Ok here we go
inxi -SMGIxxxaz
System: Kernel: 5.11.1-127-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=7b3b21ac-f441-4613-a895-f713c81a4fe8 rw rootflags=subvol=@ quiet splash rd.udev.log_priority=3
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP EliteBook 1050 G1 v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 84E9 v: KBC Version 16.4B.00 serial: <filter> UEFI: HP v: Q72 Ver. 01.14.01 date: 10/26/2020
Graphics: Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:3e9b
class ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard driver: N/A alternate: nouveau
bus ID: 01:00.0 chip ID: 10de:1c8d class ID: 0300
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-7:2 chip ID: 04f2:b5e7 class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel unloaded: modesetting
alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Info: Processes: 379 Uptime: 2m wakeups: 1 Memory: 15.35 GiB used: 4.91 GiB (32.0%) Init: systemd v: 247 Compilers:
gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1755 lib: 537 Shell: Bash v: 5.1.4 running in: yakuake inxi: 3.3.01
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.02.19 true PCI
video-nvidia-prime-render-offload 2021.02.01 false PCI
Warning: No installed USB configs!
pacman -Qs nvidia
local/egl-wayland 1.1.6-1
EGLStream-based Wayland external platform
local/gwe 0.15.2-1
A system utility for controlling NVIDIA GPUs
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-utils 460.56-1
NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 460.56-1
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.4-1
local/libxnvctrl 460.39-1
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 460.39-1
mhwd-nvidia pci id
local/mhwd-nvidia-390xx 390.141-1
mhwd-nvidia-390xx PCI ID database
local/nvidia-dkms 460.56-1
NVIDIA drivers - module sources
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 460.39-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 460.56-1
local/opencl-nvidia 460.56-1
local/xf86-video-nouveau 1.0.17-1 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 120.02 + 59.96 59.93*
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 120.00 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1368x768 120.00 59.88 59.85
1280x800 59.81 59.91
1152x864 75.00
1280x720 120.00 59.86 59.74
1024x768 85.00 75.03 70.07 60.00
1024x768i 86.96
1024x576 120.00 59.90 59.82
832x624 74.55
960x540 120.00 59.63 59.82
800x600 85.14 72.19 75.00 60.32 56.25
864x486 120.00 59.92 59.57
640x480 85.01 72.81 75.00 59.94
720x405 120.00 59.51 58.99
720x400 85.04
640x400 85.08
640x360 120.00 59.84 59.32
640x350 85.08
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
HDMI3 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
bash -c 'for Xconf in $(ls /etc/X11/xorg.conf.d/*.conf | grep -v keyboard); do echo -e "\n" $Xconf ; cat $Xconf ; done'
Nothing
bash -c 'for Xconf in $(ls /etc/modules-load.d/*.conf); do echo -e "\n" $Xconf ; cat $Xconf ; done'
/etc/modules-load.d/mhwd-gpu.conf
## Generated by mhwd - Manjaro Hardware Detection
nvidia-drm
nvidia-uvm
/etc/modules-load.d/v4l2loopback.conf
/etc/modules-load.d/xow-uinput.conf
uinput
bash -c 'for Xconf in $(ls /etc/modprobe.d/*.conf); do echo -e "\n" $Xconf ; cat $Xconf ; done'
/etc/modprobe.d/99-xpadneo-bluetooth.conf
options bluetooth disable_ertm=y
/etc/modprobe.d/mhwd-gpu.conf
options nvidia "NVreg_DynamicPowerManagement=0x02"
