Grub Boots to Emergency Mode
Apologies for any bad formatting; first post
After a bios update my Garuda install is no longer detected. Fast boot and secure boot are both disabled. I followed this guide to reinstall grub but it results in:
error: invalid volume.
Installation finished.  No error reported.
then I ran update-grub:
Found theme: /usr/share/grub/themes/garuda-dr460nized/theme.txt
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-zen.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-zen-fallback.img
Found linux image: /boot/vmlinuz-linux-lts
Found initrd image: /boot/amd-ucode.img /boot/initramfs-linux-lts.img
Found fallback initrd image(s) in /boot:  amd-ucode.img initramfs-linux-lts-fallback.img
grub-probe: error: cannot find a GRUB drive for /dev/sdb1.  Check your device.map.
Adding boot menu entry for UEFI Firmware Settings ...
Detecting snapshots ...
Found snapshot: 2023-05-02 21:29:54 | @/.snapshots/204/snapshot | post | discord-canary                                                           |
Found snapshot: 2023-05-02 21:29:53 | @/.snapshots/203/snapshot | pre  | pacman -S discord-canary                                                 |
Found snapshot: 2023-05-02 19:50:00 | @/.snapshots/202/snapshot | post | discord        |
Found snapshot: 2023-05-02 19:49:59 | @/.snapshots/201/snapshot | pre  | pacman -R discord                                                        |
Found snapshot: 2023-04-30 20:56:27 | @/.snapshots/200/snapshot | post | amberol        |
Found snapshot: 2023-04-30 20:56:26 | @/.snapshots/199/snapshot | pre  | pacman -R amberol                                                        |
Found snapshot: 2023-04-30 20:56:10 | @/.snapshots/198/snapshot | post | amberol        |
Found snapshot: 2023-04-30 20:56:09 | @/.snapshots/197/snapshot | pre  | pacman -S amberol                                                        |
Found snapshot: 2023-04-30 20:47:03 | @/.snapshots/196/snapshot | post | garuda-welcome protontricks-git ttf-arimo-nerd ttf-fantasque-nerd ttf-fi |
Found snapshot: 2023-04-30 20:47:00 | @/.snapshots/195/snapshot | pre  | pacman -Su                                                               |
Found snapshot: 2023-04-29 19:52:07 | @/.snapshots/194/snapshot | post | a52dec amd-ucode appstream appstream-qt argon2 ckbcomp discord dtc dxvk- |
Found snapshot: 2023-04-29 19:49:39 | @/.snapshots/193/snapshot | pre  | pacman -Su                                                               |
Found 12 snapshot(s)
Unmount /tmp/grub-btrfs.1XtmsFdrXs .. Success
/usr/bin/grub-probe: warning: unknown device type nvme0n1.
done
Reboot and Garuda loads into emergency mode.
I am also dual booting Windows (separate drive) and that is now no longer detected in bios or grub. The Windows drive is not detected by lsblk either
Garuda Boot Repair did not work either.
Any help is appreciated!
edit: The windows drive is still accessible in dolphin
Welcome :slight_smile:
Thats why Garuda not support dual boot with M$
Post log include command from
efibootmgr
lsblk
sudo blkid
as text. Use live ISO.
Same here, what command you used? Full log needed :slight_smile:
Try also chroot from Garuda Welcome App, maybe it’s too late?
Since you are able to chroot, the first thing I'd try is to recheck carefully your /etc/fstab.
I'd also try setting temporarily GRUB_DISABLE_OS_PROBER=true in /etc/default/grub and update-grub again.
Edit: probably you can do all the above also from the emergency mode....
