Hello,
I’ve only been running Garuda for a couple of weeks, when on the 27-Aug, I updated. The reboot “failed”. I tried a few USB Boot recovery options including rolling back to a ealier snapshot and attempting to repair grub. Same issue.
I ended up reinstalling Garuda, but to a new partition as I wanted to keep my configs. It did the same once updated. While staring at screen for several minutes wondering what to do next, the grub boot came up and Garuda started no problems. It just took a loooong time for grub to start. Probably no need to re-install, if I had been patient, it would have eventually booted. But given grub was coming up in seconds prior to that update, who would think of waiting?
I don’t reboot often, but I did another update on 1-Sept. I have heard there was a problem with grub on Arch Installs, and grub was rolled back. However, I still have the same problem. Grub takes about 2 minutes to start.
So I followed the recovery procedure (to re-install grub) outlined here:
Rebooted again. This time it took 12 minutes for grub to load, as shown below:
sudo systemd-analyze
Startup finished in 9.700s (firmware) + 12min 252ms (loader) + 3.923s (kernel) + 10.550s (userspace) = 12min 24.427s
graphical.target reached after 10.549s in userspace.
Any ideas why the grub loader is taking so long? I assume the “loader” is grub. Obviously booting from my recovery USB meant I was back in the BIOS double checking boot settings. Still good (no fast boot). My inxi is below.
I love how quickly linux boots (especially i3), but I’m not impressed with grub.
sudo garuda-inxi
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=91f29d57-8423-442e-a227-98363728a986 rw rootflags=subvol=@
Desktop: i3 v: 4.20.1 info: i3bar dm: LightDM v: 1.32.0
Type: Mini-pc System: Fanless Mini PC product: Quieter 3 v: N/A
serial: <filter> Chassis: type: 35 serial: N/A
Mobo: Fanless Mini PC model: Rev JSL1 1.10 serial: N/A UEFI: American
Megatrends LLC. v: ML_JPL1V3.2 date: 06/16/2022
Device-1: hidpp_battery_0 model: Logitech MX Vertical Advanced Ergonomic
Mouse serial: <filter> charge: 55% (should be ignored) rechargeable: yes
Info: model: Intel Celeron N5105 socket: U3E1 bits: 64 type: MCP
arch: Tremont built: 2019 process: Intel 10nm family: 6
model-id: 0x9C (156) stepping: 0 microcode: 0x24000023
desc: d-4x32 KiB; i-4x32 KiB L2: 1.5 MiB desc: 1x1.5 MiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1841 high: 2000 min/max: 800/2900 base/boost: 900/2900
scaling: driver: intel_pstate governor: powersave volts: 0.6 V
ext-clock: 100 MHz cores: 1: 1931 2: 2000 3: 2000 4: 1434 bogomips: 15974
Type: mmio_stale_data mitigation: Clear CPU buffers; SMT disabled
filling, PBRSB-eIBRS: Not affected
Device-1: Intel JasperLake [UHD Graphics] driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: HDMI-A-2
empty: DP-1,HDMI-A-1,HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:4e61
Display: x11 server: X.Org v: 21.1.4 compositor: Picom v: git-7e568
driver: X: loaded: modesetting alternate: fbdev,intel,vesa gpu: i915
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: HDMI-A-2 mapped: HDMI-2 model: LG (GoldStar) ULTRAWIDE
serial: <filter> built: 2016 res: 3440x1440 hz: 60 dpi: 109 gamma: 1.2
size: 800x335mm (31.5x13.19") diag: 867mm (34.1") modes: max: 3440x1440
min: 640x480
Device-1: Intel Jasper Lake HD Audio vendor: Realtek driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:4dc8 class-ID: 0403
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
Device-1: Intel Wi-Fi 6 AX201 160MHz driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:4df0 class-ID: 0280
bus-ID: 01:00.0 chip-ID: 10ec:8168 class-ID: 0200
bus-ID: 1-8:5 chip-ID: 8087:0026 class-ID: e001
address: <filter>
Local Storage: total: 230.47 GiB used: 10.57 GiB (4.6%)
ID-1: /dev/mmcblk1 maj-min: 179:0 model: A3A444 size: 230.47 GiB
block-size: physical: 512 B logical: 512 B type: SSD serial: <filter>
rev: 0x8 scheme: GPT
ID-1: / raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 10.57 GiB
(6.7%) fs: btrfs block-size: 4096 B dev: /dev/mmcblk1p4 maj-min: 179:4
(0.2%) fs: vfat block-size: 512 B dev: /dev/mmcblk1p1 maj-min: 179:1
ID-3: /home raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 10.57
GiB (6.7%) fs: btrfs block-size: 4096 B dev: /dev/mmcblk1p4
maj-min: 179:4
ID-4: /var/log raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 10.57
maj-min: 179:4
ID-5: /var/tmp raw-size: 158.14 GiB size: 158.14 GiB (100.00%) used: 10.57
maj-min: 179:4
ID-1: swap-1 type: zram size: 7.52 GiB used: 0 KiB (0.0%) priority: 100
priority: -2 dev: /dev/mmcblk1p3 maj-min: 179:3
System Temperatures: cpu: 52.0 C mobo: N/A
Processes: 240 Uptime: 6m wakeups: 2 Memory: 7.52 GiB used: 2.35 GiB
(31.3%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1276 lib: 325
Shell: garuda-inxi (sudo) default: Bash v: 5.1.16 running-in: alacritty
inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2022-08-27
Last full system update: 2022-09-01
