Garuda Hyprland desktop without wallpaper & setup assistant not completed
Hi Iam newbie. I installed Garuda Hyprland decades. But problems not solved.
My graphic card is GT 610 so my drivers are open source.
1- My desktop is only black. Garuda wallpaper directory include too pictures. But I can’t see any picture on my wallpaper are. Only black.
I installad G-Hyprland. And change anything (waybar, rounded etc.). But not applied Background process. It is only black.
2- Setup assistant not finished perfectly. Because error: failed retrieving file wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst not downloaded, maximum size exceeded, not found. I add below full report for this:
[sudo] password for vburak:
 garuda is up to date
 core is up to date
 extra is up to date
 multilib is up to date
 chaotic-aur            16,0 KiB  1,00   B/s  chaotic-aur           287,2 KiB   452 KiB/s  chaotic-aur           760,8 KiB   700 KiB/s 00:01
 garuda downloading...
 core downloading...
 extra downloading...
 multilib downloading...
 chaotic-aur downloading...
spawn pacman -Su
:: Replace dbus-python with extra/python-dbus? [Y/n] y
resolving dependencies...
warning: dependency cycle detected:
warning: freetype2 will be installed before its harfbuzz dependency
warning: libcamera-ipa will be installed before its libcamera dependency
warning: lib32-pam will be installed before its lib32-systemd dependency
warning: insufficient columns available for table display
Packages (703) abseil-cpp-20240116.2-2
               adobe-source-code-pro-fonts-2.042u+1.062i+1.026vf-2
               adwaita-cursors-46.2-1
               adwaita-icon-theme-46.2-1
               adwaita-icon-theme-legacy-46.2-1
               alsa-card-profiles-1:1.2.1-1
Total Download Size:      0.11 MiB
Total Installed Size:  4922.54 MiB
Net Upgrade Size:        75.42 MiB
:: Retrieving packages...
 wayland-protocols-git-1.36.r10.g7d5a3a8-1-an wayland-protocols-git-1.36.r10.g7d5a3a8-1-anerror: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from cdn-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from geo-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from br-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from bg-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from ca-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from cl-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from de-2-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from de-3-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from de-4-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from fr-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from gr-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from in-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from in-2-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from in-3-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from in-4-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from kr-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from es-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from es-2-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from us-mi-mirror.chaotic.cx : Maximum file size exceeded
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from us-tx-mirror.chaotic.cx : Recv failure: Connection reset by peer
error: failed retrieving file 'wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst' from us-ut-mirror.chaotic.cx : Maximum file size exceeded
warning: failed to retrieve some files
error: failed to commit transaction (download library error)
--> Some downloads failed. Retrying...
spawn pacman -Su --config /tmp/tmp.wKTkfv2BF7
               zstd-1.5.6-1
Press enter to exit
Advanced Users Only :warning:
For Nvidia GPU
use garuda-update in terminal and please follow the template and post garuda-inxi on every help request.
GUM
My current desktop is: Imgur: The magic of the Internet
I press modekey + i and click install hyprland. Not see any process on my screen. Then ı entered Alaclaritty this command and give error:
sudo -E calamares -D8
sudo: calamares: command not found
My garuda-inxi:
[🔴] × garuda-inxi
  Kernel: 6.8.7-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=83b83e4b-9a48-4efc-8ef5-b0a695037fad rw rootflags=subvol=@
    quiet resume=UUID=495f7cca-91a9-47b5-a3f8-82df954a11df loglevel=3 ibt=off
  Desktop: Hyprland v: 0.39.1 with: waybar tools: avail: swayidle,swaylock
    vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: P43T-ES3G serial: <superuser required>
    uuid: <superuser required> BIOS: Award v: F8 date: 01/12/2012
  Info: model: Intel Core2 Quad Q6600 bits: 64 type: MCP arch: Core2 Merom
    level: v1 built: 2006-09 process: Intel 65nm family: 6 model-id: 0xF (15)
    stepping: 0xB (11) microcode: 0xBA
    desc: d-4x32 KiB; i-4x32 KiB L2: 8 MiB desc: 2x4 MiB
  Speed (MHz): avg: 1600 min/max: 1600/2400 scaling: driver: acpi-cpufreq
    governor: schedutil cores: 1: 1600 2: 1600 3: 1600 4: 1600 bogomips: 19200
  Flags: ht lm nx pae sse sse2 sse3 ssse3 vmx
  Device-1: NVIDIA GF119 [GeForce GT 610] driver: nouveau v: kernel non-free:
    series: 390.xx+ status: legacy (EOL~2022-11-22) last: release: 390.157
    kernel: 6.0 xorg: 1.21 arch: Fermi code: GF1xx process: 40/28nm
    built: 2010-2016 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 ports:
