Hello again,
I re-installed, twice actually since after I tried the install with the Prop. drivers after installation was done I got stuck on the boot screen.
On my second go I did use the open source drivers and install success!
After the installation was complete I updated the system using pacman -Syu and after a reboot I went to the Hardware configuration and installed the proprietary drivers as it shows:
Again I think the driver doesn't work, my second monitor doesn't want to start nor the Nvidia settings.
As advised I am paste-ing again the requested logs:
inxi -SMGIxxxaz
System: Kernel: 5.11.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=a6b9a661-5b1f-46fb-ac58-d4948979b365
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM
Distro: Garuda Linux
Machine: Type: Laptop System: HP product: HP EliteBook 1050 G1 v: N/A serial: <filter> Chassis: type: 10
Mobo: HP model: 84E9 v: KBC Version 16.4B.00 serial: <filter> UEFI: HP v: Q72 Ver. 01.14.01
date: 10/26/2020
Graphics: Device-1: Intel UHD Graphics 630 vendor: Hewlett-Packard driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:3e9b class ID: 0300
Device-2: NVIDIA GP107M [GeForce GTX 1050 Mobile] vendor: Hewlett-Packard driver: N/A
alternate: nouveau bus ID: 01:00.0 chip ID: 10de:1c8d class ID: 0300
Device-3: Chicony HP HD Camera type: USB driver: uvcvideo bus ID: 1-7:2 chip ID: 04f2:b5e7
class ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: loaded: intel
unloaded: modesetting alternate: fbdev,vesa display ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 120 dpi: 143 size: 340x190mm (13.4x7.5") diag: 389mm (15.3")
OpenGL: renderer: Mesa Intel UHD Graphics 630 (CFL GT2) v: 4.6 Mesa 20.3.4 direct render: Yes
Info: Processes: 311 Uptime: 14m wakeups: 1 Memory: 15.35 GiB used: 3.74 GiB (24.4%) Init: systemd
v: 247 Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1228 lib: 305 Shell: fish
v: 3.1.2 running in: konsole inxi: 3.3.01
mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
video-linux 2021.02.19 true PCI
video-nvidia-prime-render-offload 2021.02.01 false PCI
Warning: No installed USB configs!
pacman -Qs nvidia
local/egl-wayland 1.1.6-1
EGLStream-based Wayland external platform
local/gwe 0.15.2-1
A system utility for controlling NVIDIA GPUs
local/lib32-libvdpau 1.4-1
Nvidia VDPAU library
local/lib32-nvidia-utils 460.56-1
NVIDIA drivers utilities (32-bit)
local/lib32-opencl-nvidia 460.56-1
OpenCL implemention for NVIDIA (32-bit)
local/libvdpau 1.4-1
local/libxnvctrl 460.39-1
NVIDIA NV-CONTROL X extension
local/mhwd-nvidia 460.39-1
mhwd-nvidia pci id
local/mhwd-nvidia-390xx 390.141-1
mhwd-nvidia-390xx PCI ID database
local/nvidia-dkms 460.56-1
NVIDIA drivers - module sources
local/nvidia-prime 1.0-4
NVIDIA Prime Render Offload configuration and utilities
local/nvidia-settings 460.39-1
Tool for configuring the NVIDIA graphics driver
local/nvidia-utils 460.56-1
local/opencl-nvidia 460.56-1
local/xf86-video-nouveau 1.0.17-1 (xorg-drivers)
Open Source 3D acceleration driver for nVidia cards
xrandr
Screen 0: minimum 8 x 8, current 1920 x 1080, maximum 32767 x 32767
eDP1 connected primary 1920x1080+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1920x1080 120.02*+ 59.96 59.93
1680x1050 59.95 59.88
1400x1050 74.76 59.98
1600x900 120.00 59.95 59.82
1280x1024 85.02 75.02 60.02
1400x900 59.96 59.88
1280x960 85.00 60.00
1368x768 120.00 59.88 59.85
1280x800 59.81 59.91
1152x864 75.00
1280x720 120.00 59.86 59.74
1024x768 85.00 75.03 70.07 60.00
1024x768i 86.96
1024x576 120.00 59.90 59.82
832x624 74.55
960x540 120.00 59.63 59.82
800x600 85.14 72.19 75.00 60.32 56.25
864x486 120.00 59.92 59.57
640x480 85.01 72.81 75.00 59.94
720x405 120.00 59.51 58.99
720x400 85.04
640x400 85.08
640x360 120.00 59.84 59.32
640x350 85.08
DP1 disconnected (normal left inverted right x axis y axis)
DP2 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 disconnected (normal left inverted right x axis y axis)
HDMI3 disconnected (normal left inverted right x axis y axis)
VIRTUAL1 disconnected (normal left inverted right x axis y axis)```
bash -c 'for Xconf in $(ls /etc/X11/xorg.conf.d/*.conf | grep -v keyboard); do echo -e "\n" $Xconf ; cat $Xconf ; done'
No output
bash -c 'for Xconf in $(ls /etc/modules-load.d/*.conf); do echo -e "\n" $Xconf ; cat $Xconf ; done'
/etc/modules-load.d/mhwd-gpu.conf
nvidia-drm
nvidia-uvm
bash -c 'for Xconf in $(ls /etc/modprobe.d/*.conf); do echo -e "\n" $Xconf ; cat $Xconf ; done'
/etc/modprobe.d/mhwd-gpu.conf
options nvidia "NVreg_DynamicPowerManagement=0x02"
