in this proton version.
But i am trying around to find a version that at least give me the Song Video players back
so i can see and listen when friends put Youtube Song and youtube Videos on the Players and such.
What is as well super strange , it seems that i cant copy and paste
anything into VRChat anymore. I noticed when i tryed to copy and paste a youtube
song in to see if the player would work shrugs
Here is my latest garuda-inxi :
Kernel: 6.17.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=6e8735d8-1e93-4551-9fd5-ed882145d94c rw rootflags=subvol=@
quiet resume=UUID=ce075bb5-91be-4872-8c26-780ad4d5fb6b loglevel=3
Desktop: KDE Plasma v: 6.5.1 tk: Qt v: N/A info: frameworks v: 6.19.0
Type: Desktop Mobo: Micro-Star model: B550M PRO-VDH WIFI (MS-7C95) v: 1.0
Megatrends LLC. v: 2.60 date: 01/14/2021
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
model-id: 0x21 (33) stepping: 0 microcode: 0xA20102E
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2
smt: enabled cache: L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB
desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 4066 min/max: 567/4955 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 4066 2: 4066 3: 4066
4: 4066 5: 4066 6: 4066 7: 4066 8: 4066 9: 4066 10: 4066 11: 4066 12: 4066
13: 4066 14: 4066 15: 4066 16: 4066 17: 4066 18: 4066 19: 4066 20: 4066
21: 4066 22: 4066 23: 4066 24: 4066 bogomips: 177590
Type: gather_data_sampling status: Not affected
Type: ghostwrite status: Not affected
Type: indirect_target_selection status: Not affected
Type: old_microcode status: Not affected
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow mitigation: Safe RET
Type: spectre_v2 mitigation: Retpolines; IBPB: conditional; IBRS_FW;
STIBP: always-on; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Type: tsa mitigation: Clear CPU buffers
Type: vmscape mitigation: IBPB before exit to userspace
Device-1: NVIDIA GA102 [GeForce RTX 3090] vendor: ASUSTeK driver: nvidia
v: 580.95.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-08; EOL~2026-12-xx) arch: Ampere code: GAxxx
lanes: 16 ports: active: HDMI-A-2 empty: DP-1, DP-2, DP-3, HDMI-A-1
bus-ID: 2b:00.0 chip-ID: 10de:2204 class-ID: 0300
Device-2: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2
chip-ID: 046d:0892 class-ID: 0102 serial: <filter>
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: 0
Monitor-1: HDMI-A-2 model: Acer S242HL serial: <filter> built: 2017 res:
mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 92 gamma: 1.2
max: 1920x1080 min: 640x480
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 580.95.05
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3090/PCIe/SSE2
memory: 23.44 GiB display-ID: :1.0
API: Vulkan v: 1.4.328 layers: 15 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3090 driver: nvidia v: 580.95.05
device-ID: 10de:2204 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.4 256 bits) driver: mesa llvmpipe v: 25.2.6-arch1.1 (LLVM
21.1.4) device-ID: 10005:0000 surfaces: N/A
de: kscreen-console,kscreen-doctor gpu: corectrl,nvidia-smi wl: wayland-info
Device-1: NVIDIA GA102 High Definition Audio vendor: ASUSTeK
bus-ID: 2b:00.1 chip-ID: 10de:1aef class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 2d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech C920 HD Pro Webcam driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.17.6-zen1-1-zen status: kernel-api with: aoss
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 29:00.0
IF: enp42s0 state: up speed: 100 Mbps duplex: full mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:9 chip-ID: 8087:0aa7
Local Storage: total: 4.55 TiB used: 60.85 GiB (1.3%)
fw-rev: 2B2QEXM7 temp: 49.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Toshiba model: HDWD240 size: 3.64 TiB