efibootmgr
BootCurrent: 0001
Timeout: 1 seconds
BootOrder: 0000,0001,0002
Boot0000* garuda        HD(1,GPT,b411455f-ed58-4879-a34b-b2dd62ef3aa4,0x800,0x32000)/File(\EFI\garuda\grubx64.efi)
Boot0001* UEFI: Generic-USB3.0 CRW -SD1.00      PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/CDROM(1,0x806b58,0x8000)0000424f
Boot0002* UEFI: Generic-USB3.0 CRW -SD1.00, Partition 2 PciRoot(0x0)/Pci(0x1,0x2)/Pci(0x0,0x0)/USB(6,0)/HD(2,MBR,0x0,0x806b58,0x2000)0000424f
lsblk
NAME        MAJ:MIN RM   SIZE RO TYPE MOUNTPOINTS
loop0         7:0    0  13.6M  1 loop /run/miso/sfs/livefs
loop1         7:1    0 409.4M  1 loop /run/miso/sfs/mhwdfs
loop2         7:2    0   2.8G  1 loop /run/miso/sfs/desktopfs
loop3         7:3    0   680M  1 loop /run/miso/sfs/rootfs
sda           8:0    0 232.9G  0 disk
├─sda1        8:1    0   100M  0 part /mnt/broken/@/boot/efi
│                                     /mnt/broken/@/boot/efi
├─sda2        8:2    0    16M  0 part
├─sda3        8:3    0 232.3G  0 part /run/media/garuda/F60CC3E70CC3A14B
└─sda4        8:4    0   509M  0 part
sdb           8:16   1 119.3G  0 disk
├─sdb1        8:17   1     4G  0 part /run/miso/bootmnt
└─sdb2        8:18   1     4M  0 part
sdc           8:32   1     0B  0 disk
zram0       253:0    0  15.5G  0 disk [SWAP]
nvme0n1     259:0    0 931.5G  0 disk
├─nvme0n1p1 259:1    0     1M  0 part
├─nvme0n1p2 259:2    0    15M  0 part
├─nvme0n1p3 259:3    0 431.7G  0 part
└─nvme0n1p4 259:4    0 499.8G  0 part /mnt/var/tmp
				      /mnt/var/log
				      /mnt/var/cache
				      /mnt/srv
				      /mnt/root
				      /mnt/home
				      /mnt
				      /mnt/broken/@
				      /mnt/broken
blkid
/dev/loop1: TYPE="squashfs"
/dev/nvme0n1p3: LABEL="Samsung 970 Evo 1TB" BLOCK_SIZE="512" UUID="BEE038F0E038B10F" TYPE="ntfs" PARTLABEL="LDM data partition" PARTUUID="32bc6f26-45e6-11ed-b9f4-b42e99edb583"
/dev/nvme0n1p4: UUID="a99d5415-9fa2-434e-b6c2-42da5a32fbc8" UUID_SUB="7f269ee6-9971-4aa6-ac12-49f15d4cb3cc" BLOCK_SIZE="4096" TYPE="btrfs" PTTYPE="dos" PARTLABEL="root" PARTUUID="fb5c11a1-e601-c147-89e8-47ab51955b29"
/dev/sdb2: SEC_TYPE="msdos" LABEL_FATBOOT="MISO_EFI" LABEL="MISO_EFI" UUID="1307-C5B0" BLOCK_SIZE="512" TYPE="vfat"
/dev/sdb1: BLOCK_SIZE="2048" UUID="2022-10-19-02-43-33-00" LABEL="GARUDA_DR460NIZEDGAMING_TALON" TYPE="iso9660"
/dev/loop2: TYPE="squashfs"
/dev/loop0: TYPE="squashfs"
/dev/sda4: BLOCK_SIZE="512" UUID="107C24B77C249A0C" TYPE="ntfs" PARTUUID="a7a73542-cc89-417e-ac03-a0c81b1d7623"
/dev/sda3: BLOCK_SIZE="512" UUID="F60CC3E70CC3A14B" TYPE="ntfs" PARTLABEL="Basic data partition" PARTUUID="2f8ba9c8-40b5-4b52-a884-40a9b52abbef"
/dev/sda1: UUID="21D2-CE93" BLOCK_SIZE="512" TYPE="vfat" PARTLABEL="EFI system partition" PARTUUID="b411455f-ed58-4879-a34b-b2dd62ef3aa4"
/dev/zram0: LABEL="zram0" UUID="befd13e2-62fc-4532-8ad6-281202ee3b4b" TYPE="swap"
/dev/loop3: TYPE="squashfs"
/dev/nvme0n1p1: PARTLABEL="LDM metadata partition" PARTUUID="32bc6f21-45e6-11ed-b9f4-b42e99edb583"
/dev/nvme0n1p2: PARTLABEL="Microsoft reserved partition" PARTUUID="0e672ec8-5bf6-4ebe-88c9-5e3a242cd880"
/dev/sda2: PARTLABEL="Microsoft reserved partition" PARTUUID="71e40ce4-2c1c-4e97-b8a9-3a6228c49f07"
misobasedir=garuda misolabel=GARUDA_DR460NIZEDGAMING_TALON quiet
systemd.show_status=1 ibt=off driver=nonfree nouveau.modeset=0
Console: pty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux
Type: Desktop Mobo: Gigabyte model: B550 AORUS ELITE serial: N/A
UEFI: American Megatrends LLC. v: F16c date: 03/23/2023
Info: model: AMD Ryzen 7 3800X socket: AM4 bits: 64 type: MT MCP
arch: Zen 2 gen: 3 level: v3 note: check built: 2020-22 process: TSMC n7
(7nm) family: 0x17 (23) model-id: 0x71 (113) stepping: 0
microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3900 min/max: 2200/4559 boost: enabled
base/boost: 3900/4550 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3900 2: 3900 3: 3900 4: 3900
5: 3900 6: 3900 7: 3900 8: 3900 9: 3900 10: 3900 11: 3900 12: 3900
13: 3900 14: 3900 15: 3900 16: 3900 bogomips: 124565
protection
Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: eVga.com. driver: nvidia
v: 520.56.06 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-10) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: 06:00.0 chip-ID: 10de:2507
Screen-1: 0 s-res: 3840x2160 s-dpi: 89 s-size: 1096x616mm (43.15x24.25")
s-diag: 1257mm (49.5")
Monitor-1: HDMI-0 res: 3840x2160 hz: 30 dpi: 89
size: 1095x616mm (43.11x24.25") diag: 1256mm (49.46") modes: N/A
OpenGL: renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2 v: 4.6.0 NVIDIA
520.56.06 direct render: Yes
Device-1: NVIDIA GA106 High Definition Audio vendor: eVga.com.
