I installed anbox using this guide Ultimate Guide to install Anbox in any Arch-based distro(especially Garuda)
I followed all the instructions correctly, but anbox is not starting. neither from terminal nor from GUI
Terminal start
╭─amey@amey in ~ as 🧙 took 3s
╰─λ anbox wait-ready
╭─amey@amey in ~ as 🧙 took 30s
when I run this:
sudo ls -1 /dev/binderfs
output:
binder-control
features
this is the output of anbox system-info
╭─amey@amey in ~ took 16ms
╰─λ anbox system-info
version: local-7a0bee7
cpu:
arch: x86
brand: 12th Gen Intel(R) Core(TM) i5-1235U
features:
- aes
- sse4_1
- sse4_2
- avx
- avx2
os:
version:
snap-based: false
kernel:
version: Linux version 6.1.6-zen1-2-zen (linux-zen@archlinux) (gcc (GCC) 12.2.1 20230111, GNU ld (GNU Binutils) 2.40) #1 ZEN SMP PREEMPT_DYNAMIC Mon, 16 Jan 2023 14:55:29 +0000
binder: false
binderfs: true
ashmem: true
graphics:
egl:
vendor: Mesa Project
version: 1.5
extensions:
- EGL_ANDROID_blob_cache
- EGL_ANDROID_native_fence_sync
- EGL_CHROMIUM_sync_control
- EGL_ANGLE_sync_control_rate
- EGL_EXT_buffer_age
- EGL_EXT_create_context_robustness
- EGL_EXT_image_dma_buf_import
- EGL_EXT_image_dma_buf_import_modifiers
- EGL_EXT_swap_buffers_with_damage
- EGL_IMG_context_priority
- EGL_KHR_cl_event2
- EGL_KHR_config_attribs
- EGL_KHR_context_flush_control
- EGL_KHR_create_context
- EGL_KHR_create_context_no_error
- EGL_KHR_fence_sync
- EGL_KHR_get_all_proc_addresses
- EGL_KHR_gl_colorspace
- EGL_KHR_gl_renderbuffer_image
- EGL_KHR_gl_texture_2D_image
- EGL_KHR_gl_texture_3D_image
- EGL_KHR_gl_texture_cubemap_image
- EGL_KHR_image
- EGL_KHR_image_base
- EGL_KHR_image_pixmap
- EGL_KHR_no_config_context
- EGL_KHR_reusable_sync
- EGL_KHR_surfaceless_context
- EGL_KHR_swap_buffers_with_damage
- EGL_EXT_pixel_format_float
- EGL_KHR_wait_sync
- EGL_MESA_configless_context
- EGL_MESA_drm_image
- EGL_MESA_image_dma_buf_export
- EGL_MESA_query_driver
- EGL_NOK_texture_from_pixmap
- EGL_WL_bind_wayland_display
gles2:
vendor: Intel
vendor: OpenGL ES 3.2 Mesa 22.3.3
extensions:
- GL_EXT_blend_minmax
- GL_EXT_multi_draw_arrays
- GL_EXT_texture_filter_anisotropic
- GL_EXT_texture_compression_s3tc
- GL_EXT_texture_compression_dxt1
- GL_EXT_texture_compression_rgtc
- GL_EXT_texture_format_BGRA8888
- GL_OES_compressed_ETC1_RGB8_texture
- GL_OES_depth24
- GL_OES_element_index_uint
- GL_OES_fbo_render_mipmap
- GL_OES_mapbuffer
- GL_OES_rgb8_rgba8
- GL_OES_standard_derivatives
- GL_OES_stencil8
- GL_OES_texture_3D
- GL_OES_texture_float
- GL_OES_texture_float_linear
- GL_OES_texture_half_float
- GL_OES_texture_half_float_linear
- GL_OES_texture_npot
- GL_OES_vertex_half_float
- GL_EXT_draw_instanced
- GL_EXT_texture_sRGB_decode
- GL_OES_EGL_image
- GL_OES_depth_texture
- GL_AMD_performance_monitor
- GL_OES_packed_depth_stencil
- GL_EXT_texture_type_2_10_10_10_REV
- GL_NV_conditional_render
- GL_OES_get_program_binary
- GL_APPLE_texture_max_level
- GL_EXT_discard_framebuffer
- GL_EXT_read_format_bgra
- GL_NV_pack_subimage
- GL_EXT_frag_depth
- GL_NV_fbo_color_attachments
- GL_OES_EGL_image_external
- GL_OES_EGL_sync
- GL_OES_vertex_array_object
- GL_OES_viewport_array
- GL_ANGLE_pack_reverse_row_order
- GL_ANGLE_texture_compression_dxt3
- GL_ANGLE_texture_compression_dxt5