/etc/modprobe.d/nobeep.conf
# Prevent annoying beep from the pc speaker.
blacklist pcspkr
/etc/modprobe.d/noime.conf
# Intel VPRO remote access technology driver.
blacklist mei
blacklist mei_me
/etc/modprobe.d/v4l2loopback.conf
/etc/modprobe.d/vmware-fuse.conf
# Added by VMware.
alias char-major-10-229 fuse
/etc/modprobe.d/xbox-generic-controller.conf
blacklist xpad
/etc/modprobe.d/xow-blacklist.conf
# Bind dongle to non-existent module to prevent the mt76x2u driver from loading
alias usb:v045Ep02E6d*dc*dsc*dp*ic*isc*ip*in* xow_blacklist
alias usb:v045Ep02FEd*dc*dsc*dp*ic*isc*ip*in* xow_blacklist
/etc/modprobe.d/xpadneo.conf
alias hid:b0005g*v0000045Ep000002E0 hid_xpadneo
alias hid:b0005g*v0000045Ep000002FD hid_xpadneo
alias hid:b0005g*v0000045Ep00000B05 hid_xpadneo
alias hid:b0005g*v0000045Ep00000B13 hid_xpadneo
journalctl -b -p3 --no-pager --no-hostname
-- Journal begins at Thu 2021-02-18 10:55:05 EET, ends at Fri 2021-02-26 15:14:31 EET. --
ัะตะฒ 26 15:06:50 kernel: x86/cpu: SGX disabled by BIOS
ัะตะฒ 26 15:06:50 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size of target Buffer (64 bits) (20201113/dsopcode-198)
ัะตะฒ 26 15:06:50 kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20201113/psparse-529)
ัะตะฒ 26 15:06:50 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20201113/exoparg2-393)
ัะตะฒ 26 15:06:50 kernel: ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20201113/psparse-529)
ัะตะฒ 26 15:06:50 kernel: ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20201113/psparse-529)
ัะตะฒ 26 15:06:50 systemd-modules-load[319]: Failed to find module 'nvidia-drm'
ัะตะฒ 26 15:06:50 systemd-modules-load[319]: Failed to find module 'nvidia-uvm'
ัะตะฒ 26 15:06:51 kernel: lis3lv02d: unknown sensor type 0x0
ัะตะฒ 26 15:06:51 systemd-tmpfiles[537]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
ัะตะฒ 26 15:06:52 kernel: usbhid 3-1.2:1.2: couldn't find an input interrupt endpoint
ัะตะฒ 26 15:06:52 wpa_supplicant[821]: nl80211: kernel reports: Attribute failed policy validation
ัะตะฒ 26 15:06:52 wpa_supplicant[821]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
ัะตะฒ 26 15:06:52 wpa_supplicant[821]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
ัะตะฒ 26 15:06:53 bluetoothd[567]: profiles/audio/avctp.c:avctp_server_socket() setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:06:53 bluetoothd[567]: avrcp-controller: Protocol not supported (93)
ัะตะฒ 26 15:06:53 bluetoothd[567]: audio-avrcp-target: Protocol not supported (93)
ัะตะฒ 26 15:06:56 kernel: psmouse serio3: synaptics: Unable to query device: -5
ัะตะฒ 26 15:07:08 kernel: usb 3-1.3.1: 1:1: cannot set freq 16000 to ep 0x83
ัะตะฒ 26 15:07:08 kernel: usb 3-1.3.1: 2:1: cannot set freq 48000 to ep 0x3
ัะตะฒ 26 15:07:13 kernel: ACPI Error: AE_TIME, Returned by Handler for [EmbeddedControl] (20201113/evregion-265)
ัะตะฒ 26 15:07:13 kernel: ACPI Error: Timeout from EC hardware or EC device driver (20201113/evregion-275)
ัะตะฒ 26 15:07:13 kernel: ACPI Error: Aborting method \_TZ.GTTP due to previous error (AE_TIME) (20201113/psparse-529)
ัะตะฒ 26 15:07:13 kernel: ACPI Error: Aborting method \_TZ.CPUZ._TMP due to previous error (AE_TIME) (20201113/psparse-529)
ัะตะฒ 26 15:07:15 sddm-helper[4576]: gkr-pam: unable to locate daemon control file
ัะตะฒ 26 15:07:17 bluetoothd[567]: src/profile.c:ext_start_servers() L2CAP server failed for Message Notification: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:07:17 bluetoothd[567]: src/profile.c:ext_start_servers() L2CAP server failed for Message Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:07:17 bluetoothd[567]: src/profile.c:ext_start_servers() L2CAP server failed for Phone Book Access: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:07:17 bluetoothd[567]: src/profile.c:ext_start_servers() L2CAP server failed for File Transfer: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:07:17 bluetoothd[567]: src/profile.c:ext_start_servers() L2CAP server failed for Object Push: setsockopt(L2CAP_OPTIONS): Invalid argument (22)
ัะตะฒ 26 15:07:18 systemd-coredump[5635]: [๐ก] Process 5610 (paleofetch) of user 1000 dumped core.