    active: VGA-1 empty: DVI-I-1,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:104a
    class-ID: 0300 temp: 44.0 C
    compositor: Hyprland v: 0.39.1 driver: X: loaded: nouveau
    unloaded: modesetting alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau
    display-ID: 1
  Monitor-1: VGA-1 res: 1920x1080 hz: 60 scale: 1 size: N/A modes:
    max: 1024x768 min: 640x480
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM
    17.0.6 128 bits) driver: mesa llvmpipe v: 24.0.5-arch1.1 (LLVM 17.0.6)
  Device-1: Intel 82801JI HD Audio vendor: Gigabyte GA-EP45-UD3R
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3a3e
  Device-2: NVIDIA GF119 HDMI Audio driver: snd_hda_intel v: kernel pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 bus-ID: 01:00.1 chip-ID: 10de:0e08
  API: ALSA v: k6.8.7-zen1-2-zen status: kernel-api tools: N/A
  Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
    lanes: 1 port: ce00 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Realtek RTL8187 Wireless Adapter driver: rtl8187 type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 0bda:8187
  IF: wlp0s26f7u5 state: down mac: <filter>
  Local Storage: total: 465.76 GiB used: 11.37 GiB (2.4%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST3500418AS
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    tech: HDD rpm: 7200 serial: <filter> fw-rev: CC46 scheme: MBR
  ID-1: / raw-size: 455.08 GiB size: 455.08 GiB (100.00%)
    used: 11.37 GiB (2.5%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /home raw-size: 455.08 GiB size: 455.08 GiB (100.00%)
  ID-3: /var/log raw-size: 455.08 GiB size: 455.08 GiB (100.00%)
  ID-4: /var/tmp raw-size: 455.08 GiB size: 455.08 GiB (100.00%)
  ID-1: swap-1 type: zram size: 9.71 GiB used: 0 KiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 10.68 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda2 maj-min: 8:2
  System Temperatures: cpu: 63.0 C mobo: N/A gpu: nouveau temp: 44.0 C
  Memory: total: 12 GiB note: est. available: 9.71 GiB used: 1.71 GiB (17.6%)
  Processes: 204 Power: uptime: 2m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 3.87 GiB Init: systemd v: 255
  Packages: 1249 pm: pacman pkgs: 1244 libs: 375 tools: pacseek,paru
    pm: flatpak pkgs: 5 Compilers: gcc: 13.2.1 Shell: garuda-inxi default: fish
    v: 3.7.1 running-in: alacritty inxi: 3.3.34
  System install date:     2024-07-19
  Last full system update: 2024-07-19
  Is partially upgraded:   Yes
I installed G-Hyprland via modekey+shift+g and I see on commandline gum and others installed.
There is no calamares in hyprland, only on the installer ISO. So, you can delete/forget the shortcut.
Fix this and use in terminal
upd
same like update and garuda-update.
GUM is now part of the Garuda Linux ISO.
Newbie, please don’t take up all the oxygen in the room. Please use another DE.
Yes partially updated. I said this on title. Because when I try Setup assistant or console via upd/garuda-update/update commands.
Everything’s result same
So not complete totally update and it give error and stay partial update.
https://archlinux.org/mirrors/status/
Use reflector and search for other mirrors.
Samples for reflector are in the forum.
Hi. I am using “Garuda Assistant” > Refresh Mirrorlist
It is autogenerated and save it /etc/pacman.d/mirrorlist for ex:
################# Arch Linux mirrorlist generated by Reflector #################
# With:       reflector --verbose -c BG -c DE -c TR --protocol https --sort rate --latest 10 --download-timeout 5
# When:       2024-07-20 19:06:48 UTC
# From:       https://archlinux.org/mirrors/status/json/
# Retrieved:  2024-07-20 19:06:48 UTC
# Last Check: 2024-07-20 19:04:16 UTC
## Germany
Server = https://mirror.moson.org/arch/$repo/os/$arch
## Germany
Server = https://mirror.pseudoform.org/$repo/os/$arch
## Germany
Server = https://mirror.ubrco.de/archlinux/$repo/os/$arch
## Bulgaria
Server = https://mirrors.uni-plovdiv.net/archlinux/$repo/os/$arch
## Germany
Server = https://arch.jensgutermuth.de/$repo/os/$arch
## Germany
Server = https://pkg.fef.moe/archlinux/$repo/os/$arch
## Germany
Server = https://de.arch.mirror.kescher.at/$repo/os/$arch
## Germany
Server = https://arch.phinau.de/$repo/os/$arch
## Germany
Server = https://archlinux.thaller.ws/$repo/os/$arch
## Germany
Server = https://packages.oth-regensburg.de/archlinux/$repo/os/$arch
Then I try “Setup Assistant” for totally update (or command garuda-update etc)
it give same error again and change the /etc/pacman.d/mirrorlist file. And results is same this error message.
Error message:
Then I try this process again but I add reflector generated list to /etc/pacman.d/chaotic-mirrorlist. It give results “new added mirrors not found ‘.garuda’ and ‘db’ files” And all process continue. As a result same error.
Error message:
For desktop wallpaper problem:
I try boot from live iso. I see desktop background same as installed system. Not see wallpaper both.
Me too same error.
I avoided it by following these steps:
  1. wget https://builds.garudalinux.org/repos/chaotic-aur/x86_64/wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst
  2. sudo pacman -U wayland-protocols-git-1.36.r10.g7d5a3a8-1-any.pkg.tar.zst
  3. execute setup assistant.
A post was split to a new topic: Unable to satisfy dependency 'libhyprutils.so=1-64
  • ONE issue per topic. :slight_smile:
    Please mark the post which solved your problem.