/etc/modprobe.d/nobeep.conf
# Prevent annoying beep from the pc speaker.
blacklist pcspkr
/etc/modprobe.d/noime.conf
# Intel VPRO remote access technology driver.
blacklist mei
blacklist mei_meโ
journalctl -b -p3 --no-pager --no-hostname
-- Journal begins at Sat 2021-02-27 00:09:44 EET, ends at Sat 2021-02-27 09:44:35 EET. --
ัะตะฒ 27 09:25:30 kernel: x86/cpu: SGX disabled by BIOS
ัะตะฒ 27 09:25:30 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 ex
ceeds size of target Buffer (64 bits) (20201113/dsopcode-198)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (202
01113/psparse-529)
ัะตะฒ 27 09:25:30 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of obje
ct (length 0x5) (20201113/exoparg2-393)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20
201113/psparse-529)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT
) (20201113/psparse-529)
201113/psparse-529)
ัะตะฒ 27 09:25:30 systemd-modules-load[322]: Failed to find module 'nvidia-drm'
ัะตะฒ 27 09:25:30 systemd-modules-load[322]: Failed to find module 'nvidia-uvm'
ัะตะฒ 27 09:25:30 kernel: lis3lv02d: unknown sensor type 0x0
ัะตะฒ 27 09:25:30 systemd-tmpfiles[459]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operati
on not permitted
ัะตะฒ 27 09:25:31 kernel: usbhid 3-1.2:1.2: couldn't find an input interrupt endpoint
ัะตะฒ 27 09:25:32 wpa_supplicant[1660]: nl80211: kernel reports: Attribute failed policy validation
ัะตะฒ 27 09:25:32 wpa_supplicant[1660]: Failed to create interface p2p-dev-wlp0s20f3: -22 (Invalid argument)
ัะตะฒ 27 09:25:32 wpa_supplicant[1660]: nl80211: Failed to create a P2P Device interface p2p-dev-wlp0s20f3
ัะตะฒ 27 09:25:39 kernel: usb 3-1.3.1: 1:1: cannot set freq 16000 to ep 0x83
ัะตะฒ 27 09:25:39 kernel: usb 3-1.3.1: 2:1: cannot set freq 48000 to ep 0x3
ัะตะฒ 27 09:25:41 kwin_x11[2195]: kwin_xkbcommon: XKB: Couldn't process include statement for 'us(\0)'
ัะตะฒ 27 09:25:41 kwin_x11[2195]: kwin_xkbcommon: XKB: Abandoning symbols file "(unnamed)"
ัะตะฒ 27 09:25:41 kwin_x11[2195]: kwin_xkbcommon: XKB: Failed to compile xkb_symbols
ัะตะฒ 27 09:25:41 kwin_x11[2195]: kwin_xkbcommon: XKB: Failed to compile keymap
ัะตะฒ 27 09:26:17 systemd-coredump[4053]: [๏ก] Process 4047 (pipewire-media-) of user 1000 dumped core.