Stack trace of thread 5610:
#0 0x00007fe3e542105e __strncpy_avx2 (libc.so.6 + 0x16305e)
#1 0x0000556e25c9b537 n/a (paleofetch + 0x3537)
#2 0x0000556e25c9a19f n/a (paleofetch + 0x219f)
#3 0x00007fe3e52e5b25 __libc_start_main (libc.so.6 + 0x27b25)
#4 0x0000556e25c9a3ce n/a (paleofetch + 0x23ce)
ัะตะฒ 26 15:07:18 bluetoothd[567]: src/service.c:btd_service_connect() a2dp-sink profile connect failed for 00:12:6F:E1:F9:8A: Protocol not available
ัะตะฒ 26 15:07:18 bluetoothd[567]: src/service.c:btd_service_connect() a2dp-source profile connect failed for 00:12:6F:E1:F9:8A: Protocol not available
ัะตะฒ 26 15:07:19 systemd-coredump[5866]: [๐ก] Process 5841 (pipewire-media-) of user 1000 dumped core.
Stack trace of thread 5841:
#0 0x000055978580e03b n/a (pipewire-media-session + 0x2003b)
#1 0x000055978580ca6b n/a (pipewire-media-session + 0x1ea6b)
#2 0x00007efee1296df4 n/a (libpipewire-module-protocol-native.so + 0x16df4)
#3 0x00007efee1290aa2 n/a (libpipewire-module-protocol-native.so + 0x10aa2)
#4 0x00007efee1290ff8 n/a (libpipewire-module-protocol-native.so + 0x10ff8)
#5 0x00007efee238cd9b n/a (libspa-support.so + 0x6d9b)
#6 0x00007efee22fd5ab pw_main_loop_run (libpipewire-0.3.so.0 + 0x425ab)
#7 0x00005597857fa7dc n/a (pipewire-media-session + 0xc7dc)
#8 0x00007efee1fc0b25 __libc_start_main (libc.so.6 + 0x27b25)
#9 0x00005597857fac5e n/a (pipewire-media-session + 0xcc5e)
Stack trace of thread 5843:
#0 0x00007efee209839e epoll_wait (libc.so.6 + 0xff39e)
#1 0x00007efee23961f1 n/a (libspa-support.so + 0x101f1)
#2 0x00007efee238cd04 n/a (libspa-support.so + 0x6d04)
#3 0x00007efee22e3f50 n/a (libpipewire-0.3.so.0 + 0x28f50)
#4 0x00007efee216f299 start_thread (libpthread.so.0 + 0x9299)
#5 0x00007efee2098053 __clone (libc.so.6 + 0xff053)
ัะตะฒ 26 15:07:24 bluetoothd[567]: src/profile.c:record_cb() Unable to get Headset Voice gateway SDP record: Host is down
ัะตะฒ 26 15:07:25 systemd-coredump[6464]: [๐ก] Process 5513 (org_kde_powerde) of user 1000 dumped core.