block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s tech: HDD
rpm: 5400 serial: <filter> fw-rev: 0A scheme: GPT
ID-1: / raw-size: 200 GiB size: 200 GiB (100.00%) used: 26.42 GiB (13.2%)
used: 664 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 714.51 GiB size: 714.51 GiB (100.00%)
used: 34.43 GiB (4.8%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 200 GiB size: 200 GiB (100.00%)
used: 26.42 GiB (13.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-5: /var/tmp raw-size: 200 GiB size: 200 GiB (100.00%)
ID-1: swap-1 type: zram size: 62.71 GiB used: 348 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
System Temperatures: cpu: 51.2 C mobo: N/A
Repos:
Packages: 2002 pm: pacman pkgs: 1994 libs: 534
tools: gnome-software,octopi,paru pm: snap pkgs: 8
Active pacman repo servers in: /etc/pacman.d/chaotic-mirrorlist
1: https://cdn-mirror.chaotic.cx/$repo/$arch
2: https://geo-mirror.chaotic.cx/$repo/$arch
3: https://br-mirror.chaotic.cx/$repo/$arch
4: https://cl-mirror.chaotic.cx/$repo/$arch
5: https://cl-2-mirror.chaotic.cx/$repo/$arch
6: https://de-2-mirror.chaotic.cx/$repo/$arch
7: https://de-4-mirror.chaotic.cx/$repo/$arch
8: https://fr-mirror.chaotic.cx/$repo/$arch
9: https://gb-mirror.chaotic.cx/$repo/$arch
10: https://gr-mirror.chaotic.cx/$repo/$arch
11: https://in-mirror.chaotic.cx/$repo/$arch
12: https://in-2-mirror.chaotic.cx/$repo/$arch
13: https://in-4-mirror.chaotic.cx/$repo/$arch
14: https://kr-mirror.chaotic.cx/$repo/$arch
15: https://es-mirror.chaotic.cx/$repo/$arch
16: https://es-2-mirror.chaotic.cx/$repo/$arch
17: https://us-mi-mirror.chaotic.cx/$repo/$arch
18: https://us-ut-mirror.chaotic.cx/$repo/$arch
19: https://vn-mirror.chaotic.cx/$repo/$arch
Active pacman repo servers in: /etc/pacman.d/mirrorlist
1: https://mirror.osbeck.com/archlinux/$repo/os/$arch
2: https://de.arch.niranjan.co/$repo/os/$arch
3: http://mirror.ubrco.de/archlinux/$repo/os/$arch
4: http://archlinux.uk.mirror.allworldit.com/archlinux/$repo/os/$arch
5: https://mirrors.teamcloud.am/archlinux/$repo/os/$arch
6: https://theswissbay.ch/archlinux/$repo/os/$arch
7: http://mirrors.teamcloud.am/archlinux/$repo/os/$arch
8: https://europe.mirror.pkgbuild.com/$repo/os/$arch
9: https://at.arch.niranjan.co/$repo/os/$arch
10: http://mirror.accum.se/mirror/archlinux/$repo/os/$arch
11: http://ch.mirrors.cicku.me/archlinux/$repo/os/$arch
12: http://mirror.trap.moe/archlinux/$repo/os/$arch
13: https://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
14: http://it.mirrors.cicku.me/archlinux/$repo/os/$arch
15: http://mirror.sahil.world/archlinux/$repo/os/$arch
16: https://at.arch.mirror.kescher.at/$repo/os/$arch
17: http://ftp.energotel.sk/pub/linux/arch/$repo/os/$arch
18: https://ftp.energotel.sk/pub/linux/arch/$repo/os/$arch
19: http://arch.midov.pl/arch/$repo/os/$arch
20: https://mirror.trap.moe/archlinux/$repo/os/$arch
21: http://ftp.sh.cvut.cz/arch/$repo/os/$arch
22: https://archlinux.koyanet.lv/archlinux/$repo/os/$arch
23: http://mirrors.dotsrc.org/archlinux/$repo/os/$arch
24: http://archlinux.koyanet.lv/archlinux/$repo/os/$arch
25: https://ro.arch.niranjan.co/$repo/os/$arch
26: https://mirror.1ago.be/archlinux/$repo/os/$arch
27: https://mirrors.dotsrc.org/archlinux/$repo/os/$arch
28: http://super.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
29: http://jp.mirrors.cicku.me/archlinux/$repo/os/$arch
30: https://arch.mirror.constant.com/$repo/os/$arch
31: https://london.mirror.pkgbuild.com/$repo/os/$arch
32: http://nova.quantum-mirror.hu/mirrors/pub/archlinux/$repo/os/$arch
33: http://mirror.nw-sys.ru/archlinux/$repo/os/$arch
34: https://fi.arch.niranjan.co/$repo/os/$arch
35: http://es.mirrors.cicku.me/archlinux/$repo/os/$arch
36: https://mirror.tux.si/arch/$repo/os/$arch
37: https://repo.hyron.dev/archlinux/$repo/os/$arch