driver: snd_hda_intel v: kernel bus-ID: 1-9:8 pcie: chip-ID: 1b1c:0a6b
gen: 4 class-ID: 0300 serial: <filter> speed: 16 GT/s lanes: 8 link-max:
lanes: 16 bus-ID: 06:00.1 chip-ID: 10de:228e class-ID: 0403
bus-ID: 08:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Corsair HS80 RGB Wireless Gaming Receiver type: USB
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
bus-ID: 1-6.4.2:11 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 1.25 TiB used: 526.18 GiB (41.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 35.9 C scheme: GPT
SMART: yes health: PASSED on: 82d 4h cycles: 546 read-units: 15,705,404
[8.04 TB] written-units: 49,222,496 [25.2 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 EVO 250GB
family: based SSDs size: 232.89 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 29 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 180d 8h cycles: 2981
written: 18.77 TiB
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Generic model: USB3.0 CRW
-SD size: 119.25 GiB block-size: physical: 512 B logical: 512 B type: N/A
ID-1: swap-1 type: zram size: 15.52 GiB used: 1.71 GiB (11.0%)
System Temperatures: cpu: 38.8 C mobo: 27.0 C gpu: nvidia temp: 36 C
Processes: 360 Uptime: 22h 47m wakeups: 0 Memory: 15.52 GiB used: 5.41 GiB
(34.9%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1842 libs: 504
tools: octopi,paru Shell: garuda-inxi (sudo) default: Bash v: 5.1.16
Garuda (2.6.8-1):
System install date:     2023-05-04
Last full system update: 2023-05-04 ↻
command log
╭─garuda@garuda in ~ as 🧙 took 117ms
╰─λ sudo mkdir -p /mnt/broken
╭─garuda@garuda in ~ as 🧙 took 23ms
╰─λ sudo mount /dev/nvme0n1p4 /mnt/broken
╭─garuda@garuda in ~ as 🧙 took 67ms
╰─λ sudo garuda-chroot /mnt/broken/@
sh-5.1# parted -l | grep -iE "^Disk /|esp" | grep -B1 esp
Disk /dev/sda: 250GB
1      1049kB  106MB  105MB   fat32        EFI system partition          boot, esp, no_automount
Disk /dev/sdb: 128GB
2      4309MB  4313MB  4194kB  primary               esp
sh-5.1# mount /dev/sda1 /boot/efi
sh-5.1# grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=garuda --recheck
Installing for x86_64-efi platform.
sh-5.1# update-grub
done
sh-5.1# exit
exit
umount: /mnt/broken/@: target is busy.
Using chroot from Garuda Welcome gives a few invalid volume errors at first but is able to chroot
@filo disabling the OS prober results in a nearly identical result output but again still finishes, still boots to emergency mode
Sorry, I copied it here.
It's easier to read here than jumping back and forth between 6 websites :slight_smile:
greetings SGS
I cannot really understand where the problem could come from.
As said, check your /etc/fstab maybe there is something old left, or something has changed...
fstab seems to be fine based off what I've found online, though I'm relatively new to linux and don't quite know what to look for; I've never checked fstab before
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /              btrfs   subvol=/@,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /home          btrfs   subvol=/@home,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /root          btrfs   subvol=/@root,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /srv           btrfs   subvol=/@srv,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /var/cache     btrfs   subvol=/@cache,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /var/log       btrfs   subvol=/@log,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=a99d5415-9fa2-434e-b6c2-42da5a32fbc8 /var/tmp       btrfs   subvol=/@tmp,defaults,noatime,compress=zstd,discard=async,ssd 0 0
UUID=28C2-DB81                            /boot/efi      vfat    umask=0077 0 2
tmpfs                                     /tmp           tmpfs   defaults,noatime,mode=1777 0 0
Fstab seems ok. I assume the uuids did not change for a BIOS update.