Stack trace of thread 5513:
#0 0x00007f6074725ef5 raise (libc.so.6 + 0x3cef5)
#1 0x00007f6074725f80 __restore_rt (libc.so.6 + 0x3cf80)
#2 0x00007f6074725ef5 raise (libc.so.6 + 0x3cef5)
#3 0x00007f607470f862 abort (libc.so.6 + 0x26862)
#4 0x00007f607470f747 __assert_fail_base.cold (libc.so.6 + 0x26747)
#5 0x00007f607471e646 __assert_fail (libc.so.6 + 0x35646)
#6 0x00007f606cdaf655 n/a (libddcutil.so.4 + 0x31655)
#7 0x00007f606cda1391 n/a (libddcutil.so.4 + 0x23391)
#8 0x00007f606cda1bba n/a (libddcutil.so.4 + 0x23bba)
#9 0x00007f606cd973c2 n/a (libddcutil.so.4 + 0x193c2)
#10 0x00007f606cd97681 n/a (libddcutil.so.4 + 0x19681)
#11 0x00007f606cd97921 n/a (libddcutil.so.4 + 0x19921)
#12 0x00007f606cd97c43 n/a (libddcutil.so.4 + 0x19c43)
#13 0x00007f606cd99ad7 n/a (libddcutil.so.4 + 0x1bad7)
#14 0x00007f606cd8ede6 ddca_get_non_table_vcp_value (libddcutil.so.4 + 0x10de6)
#15 0x00007f606ce4a960 n/a (powerdevilupowerbackend.so + 0x17960)
#16 0x00007f606ce41207 _ZN23PowerDevilUPowerBackend4initEv (powerdevilupowerbackend.so + 0xe207)
#17 0x00005607905c68af n/a (org_kde_powerdevil + 0x78af)
#18 0x00005607905c51e5 n/a (org_kde_powerdevil + 0x61e5)
#19 0x00007f6074710b25 __libc_start_main (libc.so.6 + 0x27b25)
#20 0x00005607905c525e _start (org_kde_powerdevil + 0x625e)
Stack trace of thread 5548:
#0 0x00007f60747dd37f __poll (libc.so.6 + 0xf437f)
#1 0x00007f6072dc2baf n/a (libglib-2.0.so.0 + 0xa7baf)
#2 0x00007f6072d6d3b1 g_main_context_iteration (libglib-2.0.so.0 + 0x523b1)
#3 0x00007f6072d6d402 n/a (libglib-2.0.so.0 + 0x52402)
#4 0x00007f6072d9bfc1 n/a (libglib-2.0.so.0 + 0x80fc1)
#5 0x00007f60737d4299 start_thread (libpthread.so.0 + 0x9299)
#6 0x00007f60747e8053 __clone (libc.so.6 + 0xff053)
Stack trace of thread 5560:
#0 0x00007f60747e960d recvmsg (libc.so.6 + 0x10060d)
#1 0x00007f6072cb9237 n/a (libudev.so.1 + 0x10237)
#2 0x00007f6072cb9c6b udev_monitor_receive_device (libudev.so.1 + 0x10c6b)
#3 0x00007f606cd9b5f2 n/a (libddcutil.so.4 + 0x1d5f2)
Stack trace of thread 5549:
#2 0x00007f6072d6e0d3 g_main_loop_run (libglib-2.0.so.0 + 0x530d3)
#3 0x00007f606e00fd18 n/a (libgio-2.0.so.0 + 0x101d18)
Stack trace of thread 5547:
#3 0x00007f6074da1691 _ZN20QEventDispatcherGlib13processEventsE6QFlagsIN10QEventLoop17ProcessEventsFlagEE (libQt5Core.so.5 + 0x30e691)
#4 0x00007f6074d473ac _ZN10QEventLoop4execE6QFlagsINS_17ProcessEventsFlagEE (libQt5Core.so.5 + 0x2b43ac)
#5 0x00007f6074b5fd12 _ZN7QThread4execEv (libQt5Core.so.5 + 0xccd12)
#6 0x00007f6074fff098 n/a (libQt5DBus.so.5 + 0x17098)
#7 0x00007f6074b60eff n/a (libQt5Core.so.5 + 0xcdeff)
#8 0x00007f60737d4299 start_thread (libpthread.so.0 + 0x9299)
#9 0x00007f60747e8053 __clone (libc.so.6 + 0xff053)
ัะตะฒ 26 15:07:54 pulseaudio[5572]: Error opening PCM device front:0: No such file or directory
ัะตะฒ 26 15:07:55 libvirtd[658]: Device 0000:01:00.0 not found: could not access /sys/bus/pci/devices/0000:01:00.0/config: No such file or directory
ัะตะฒ 26 15:07:55 libvirtd[658]: Device 0000:01:00.1 not found: could not access /sys/bus/pci/devices/0000:01:00.1/config: No such file or directory
ัะตะฒ 26 15:07:58 sddm-helper[12478]: gkr-pam: unable to locate daemon control file
ัะตะฒ 26 15:08:01 systemd-coredump[12731]: [๐ก] Process 12712 (paleofetch) of user 1000 dumped core.