38: https://arch.midov.pl/arch/$repo/os/$arch
39: http://arch.yhtez.xyz/$repo/os/$arch
40: http://mirror.1ago.be/archlinux/$repo/os/$arch
41: https://mirror.neuf.no/archlinux/$repo/os/$arch
42: https://mirrors.pidginhost.com/arch/$repo/os/$arch
43: http://arch.mirror.constant.com/$repo/os/$arch
44: https://es.mirrors.cicku.me/archlinux/$repo/os/$arch
45: https://it.mirrors.cicku.me/archlinux/$repo/os/$arch
46: https://mirrors.atviras.lt/archlinux/$repo/os/$arch
47: https://in.arch.niranjan.co/$repo/os/$arch
48: https://sg.arch.niranjan.co/$repo/os/$arch
49: http://mirror.neuf.no/archlinux/$repo/os/$arch
50: http://mirrors.atviras.lt/archlinux/$repo/os/$arch
51: http://mirror.quantum5.ca/archlinux/$repo/os/$arch
52: https://mirror.ditatompel.com/archlinux/$repo/os/$arch
53: http://repo.hyron.dev/archlinux/$repo/os/$arch
54: https://mirror.franscorack.com/archlinux/$repo/os/$arch
55: http://mirror.tux.si/arch/$repo/os/$arch
56: https://mirror.nw-sys.ru/archlinux/$repo/os/$arch
57: https://singapore.mirror.pkgbuild.com/$repo/os/$arch
58: http://mirror.ditatompel.com/archlinux/$repo/os/$arch
59: https://au.arch.niranjan.co/$repo/os/$arch
60: https://mirrors.jlu.edu.cn/archlinux/$repo/os/$arch
61: http://mirrors.jlu.edu.cn/archlinux/$repo/os/$arch
62: http://gsl-syd.mm.fcix.net/archlinux/$repo/os/$arch
Memory: total: 64 GiB note: est. available: 62.71 GiB used: 11 GiB (17.5%)
Processes: 561 Power: uptime: 39m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 25.02 GiB services: org_kde_powerdevil,
Compilers: clang: 21.1.4 gcc: 15.2.1 Shell: fish v: 4.1.2
running-in: konsole inxi: 3.3.39 ~~~
Hi Chris,
thx for the inxi but how you did copy it not seen this info also garuda-health is missing.
Thank you for this information how it works. I do have a VR but its the generation 1 for my Playstation 4. I did until today not try if i can use it on the PC lol. Im not to much in the VR or MetaVerse. I just read for different VR`s you need another driver like lighthouse or something to get it proper working .( just red on the vrdb website guide.
for this question:
/.local/share is not the right place if i remembering correctly . You should use your home folder if you installed steam normally not on a other SSD. So should be look like this /home/user/.steam/steam/compatibilitytools.d (replace user with your username) Then close steam completely and start it again it should be to see now.
Just to be sure did you checked if you have all drivers for it like dxvk ,vk3d and so on.
I would try other settings like the guys here do. Try other Kernels and wine Versions too.
here the link :ok_hand:
https://www.protondb.com/app/438100
i forgot about this maybe you can work with it and try it if it helps you. This will help you to mange different versions and you can set it up easier for Steam :wink:
sudo pacman -S protonup-qt
https://www.msi.com/Motherboard/B550M-PRO-VDH-WIFI/support
Pls bios update. Your bios is outdated.
Think on the right settings after.
Secure + Fast-Boot off / AHCI Mode not raid / UEFI not CSM / Resizebar Enabled
That should already be done, but @Chris83 hasn’t given any feedback on it yet. :man_shrugging:
Even you are newbie or not, you have a search engine, to look also self, sorry.
example:
Read in your manual, no manual → download it from there
https://www.msi.com/Motherboard/B550M-PRO-VDH-WIFI/support#manual
Read on the msi page the how-to:
I’m sure I’m not a newbie. :wink:
And I’m also sure that you’ve hit the wrong reply button again. :winking_face_with_tongue:
Sorry, nepti, of course…you are a newbie :rofl:
Yes, now it was the third time, i mean…next time, i spend a cup of coffee, ok ?
Hi everyone, well i have not done the BIOS Update yet because i need my computer reliably working fully functional till Friday for work, then i will look into it.