Stack trace of thread 4047:
#0 0x0000563cc328e03b n/a (pipewire-media-session + 0x2003b)
#1 0x0000563cc328ca6b n/a (pipewire-media-session + 0x1ea6b)
#2 0x00007fbb9e483df4 n/a (libpipewire-module-protocol-native.so +
0x16df4)
#3 0x00007fbb9e47daa2 n/a (libpipewire-module-protocol-native.so +
0x10aa2)
#4 0x00007fbb9e47dff8 n/a (libpipewire-module-protocol-native.so +
0x10ff8)
#5 0x00007fbb9f55dd9b n/a (libspa-support.so + 0x6d9b)
#6 0x00007fbb9f4dc5ab pw_main_loop_run (libpipewire-0.3.so.0 + 0x4
25ab)
#7 0x0000563cc327a7dc n/a (pipewire-media-session + 0xc7dc)
#8 0x00007fbb9f19fb25 __libc_start_main (libc.so.6 + 0x27b25)
#9 0x0000563cc327ac5e n/a (pipewire-media-session + 0xcc5e)
Stack trace of thread 4049:
#0 0x00007fbb9f27739e epoll_wait (libc.so.6 + 0xff39e)
#1 0x00007fbb9f5671f1 n/a (libspa-support.so + 0x101f1)
#2 0x00007fbb9f55dd04 n/a (libspa-support.so + 0x6d04)
#3 0x00007fbb9f4c2f50 n/a (libpipewire-0.3.so.0 + 0x28f50)
#4 0x00007fbb9f34e299 start_thread (libpthread.so.0 + 0x9299)
#5 0x00007fbb9f277053 __clone (libc.so.6 + 0xff053)
bash -c 'for Xlog in $(ls /var/log/Xorg.?.log); do echo -e "\n" $Xlog ; grep -E "(EE)|(WW)|failed|Time" $Xlog ; done'
/var/log/Xorg.0.log
[ 8.259] Current Operating System: Linux moksha 5.11.1-zen1-1-zen #1 ZEN SMP PREEMPT Tue, 23 Feb 2021 14:0
5:33 +0000 x86_64
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 8.259] (==) Log file: "/var/log/Xorg.0.log", Time: Sat Feb 27 09:25:31 2021
[ 8.262] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/misc".
[ 8.262] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/TTF".
[ 8.262] (WW) The directory "/usr/share/fonts/OTF" does not exist.
[ 8.262] (WW) The directory "/usr/share/fonts/Type1" does not exist.
[ 8.262] (WW) The directory "/usr/share/fonts/100dpi" does not exist.
[ 8.262] (WW) The directory "/usr/share/fonts/75dpi" does not exist.
[ 8.272] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 8.278] (WW) Warning, couldn't open module fbdev
[ 8.278] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 8.278] (WW) Warning, couldn't open module vesa
[ 8.278] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 8.291] (WW) Falling back to old probe method for modesetting
[ 8.305] (II) Initializing extension MIT-SCREEN-SAVER
[ 16.304] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:1c.4/0000:05:00.0/0000:06:01.0/00
00:08:00.0/0000:09:02.0/0000:0a:00.0/usb3/3-1/3-1.3/3-1.3.1/3-1.3.1:1.3/0003:047F:02EE.0004/input/input41/even
t29"
[ 946.280] (EE) event21 - Corsair Corsair Gaming K66 Keyboard: client bug: event processing lagging behind b
y 21ms, your system is too slow
[ 1075.574] (EE) event21 - Corsair Corsair Gaming K66 Keyboard: client bug: event processing lagging behind b
y 31ms, your system is too slow
[ 1203.481] (EE) event21 - Corsair Corsair Gaming K66 Keyboard: client bug: event processing lagging behind b
y 30ms, your system is too slow
-- Journal begins at Sat 2021-02-27 00:09:44 EET, ends at Sat 2021-02-27 09:47:15 EET. --
ัะตะฒ 27 09:25:30 kernel: ACPI BIOS Error (bug): AE_AML_BUFFER_LIMIT, Field [CAP1] at bit offset/length 64/32 exceeds size of target Buffer (64 bits) (20201113/dsopcode-198)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_SB._OSC due to previous error (AE_AML_BUFFER_LIMIT) (20201113/psparse-529)
ัะตะฒ 27 09:25:30 kernel: ACPI BIOS Error (bug): AE_AML_PACKAGE_LIMIT, Index (0x000000005) is beyond end of object (length 0x5) (20201113/exoparg2-393)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_TZ.GETP due to previous error (AE_AML_PACKAGE_LIMIT) (20201113/psparse-529)
ัะตะฒ 27 09:25:30 kernel: ACPI Error: Aborting method \_TZ.CHGZ._CRT due to previous error (AE_AML_PACKAGE_LIMIT) (20201113/psparse-529)
ัะตะฒ 27 09:25:30 systemd-tmpfiles[459]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
ัะตะฒ 27 09:26:17 systemd-coredump[4053]: [๐ก] Process 4047 (pipewire-media-) of user 1000 dumped core.
#2 0x00007fbb9e483df4 n/a (libpipewire-module-protocol-native.so +0x16df4)
#3 0x00007fbb9e47daa2 n/a (libpipewire-module-protocol-native.so +0x10aa2)
#4 0x00007fbb9e47dff8 n/a (libpipewire-module-protocol-native.so +0x10ff8)
#6 0x00007fbb9f4dc5ab pw_main_loop_run (libpipewire-0.3.so.0 + 0x425ab)
full Xor:
psswd: jhkbgsdfjhb#%$^