I’m sorry but I really don’t understand what’s going on… :pensive:
Maybe it was a wrong BIOS update. Have you searched at your manufacturer site, forum, etc.
Maybe it is in relation to that strange LDM data partition.
Just a curiosity.
Can you see Garuda from BIOS?
Finally, it could very unlikely be that we’re searching in the wrong place and, instead of reinstalling the GRUB, you could try a garuda-update from inside the chroot.
It could have been a bad update or maybe you still needed a fix we implemented in Garuda migrations a few weeks ago.
Thanks for all your help so far!
Garuda is visible from bios, though, when booting, grub is very laggy with ~1 second delayed inputs, visible display refreshing, takes a lot longer to "boot" and pressing esc to view boot log doesn't work.
A bad bios update seems unlikely, the updates been out since March so it should be fine and normally updates for different model boards would error out before applying though I will look into it tomorrow.
My last update was a few days before the bios update, but I'll try that too.
Also, I was mistaken as windows is still viable in lsblk. After the bios update garuda wasn't visible in bios but windows was. After updating grub windows disappeared from bios & grub.
Could you try grub-install like before, but with --verbose? Maybe this helps finding out more about the invalid volume errors.
I didnt change anything but chroot from Garuda Welcome no longer as invalid volume errors :thinking:
Running garuda-update had the same invalid volume errors when updating grub, and there were a few errors for other things
: Running post-transaction hooks..
( 1/32) Restoring Linux kernel modules...
++ uname -r
+ KVER=6.0.2-zen1-1-zen
+ test -e /usr/lib/modules/backup/6.0.2-zen1-1-zen
+ rm -rf /usr/lib/modules/backup
( 2/32) Creating system user accounts...
( 3/32) Updating journal message catalog...
( 4/32) Reloading system manager configuration...
Skipped: Running in chroot.
( 5/32) Updating udev hardware database...
( 6/32) Applying kernel sysctl settings...
( 7/32) Creating temporary files...
Failed to open file "/sys/devices/system/cpu/cpu11/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu9/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu7/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu5/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu3/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu14/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu1/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu12/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu10/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu8/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu6/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu4/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu15/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu2/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu13/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/devices/system/cpu/cpu0/cpufreq/scaling_governor": Read-only file system
Failed to open file "/sys/module/zswap/parameters/enabled": Read-only file system
Failed to open file "/sys/module/pcie_aspm/parameters/policy": Read-only file system
Failed to open file "/sys/class/rtc/rtc0/max_user_freq": Read-only file system
and
==> Starting build: '6.3.1-zen1-1-zen'
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [modconf]
-> Running build hook: [block]
==> WARNING: Possibly missing firmware for module: 'aic94xx'
==> WARNING: Possibly missing firmware for module: 'bfa'
==> WARNING: Possibly missing firmware for module: 'qed'
==> WARNING: Possibly missing firmware for module: 'qla1280'
==> WARNING: Possibly missing firmware for module: 'qla2xxx'
==> WARNING: Possibly missing firmware for module: 'wd719x'
==> WARNING: Possibly missing firmware for module: 'xhci_pci'
-> Running build hook: [keyboard]
-> Running build hook: [keymap]
-> Running build hook: [consolefont]
-> Running build hook: [plymouth]
-> Running build hook: [filesystems]
-> Running build hook: [grub-btrfs-overlayfs]
==> Generating module dependencies
==> Creating zstd-compressed initcpio image: '/boot/initramfs-linux-zen-fallback.img'
==> Image generation successful
(15/32) Refreshing PackageKit...
Error connecting: Could not connect: No such file or directory
Rebooting and grub is still in emergency mode but the bios boot menu has a new grub option
Something to note is that Garuda is installed on my Samsung 970, not the 850, and before the bios update it said the correct drive, but lsblk lists the only vfat partition as on the 850 :thinking:
Is it possible for me to just reinstall and move my home directory?
@UltraBlack --verbose didn't seem to tell me any useful information other than adding relocation entries and occasionally writing bytes
"Fixed" the issue by reinstalling Garuda and moving my old home directory using this guide, marking as solved
2 posts were split to a new topic: Emergency mode after failing to mount
