inxi -Faz:
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "pt_BR.UTF-8",
LC_NAME = "pt_BR.UTF-8",
LC_MONETARY = "pt_BR.UTF-8",
LC_PAPER = "pt_BR.UTF-8",
LC_IDENTIFICATION = "pt_BR.UTF-8",
LC_TELEPHONE = "pt_BR.UTF-8",
LC_MEASUREMENT = "pt_BR.UTF-8",
LC_TIME = "pt_BR.UTF-8",
LC_NUMERIC = "pt_BR.UTF-8",
LANG = "en_US.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.15.81-1-lts arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/.snapshots/2131/snapshot/boot/vmlinuz-linux-lts
root=UUID=33da784c-6400-4145-99e3-93bc3c7463b2 quiet
cryptdevice=UUID=5b16040e-5d39-4cd0-80b7-423ffe50eaff:luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
root=/dev/mapper/luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff splash
rootflags=defaults,noatime,noautodefrag,compress=zstd,[email protected]/.snapshots/2131/snapshot
Desktop: LXQt v: 1.2.0 tk: Qt v: 5.15.7 info: cairo-dock, lxqt-panel
Type: Desktop Mobo: INTEL model: HM65DESK serial: <superuser required>
UEFI: American Megatrends v: 4.6.5 date: 02/23/2019
Info: model: Intel Core i7-2620M bits: 64 type: MT MCP arch: Sandy Bridge
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3193 min/max: 800/3400 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3193 2: 3193 3: 3193 4: 3193 bogomips: 21552
Flags: avx ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3
prctl and seccomp
Device-1: NVIDIA GM107 [GeForce GTX 750] driver: nvidia v: 525.60.11
alternate: nouveau,nvidia_drm non-free: 520.xx+
status: current (as of 2022-10) arch: Maxwell code: GMxxx
process: TSMC 28nm built: 2014-19 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 2 speed: 5 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1381 class-ID: 0300
compositor: kwin_x11 driver: N/A display-ID: :0 screens: 1
Screen-1: 0 s-res: 1360x768 s-dpi: 90 s-size: 384x300mm (15.12x11.81")
s-diag: 487mm (19.18")
Monitor-1: HDMI-0 res: 1360x768 hz: 60 dpi: 49
size: 708x398mm (27.87x15.67") diag: 812mm (31.98") modes: N/A
API: OpenGL v: 4.6.0 NVIDIA 525.60.11 renderer: NVIDIA GeForce GTX
750/PCIe/SSE2 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Device-2: NVIDIA GM107 High Definition Audio [GeForce 940MX]
driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0fbc class-ID: 0403
Sound API: ALSA v: k5.15.81-1-lts running: yes
driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 2-1.5:3 chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s29u1u5 state: up mac: <filter>
Local Storage: total: 2.78 TiB used: 227.42 GiB (8.0%)
ID-1: /dev/sda maj-min: 8:0 model: SATA SSD size: 55.9 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD serial: <filter>
rev: Sb10 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST3000NM0053
size: 2.73 TiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
type: HDD rpm: 7200 serial: <filter> rev: G00A scheme: GPT
ID-1: / raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
used: 227.19 GiB (40.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-5b16040e-5d39-4cd0-80b7-423ffe50eaff
ID-2: /boot/efi raw-size: 5.59 GiB size: 5.58 GiB (99.80%)
used: 241.4 MiB (4.2%) fs: vfat dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-4: /var/log raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-5: /var/tmp raw-size: 558.79 GiB size: 558.79 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.79 GiB used: 94.8 MiB (2.4%) priority: 100
System Temperatures: cpu: 44.0 C mobo: N/A gpu: nvidia temp: 38 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 223 Uptime: 2m wakeups: 0 Memory: 3.79 GiB used: 1.74 GiB (45.8%)
Init: systemd v: 252 default: graphical tool: systemctl Compilers:
gcc: 12.2.0 alt: 11 clang: 14.0.6 Packages: 1800 pm: pacman pkgs: 1762
libs: 537 tools: octopi,pamac,paru pm: flatpak pkgs: 38 Shell: Bash
v: 5.1.16 running-in: qterminal inxi: 3.3.23
Hey, me again. This grub update can't give me a rest. So, last week I've had this same problem, but as I immediately went for a snapshot, and then the snapshot recover went wrong, I guess I didn't really solved my problem? Here's the previous post:
But after recovering my system I forgot I restored a snapshot and didn't update. Today my system told me it was out of date and I tried updating... but well, grub is being weird again.
I mean, I can get up to grub and select the Garuda entry, and I go past kernel and initram, but instead of getting the usual plymouth thing, I get only the header as usual, and then a fail, like so:
setfont: KDFONTOP: Function not implemented.
ERROR: device '/dev/mapper/luks-5c18030e-5d39-4cd0-60k7-423ffe50eaff' not found. Skipping fsck.
mount: /new_root: no filesystem type specified.
You are now being dropped into an emergency shell.
sh: can't access tty: job control turned off
[rootfs ]#
That's about it. I currently can boot into any snapshot, but haven't tried recovering any of them because, well, I did that last week and it didn't solve much apparently.
I truly need some help recovering the system and absolutely need help updating my grub properly without breaking everything before I go actually critically out of date.
