Help, I can't boot: "452: out of range pointer"
Hello everyone! So, I got the 452 error after updating my system. Since I can’t boot, I got the inxi from my last post here:
inxi
        LANGUAGE = "",
        LC_ALL = (unset),
        LC_ADDRESS = "pt_BR.UTF-8",
        LC_NAME = "pt_BR.UTF-8",
        LC_MONETARY = "pt_BR.UTF-8",
        LC_PAPER = "pt_BR.UTF-8",
        LC_IDENTIFICATION = "pt_BR.UTF-8",
        LC_TELEPHONE = "pt_BR.UTF-8",
        LC_MEASUREMENT = "pt_BR.UTF-8",
        LC_TIME = "pt_BR.UTF-8",
        LC_NUMERIC = "pt_BR.UTF-8",
        LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
  Kernel: 5.15.67-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
    root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 rw rootflags=subvol=@
    quiet
    cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
    root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff splash
  Desktop: LXQt v: 1.1.0 tk: Qt v: 5.15.6 info: cairo-dock, lxqt-panel
  Type: Desktop Mobo: INTEL model: HM65DESK serial: <superuser required>
    UEFI: American Megatrends v: 4.6.5 date: 02/23/2019
  Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
    L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 971 high: 1296 min/max: 800/3400 scaling:
    driver: intel_cpufreq governor: performance cores: 1: 937 2: 837 3: 814
    4: 1296 bogomips: 21551
  Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
    prctl and seccomp
  Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 515.65.01
    alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current (as of
    2022-08) arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-19
    pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 2 speed: 5 GT/s
    lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1381 class-ID: 0300
  Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.12x11.81")
    s-diag: 487mm (19.18")
  Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49
    size: 708x398mm (27.87x15.67") diag: 812mm (31.98") modes: N/A
  OpenGL: renderer: NVIDIA GeForce GTX 750/PCIe/SSE2 v: 4.6.0 NVIDIA
    515.65.01 direct render: Yes
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
  Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
    link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
  Sound Server-1: ALSA v: k5.15.67-1-lts running: yes
    driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
    bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 2.78 TiB used: 592.46 GiB (20.8%)
  ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
    physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
    rev: Sb10 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
    size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
  ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 164.05 GiB
    (29.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
  ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%) used: 240.8
    MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
  ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 164.05
    GiB (29.4%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
  ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 164.05
  ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%) used: 164.05
  ID-1: swap-1 type: zram size: 3.79 GiB used: 710.8 MiB (18.3%)
  System Temperatures: cpu: 36.0 C mobo: N/A gpu: nvidia temp: 29 C
  Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
  Processes: 238 Uptime: 18m wakeups: 0 Memory: 3.79 GiB used: 1.28 GiB
  (33.8%) Init: systemd v: 251 default: graphical tool: systemctl
  Compilers: gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1803 pm: pacman
  pkgs: 1776 libs: 545 tools: octopi,pamac,paru pm: flatpak pkgs: 27
  Shell: Bash v: 5.1.16 running-in: qterminal inxi: 3.3.21
Alright, so I did a simple garuda update -a as usual, grub updated and then I rebooted.
I could get to grub, but the Garuda entry there couldn’t boot up and showed me an error I did not take notes on. I thought “oh well, snapshot it is then” and successfully booted into a snapshot, it prompted me to restore and reboot and so I did.
Except
All entries on Garuda now don’t boot, main kernel, second kernel, or snapshots. All give me this same error:
Loading Linux linux-lts ...
452: out of range pointer: 0xcc088520
Aborted. Press any key to continue. _
Ofc small variations on the message, for example for each snapshot I noticed a different pointer, but it always starts with 0xcc, so it’s all under the same trouble I guess.
After I press the key I fall back on my secondary system, which is Zorin, no troubles on that part, so at least my pc is usable until Garuda’s back. Haven’t tried Zorin directly from grub tho.
I found this post on the forum
But seems like the problem there was with timeshift? I’m using snapper, so I don’t know if the fix is the same or even the trouble.
Should I give it a try?
Or should I do something else?
That was a separate issue.
I fixed the pointer error by using chroot and following these steps
Maybe?
Summary
seth
Member
[SOLVED] Can't boot (452: out of range pointer: 0x86cb7020) / Kernel & Hardware / Arch Linux Forums
Re: [SOLVED] Can’t boot (452: out of range pointer: 0x86cb7020)
This is a filesystem/drive issue.
Could be a too aggressive trimming strategy or issues w/ the filesystem (any btrfs or f2fs over there?) or a power loss during the update.
Hmm no power loss, I also didn't do any trim? I only have Garuda as btrfs and I don't really know what f2fs is.
To be exact, I deleted 2 snapshots from january with the BTRFS tool from Garuda, it was before rebooting after updating. Would this be the problem?
I had a similar problem where after updating grub I went back a snapshot and then restoring the snapshot gave me a similar message.
The fix for this is chrooting into your system and reinstalling grub.
Try to follow this tutorial:
Ok, I'm trying to do the chroot thing, but my garuda partition is encrypted and I can't mount it.
I've found this explanation on reddit: https://www.reddit.com/r/archlinux/comments/nv297r/cant_chroot_into_encrypted_partition/
But here are my issues with that solution:
cryptsetup luksOpen /dev/sdb1 GarudaInstalled
Device /dev/sdb1 does not exist or access denied
After that I tried mounting the partition through Thunar and as it did mount properly I thought it would be nice to give a try, mounted or unmounted
sudo mount /dev/sdb1
mount: /dev/sdb1: cant find in /etc/fstab.
sudo mount /dev/mapper/luks-5b17384e-6g96-4fr0-80b7-423ffe50eaff
mount: /dev/mapper/luks-5b17384e-6g96-4fr0-80b7-423ffe50eaff: cant find in /etc/fstab.
Fair enough, that's probably because it was mounted inside the live system so it could not be found. But how come I can't open it with cryptsetup? What should I do?
Update: from Zorin, with udisksctl unlock -b /path/to/disk/partition I was able to unlock the partition, but turns out Zorin doesn't have chroot tools.
I'm gonna find out now if garuda have udisks2 and if that works there as well. Wish me luck.
Update on the matter: I was able open the encryption with gparted, then I successfully chrooted and reinstalled the grub
Thank you all so much for helping me out and maybe sorry because when I panick I get a bit dumb? And I panicked a LOT today xD
Thanks again, wish you all a wonderful end of the week!