- GL_EXT_occlusion_query_boolean
- GL_EXT_robustness
- GL_EXT_texture_rg
- GL_EXT_unpack_subimage
- GL_NV_draw_buffers
- GL_NV_read_buffer
- GL_NV_read_depth
- GL_NV_read_depth_stencil
- GL_NV_read_stencil
- GL_EXT_draw_buffers
- GL_EXT_map_buffer_range
- GL_KHR_debug
- GL_KHR_robustness
- GL_KHR_texture_compression_astc_ldr
- GL_NV_pixel_buffer_object
- GL_OES_depth_texture_cube_map
- GL_OES_required_internalformat
- GL_OES_surfaceless_context
- GL_EXT_color_buffer_float
- GL_EXT_debug_label
- GL_EXT_sRGB_write_control
- GL_EXT_separate_shader_objects
- GL_EXT_shader_framebuffer_fetch
- GL_EXT_shader_group_vote
- GL_EXT_shader_implicit_conversions
- GL_EXT_shader_integer_mix
- GL_EXT_tessellation_point_size
- GL_EXT_tessellation_shader
- GL_INTEL_conservative_rasterization
- GL_INTEL_performance_query
- GL_ANDROID_extension_pack_es31a
- GL_EXT_base_instance
- GL_EXT_compressed_ETC1_RGB8_sub_texture
- GL_EXT_copy_image
- GL_EXT_draw_buffers_indexed
- GL_EXT_draw_elements_base_vertex
- GL_EXT_gpu_shader5
- GL_EXT_polygon_offset_clamp
- GL_EXT_primitive_bounding_box
- GL_EXT_render_snorm
- GL_EXT_shader_io_blocks
- GL_EXT_texture_border_clamp
- GL_EXT_texture_buffer
- GL_EXT_texture_cube_map_array
- GL_EXT_texture_norm16
- GL_EXT_texture_view
- GL_KHR_blend_equation_advanced
- GL_KHR_blend_equation_advanced_coherent
- GL_KHR_context_flush_control
- GL_KHR_robust_buffer_access_behavior
- GL_NV_image_formats
- GL_NV_shader_noperspective_interpolation
- GL_OES_copy_image
- GL_OES_draw_buffers_indexed
- GL_OES_draw_elements_base_vertex
- GL_OES_gpu_shader5
- GL_OES_primitive_bounding_box
- GL_OES_sample_shading
- GL_OES_sample_variables
- GL_OES_shader_io_blocks
- GL_OES_shader_multisample_interpolation
- GL_OES_tessellation_point_size
- GL_OES_tessellation_shader
- GL_OES_texture_border_clamp
- GL_OES_texture_buffer
- GL_OES_texture_cube_map_array
- GL_OES_texture_stencil8
- GL_OES_texture_storage_multisample_2d_array
- GL_OES_texture_view
- GL_EXT_blend_func_extended
- GL_EXT_buffer_storage
- GL_EXT_float_blend
- GL_EXT_geometry_point_size
- GL_EXT_geometry_shader
- GL_EXT_shader_samples_identical
- GL_EXT_texture_sRGB_R8
- GL_KHR_no_error
- GL_KHR_texture_compression_astc_sliced_3d
- GL_NV_fragment_shader_interlock
- GL_OES_EGL_image_external_essl3
- GL_OES_geometry_point_size
- GL_OES_geometry_shader
- GL_OES_shader_image_atomic
- GL_EXT_clear_texture
- GL_EXT_clip_cull_distance
- GL_EXT_disjoint_timer_query
- GL_EXT_texture_compression_s3tc_srgb
- GL_MESA_shader_integer_functions
- GL_EXT_clip_control
- GL_EXT_color_buffer_half_float
- GL_EXT_memory_object
- GL_EXT_memory_object_fd
- GL_EXT_semaphore
- GL_EXT_semaphore_fd
- GL_EXT_texture_compression_bptc
- GL_EXT_texture_mirror_clamp_to_edge
- GL_KHR_parallel_shader_compile
- GL_EXT_EGL_image_storage
- GL_EXT_shader_framebuffer_fetch_non_coherent
- GL_EXT_texture_shadow_lod
- GL_INTEL_blackhole_render
- GL_MESA_framebuffer_flip_y
- GL_NV_compute_shader_derivatives
- GL_EXT_demote_to_helper_invocation
- GL_EXT_depth_clamp
- GL_EXT_texture_query_lod
- GL_MESA_bgra
╭─amey@amey in ~ as 🧙 took 40ms
╰─λ anbox check-features
Your computer does meet all requirements to run Anbox
╭─amey@amey in ~ as 🧙 took 19ms
╰─λ garuda-inxi