Stack trace of thread 12712:
#0 0x00007fae1ec1805e __strncpy_avx2 (libc.so.6 + 0x16305e)
#1 0x0000557eb57dc537 n/a (paleofetch + 0x3537)
#2 0x0000557eb57db19f n/a (paleofetch + 0x219f)
#3 0x00007fae1eadcb25 __libc_start_main (libc.so.6 + 0x27b25)
#4 0x0000557eb57db3ce n/a (paleofetch + 0x23ce)
ัะตะฒ 26 15:08:07 bluetoothd[567]: src/profile.c:record_cb() Unable to get Headset Voice gateway SDP record: Host is down
bash -c 'for Xlog in $(ls /var/log/Xorg.?.log); do echo -e "\n" $Xlog ; grep -E "(EE)|(WW)|failed|Time" $Xlog ; done'
/var/log/Xorg.0.log
[ 69.952] Current Operating System: Linux moksha 5.11.1-127-tkg-bmq #1 TKG SMP PREEMPT Wed, 24 Feb 2021 13:51:39 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 69.952] (==) Log file: "/var/log/Xorg.0.log", Time: Fri Feb 26 15:07:55 2021
[ 69.952] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 69.952] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 69.952] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[ 69.952] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 69.952] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 69.952] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 69.958] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 69.960] (WW) Warning, couldn't open module fbdev
[ 69.960] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 69.960] (WW) Warning, couldn't open module vesa
[ 69.960] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 69.961] (WW) Falling back to old probe method for modesetting
[ 69.978] (II) Initializing extension MIT-SCREEN-SAVER
[ 70.334] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:05:00.0/0000:06:01.0/0000:08:00.0/0000:09:02.0/0000:0a:00.0/usb3/3-1/3-1.3/3-1.3.1/3-1.3.1:1.3/0003:047F:02EE.0004/input/input39/event28"
[ 186.997] (EE) event12 - Corsair Corsair Gaming K66 Keyboard: client bug: event processing lagging behind by 17ms, your system is too slow
/var/log/Xorg.1.log
[ 12534.024] _XSERVTransSocketUNIXCreateListener: ...SocketCreateListener() failed
[ 12534.025] Current Operating System: Linux moksha 5.10.8-112-tkg-bmq #1 TKG SMP PREEMPT Tue, 19 Jan 2021 21:15:04 +0000 x86_64
[ 12534.026] (==) Log file: "/var/log/Xorg.1.log", Time: Tue Jan 26 13:00:09 2021
[ 12534.027] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 12534.027] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 12534.027] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/OTF".
[ 12534.027] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 12534.027] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 12534.027] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 12534.038] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 12535.040] (II) NVIDIA(0): ACPI: failed to connect to the ACPI event daemon; the daemon
[ 12535.286] (WW) modeset(G0): Option "AllowEmptyInitialConfiguration" is not used
[ 12535.286] (WW) modeset(G0): Option "AllowExternalGpus" is not used
[ 12535.291] (II) Initializing extension MIT-SCREEN-SAVER
[ 12535.939] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:05:00.0/0000:06:01.0/0000:08:00.0/0000:09:02.0/0000:0a:00.0/usb3/3-1/3-1.3/3-1.3.1/3-1.3.1:1.3/0003:047F:02EE.0002/input/input41/event29"
