Hi community,
after running sudo garuda-update today, I've encountered following in terminal output:
spawn pacman -Su grub
warning: downgrading package grub (2:2.06.r322.gd9b4638c5-1 => 2:2.06.r261.g2f4430cc0-1)
GRUB got updated a while back and I don't understand why it wants to downgrade now, and I would prefer if the bootloader is touched as less as possible. I didn't confirm the update for now.
Thanks in advance for any comments on this.
inxi:
Kernel: 5.19.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=21c7fde8-1bef-4f82-abc8-364dad2d6848 rw rootflags=subvol=@
resume=UUID=59131e58-a432-49f0-bae1-aebf3325230e loglevel=3 ibt=off
Type: Laptop System: HP product: OMEN by HP Laptop 15-dc1xxx v: N/A
Mobo: HP model: 8574 v: 21.17 serial: <superuser required> UEFI: AMI
v: F.22 date: 05/03/2021
ID-1: BAT0 charge: 46.3 Wh (100.0%) condition: 46.3/46.3 Wh (100.0%)
volts: 17.3 min: 15.4 model: HP Primary type: Li-ion serial: N/A
status: full
gen: core 9 built: 2018 process: Intel 14nm family: 6 model-id: 0x9E (158)
stepping: 0xD (13) microcode: 0xF0
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1594 high: 2600 min/max: 800/4500 scaling:
driver: intel_pstate governor: powersave cores: 1: 1300 2: 1300 3: 1234
4: 1300 5: 2600 6: 1300 7: 1122 8: 1300 9: 2600 10: 1177 11: 2600
12: 1300 bogomips: 62399
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Hewlett-Packard
driver: nvidia v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-07) arch: Turing code: TUxxx
process: TSMC 12nm built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
Device-2: Lite-On HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 04ca:707f class-ID: 0e02 serial: <filter>
compositors: 1: kwin_x11 2: Tabby driver: X: loaded: nvidia gpu: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 143 s-size: 341x191mm (13.43x7.52")
s-diag: 391mm (15.39")
Monitor-1: DP-2 res: 1920x1080 hz: 60 dpi: 142
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-2: NVIDIA TU106 High Definition Audio vendor: Hewlett-Packard
link-max: lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Sound Server-1: ALSA v: k5.19.5-zen1-1-zen running: yes
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 3c:00.0 chip-ID: 10ec:8168
speed: 5 GT/s lanes: 1 bus-ID: 3d:00.0 chip-ID: 8086:2723 class-ID: 0280
IF-ID-1: br-da2c536dbf10 state: down mac: <filter>
IF-ID-3: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
bus-ID: 1-7:4 chip-ID: 8087:0029 class-ID: e001
v: 3.0 port: 5020 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 1.84 TiB used: 65.04 GiB (3.4%)
model: MZVLB1T0HBLR-000H1 size: 953.87 GiB block-size: physical: 512 B
rev: HPS0NEXF temp: 43.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
ID-1: / raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 65.01 GiB
(7.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.45%) used: 27.5 MiB
(10.8%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 65.01 GiB
ID-4: /var/log raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 65.01
GiB (7.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-5: /var/tmp raw-size: 896.9 GiB size: 896.9 GiB (100.00%) used: 65.01
ID-1: swap-1 type: zram size: 31.23 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 34.36 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 68.0 C pch: 50.0 C mobo: N/A gpu: nvidia
temp: 53 C
Fan Speeds (RPM): cpu: 1983 fan-2: 0
Processes: 344 Uptime: 13m wakeups: 1 Memory: 31.23 GiB used: 5.51 GiB
(17.6%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 Packages: pacman: 1706 lib: 499 Shell: fish v: 3.5.1
running-in: tabby inxi: 3.3.20
Garuda (2.6.6-1):
System install date: 2021-07-24
Last full system update: 2022-08-30
Relevant software: tlp NetworkManager
Snapshots: Timeshift (maybe)