Kernel: 6.1.6-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=5db7243d-174d-446d-8935-c049889ff0f7 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Laptop System: HP product: HP Laptop 15s-fq5xxx v: N/A
Mobo: HP model: 8A20 v: 20.18 serial: <superuser required> UEFI: AMI
v: F.16 date: 09/15/2022
ID-1: BAT0 charge: 24.9 Wh (59.4%) condition: 41.9/41.0 Wh (102.0%)
volts: 11.5 min: 11.4 model: HP Primary type: Li-ion serial: <filter>
status: discharging cycles: 59
Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
microcode: 0x424
Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1037 high: 2500 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 864 2: 501 3: 860 4: 945
5: 873 6: 1200 7: 605 8: 1279 9: 914 10: 999 11: 2500 12: 913
bogomips: 59904
Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
vendor: Hewlett-Packard driver: i915 v: kernel arch: Gen-12.2
process: Intel 10nm built: 2021-22+ ports: active: eDP-1 empty: DP-1,
DP-2, DP-3, DP-4, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a8
Device-2: Quanta HP TrueVision HD Camera type: USB driver: uvcvideo
bus-ID: 1-3:2 chip-ID: 0408:536c class-ID: 0e02 serial: <filter>
Monitor-1: eDP-1 model: ChiMei InnoLux 0x153b built: 2020 res: 1920x1080
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.3.3 renderer: Mesa Intel Graphics (ADL GT2)
direct render: Yes
vendor: Hewlett-Packard driver: sof-audio-pci-intel-tgl
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.1.6-zen1-2-zen running: yes
vendor: Hewlett-Packard driver: rtw_8822ce v: N/A modules: rtw88_8822ce
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 01:00.0
IF-ID-1: anbox0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vethTCNR6b state: up speed: 10000 Mbps duplex: full mac: <filter>
bus-ID: 1-10:3 chip-ID: 0bda:b00c class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 61.05 GiB (12.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Intel model: SSDPEKNU512GZH
lanes: 4 type: SSD serial: <filter> rev: HPS1 temp: 27.9 C scheme: GPT
ID-1: / raw-size: 56.59 GiB size: 56.59 GiB (100.00%)
used: 29.47 GiB (52.1%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 612 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p8 maj-min: 259:8
ID-3: /home raw-size: 119.27 GiB size: 119.27 GiB (100.00%)
used: 31.58 GiB (26.5%) fs: btrfs dev: /dev/nvme0n1p7 maj-min: 259:7
ID-4: /var/log raw-size: 56.59 GiB size: 56.59 GiB (100.00%)
ID-5: /var/tmp raw-size: 56.59 GiB size: 56.59 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.44 GiB used: 236 MiB (3.1%) priority: 100
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 349 Uptime: 2h 25m wakeups: 3083 Memory: 7.44 GiB
used: 4.03 GiB (54.2%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1570
libs: 495 tools: pamac,paru,yay Shell: fish v: 3.6.0 default: Bash v: 5.1.16
Garuda (2.6.14-1):
System install date: 2022-12-07
Last full system update: 2023-01-18
Please help me
SGS
18 January 2023 14:31
2
Missing your garuda-inxi.
Writing a well formatted post in the forum (Discource powered) is important, if you want readers to easily read and understand.
It’s especially important for terminal output.
Here is a brief tutorial.
Terminal output
For terminal output, text output with special characters, always use code wrapping (Pre-formated text).
Select all of the text and do one of these:
Hit the </> button in Discource Post Toolbar.
Press CtrlShift+C on your keyboard.
Manually with markdown
After you Copy your …
I have edited the post. Now does this look good?
Austin
20 January 2023 02:57
4
https://aur.archlinux.org/packages/anbox-modules-dkms#comment-846854
sudo modprobe binder_linux devices=binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder
sudo modprobe ashmem_linux
sudo umount /dev/binderfs
sudo mount -t binder none /dev/binderfs
Now again post:
Does this get it working, @ameyjoshi3068 ?
I had exams the last two days so I couldn't reply.
It looks like anbox-module-dkms cannot install binder for my machine
╭─amey@amey in ~ as 🧙 took 408ms
[🔴] × sudo pacman -S anbox-modules-dkms
warning: anbox-modules-dkms-5.19-4.1 is up to date -- reinstalling
resolving dependencies...
Packages (1) anbox-modules-dkms-5.19-4.1
Total Download Size: 0.08 MiB
Total Installed Size: 0.48 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
anbox-modules-dkms-5.19-4.1-x86_64 78.1 KiB 85.9 KiB/s 00:01 [------------------------------------] 100%
(1/1) checking keys in keyring [------------------------------------] 100%
(1/1) checking package integrity [------------------------------------] 100%
(1/1) loading package files [------------------------------------] 100%
(1/1) checking for file conflicts [------------------------------------] 100%
(1/1) checking available disk space [------------------------------------] 100%
(1/2) Performing snapper pre snapshots for the following configurations...
==> root: 179
(2/2) Remove upgraded DKMS modules
==> dkms remove --no-depmod ashmem/1 -k 6.1.6-zen1-2-zen
==> dkms remove binder/1
(1/1) reinstalling anbox-modules-dkms [------------------------------------] 100%
==>> Building & Installing Modules (binder)
make -C /lib/modules/6.1.6-zen1-2-zen/build V=0 M=$PWD
make[1]: Entering directory '/usr/lib/modules/6.1.6-zen1-2-zen/build'
CC [M] /tmp/binder_install/deps.o
In file included from ././include/linux/kconfig.h:5,
from <command-line>:
./include/generated/autoconf.h:4400: warning: "CONFIG_ANDROID_BINDER_DEVICES" redefined
4400 | #define CONFIG_ANDROID_BINDER_DEVICES ""
<command-line>: note: this is the location of the previous definition
./include/generated/autoconf.h:5760: warning: "CONFIG_ANDROID_BINDERFS" redefined
5760 | #define CONFIG_ANDROID_BINDERFS 1
/tmp/binder_install/deps.c: In function ‘close_fd_get_file’:
/tmp/binder_install/deps.c:92:42: error: ‘res’ undeclared (first use in this function)
92 | return close_fd_get_file_ptr(fd, res);
/tmp/binder_install/deps.c:92:42: note: each undeclared identifier is reported only once for each function it appears in
/tmp/binder_install/deps.c:92:16: error: too many arguments to function ‘close_fd_get_file_ptr’
make[2]: *** [scripts/Makefile.build:250: /tmp/binder_install/deps.o] Error 1
make[1]: *** [Makefile:1990: /tmp/binder_install] Error 2
make[1]: Leaving directory '/usr/lib/modules/6.1.6-zen1-2-zen/build'
make: *** [Makefile:8: all] Error 2
cp binder_linux.ko /usr/src/binder-1/
cp: cannot stat 'binder_linux.ko': No such file or directory
make: *** [Makefile:11: install] Error 1
==>> Building & Installing Modules (ashmem)
CC [M] /tmp/ashmem_install/deps.o
CC [M] /tmp/ashmem_install/ashmem.o
LD [M] /tmp/ashmem_install/ashmem_linux.o
MODPOST /tmp/ashmem_install/Module.symvers
CC [M] /tmp/ashmem_install/ashmem_linux.mod.o
LD [M] /tmp/ashmem_install/ashmem_linux.ko
BTF [M] /tmp/ashmem_install/ashmem_linux.ko
cp ashmem_linux.ko /usr/src/ashmem-1/
==>> Cleaning Up
==>> Loading Anbox Modules
modprobe: FATAL: Module binder_linux not found in directory /lib/modules/6.1.6-zen1-2-zen
shell-init: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
==> Building image from preset: /etc/mkinitcpio.d/linux-xanmod-anbox.preset: 'default'
-> -k /boot/vmlinuz-linux-xanmod-anbox -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-xanmod-anbox.img
==> Starting build: 6.1.5-x64v1-xanmod1-1
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: xhci_pci
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-xanmod-anbox.img
pushd: error retrieving current directory: getcwd: cannot access parent directories: No such file or directory
/usr/bin/mkinitcpio: line 260: popd: directory stack empty
==> Image generation successful
==> Building image from preset: /etc/mkinitcpio.d/linux-xanmod-anbox.preset: 'fallback'
-> -k /boot/vmlinuz-linux-xanmod-anbox -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-xanmod-anbox-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: aic94xx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla1280
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: wd719x
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-xanmod-anbox-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'default'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen.img
==> Starting build: 6.1.6-zen1-2-zen
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen.img
==> Building image from preset: /etc/mkinitcpio.d/linux-zen.preset: 'fallback'
-> -k /boot/vmlinuz-linux-zen -c /etc/mkinitcpio.conf -g /boot/initramfs-linux-zen-fallback.img -S autodetect
==> Creating zstd-compressed initcpio image: /boot/initramfs-linux-zen-fallback.img
(1/8) Arming ConditionNeedsUpdate...
(2/8) Install DKMS modules
==> dkms install --no-depmod binder/1 -k 6.1.6-zen1-2-zen
Error! Bad return status for module build on kernel: 6.1.6-zen1-2-zen (x86_64)
Consult /var/lib/dkms/binder/1/build/make.log for more information.
==> WARNING: `dkms install --no-depmod binder/1 -k 6.1.6-zen1-2-zen' exited 10
==> dkms install --no-depmod ashmem/1 -k 6.1.6-zen1-2-zen
==> depmod 6.1.6-zen1-2-zen
(3/8) Updating linux initcpios...
(4/8) Foreign/AUR package notification
python-bluetooth-battery 1.3.2-4
rootactions-servicemenu 2.7.3-1
(5/8) Orphaned package notification...
debugedit 5.0-4
geocode-glib 3.26.4-2
libvisual 0.4.0-8
maven 3.8.7-1
mcfly 0.7.1-1
(6/8) Checking for .pacnew and .pacsave files...
.pac* files found:
/etc/default/grub.pacnew
/etc/pamac.conf.pacnew
/etc/mkinitcpio.conf.pacnew
Please check and merge
(7/8) Performing snapper post snapshots for the following configurations...
==> root: 180
(8/8) Syncing all file systems...
╭─amey@amey in ~ as 🧙 took 1m45s
╰─λ sudo modprobe binder_linux devices=binder,hwbinder,vndbinder,anbox-binder,anbox-hwbinder,anbox-vndbinder
But it looks like ashem and binder are loaded
╭─amey@amey in ~
╰─λ grep binder /proc/filesystems
grep ashmem /proc/misc
nodev binder
123 ashmem
here is the output you asked for
╭─amey@amey in ~
╰─λ sudo ls -1 /dev/binderfs
[sudo] password for amey:
binder-control
features
filo
20 January 2023 14:21
6
Possibly related (I don't use Anbox): see latest comment here:
https://aur.archlinux.org/packages/anbox-modules-dkms#comment-897829
Related to this:
choff:master ← zhanghua000:patch-1
opened 12:55PM - 24 Dec 22 UTC
It seems that they simplified some code on version 6.1 and we should also adjust… this module.
See https://github.com/torvalds/linux/commit/f5d39b020809146cc28e6e73369bf8065e0310aa for more info.
Seems to be fixed, so should be hopefully committed soon.
Austin
20 January 2023 14:51
7
You could btw check out Waydroid, we have a guide for that too in the forum.
But first you would have to undo all the changes you have made for Anbox, including removing Anbox modules.
Waydroid is actively being developed and is supposed to be the successor of Anbox.
Edit:
I just checked out, anbox was last active 4 months ago, while Waydroid was last contributed to just 4 hours ago!
I will check Waydroid for sure. Thanks, everyone for helping me
system
Closed
4 February 2023 11:05
9
