Hi garuda team,
When i installed garuda - hyprland and enter password in login screen it doesn’t get started. Showing lock screen again and again.
Terminal was not opening
So i used ctrl+alt+F5
How to fix
Kindly help
Please use terminal text, not pictures, for garuda-inxi.
like this
I’m not an Hyprland user, but there are many others recently, so they’ll support better.
I was just wondering if you were using the garuda_hyprland login session, as described here:
How to copy and write from login terminal
root=UUID=aa4c88ea-fd27-4332-bcc1-5b96dfe11b4b rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.9 tk: Qt v: 5.15.11 wm: kwin_wayland vt: 1
Type: Laptop System: LENOVO product: 83BF v: IdeaPad Slim 5 14IAH8
serial: <superuser required> Chassis: type: 10 v: IdeaPad Slim 5 14IAH8
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN
serial: <superuser required> UEFI: LENOVO v: LACN25WW date: 05/25/2023
ID-1: BAT1 charge: 51.4 Wh (89.9%) condition: 57.2/56.6 Wh (101.0%)
power: 6.4 W volts: 12.8 min: 11.5 model: LGES L22L3PA4 type: Unknown
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse serial: <filter>
charge: 50% (should be ignored) rechargeable: yes status: N/A
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP
microcode: 0x42C
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled
cache: L1: 704 KiB desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB
L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 482 high: 1133 min/max: 400/4400:3300 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 657 3: 1133 4: 400
5: 400 6: 400 7: 400 8: 400 9: 400 10: 400 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Lenovo driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a3
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-5:3 chip-ID: 04f2:b7b9
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 23.2.1-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a3 memory: 14.99 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel
Graphics (ADL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:46a3 surfaces: xcb,xlib,wayland device: 1 type: cpu
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Server-1: PipeWire v: 0.3.84 status: active with: 1: pipewire-pulse
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:4 chip-ID: 0bda:4853
lmp-v: 12 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 476.94 GiB used: 12.89 GiB (2.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC
SN740 SDDPMQD-512G-1101 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 73110001 temp: 39.9 C scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 12.85 GiB (12.9%)
fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
used: 35.7 MiB (37.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%)
used: 12.85 GiB (12.9%) fs: btrfs dev: /dev/nvme0n1p6 maj-min: 259:6
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%)
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100
Src: /sys System Temperatures: cpu: 54.0 C mobo: N/A
Processes: 293 Uptime: 14m wakeups: 0 Memory: total: 16 GiB note: est.
available: 15.35 GiB used: 3.73 GiB (24.3%) Init: systemd v: 254
pm: pacman pkgs: 1510 libs: 424 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.31
Garuda (2.6.17-1):
System install date: 2023-11-05
Last full system update: 2023-11-07
i used garuda linux (KDE) to write garuda-inxi output.
Use ventoy, remove usb safely, check also sha sum, in BIOS cancel secure and fastboot.
yess i am using ventoy for iso installation
kindly help
as i have done all possible method
but nothing worked
If this is Hyprland, you are not choosing the correct session from the login screen.
Do you have more than one DE installed simultaneously?
No
But having triple boot
Means have win11 , garuda kde, Garuda hyprland
If they are separate installations, most likely your issue is having the wrong session selected on the login screen like I mentioned above.
No
Only have garuda-hypr nd hyprland
I have done it correctly
Even i choose both of them one by one
But nothing worked
I don’t think so because Hyprland cannot launch an Xorg session.
Try again to log in to Hyprland, then when it fails switch to the TTY, run these commands, and type the URLs the commands return into the thread:
garuda-inxi | tb
systemctl status display-manager | tb
Just popped up here to mention in case these commands fail to produce a link that’s most likely due to you not being connected to the internet. So,
- Ensure networkmanager is up,
sudo systemctl start NetworkManager.service
- Connect to the internet with network manager’s TUI utility
nmtui
Use
systemctl status display-manager | nc termbin.com 9999
garuda-inxi | nc termbin.com 9999
tb is the alias for nc termbin.com 9999
Showing invalid port specifications: garuda-inxi
(Sry you all guyz have to explain sso much because of my little knowledge)
Kindly help me
Not all one command like that, two separate lines please.
Kernel: 6.5.9-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1 clocksource: tsc
available: acpi_pm parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen
root=UUID=243eadb6-01d7-4291-9901-8a1e15679251 rw rootflags=subvol=@ quiet loglevel=3 ibt=off
Console: tty 5 DM: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: LENOVO product: 83BF v: IdeaPad Slim 5 14IAH8 serial: <superuser required>
Chassis: type: 10 v: IdeaPad Slim 5 14IAH8 serial: <superuser required>
Mobo: LENOVO model: LNVNB161216 v: SDK0T76485 WIN serial: <superuser required> UEFI: LENOVO
ID-1: BAT1 charge: 53.6 Wh (93.7%) condition: 57.2/56.6 Wh (101.0%) power: 15.5 W volts: 13.1
min: 11.5 model: LGES L22L3PA4 type: Unknown serial: <filter> status: charging
Info: model: 12th Gen Intel Core i5-12450H bits: 64 type: MST AMCP arch: Alder Lake gen: core 12
level: v3 note: check built: 2021+ process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154)
stepping: 3 microcode: 0x42C
Topology: cpus: 1x cores: 8 mt: 4 tpc: 2 st: 4 threads: 12 smt: enabled cache: L1: 704 KiB
desc: d-4x32 KiB, 4x48 KiB; i-4x32 KiB, 4x64 KiB L2: 7 MiB desc: 4x1.2 MiB, 1x2 MiB L3: 12 MiB
desc: 1x12 MiB
Speed (MHz): avg: 813 high: 3674 min/max: 400/4400:3300 scaling: driver: intel_pstate
governor: powersave cores: 1: 560 2: 1078 3: 400 4: 400 5: 3674 6: 400 7: 400 8: 400 9: 400
10: 1254 11: 400 12: 400 bogomips: 59904
Device-1: Intel Alder Lake-P GT1 [UHD Graphics] vendor: Lenovo driver: i915 v: kernel
arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports: active: eDP-1
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:46a3 class-ID: 0300
Device-2: Chicony Integrated Camera driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s
lanes: 1 mode: 2.0 bus-ID: 3-5:4 chip-ID: 04f2:b7b9 class-ID: fe01 serial: <filter>
Display: server: X.org v: 1.21.1.9 with: Xwayland v: 23.2.2 driver: X: loaded: modesetting
alternate: fbdev,intel,vesa dri: iris gpu: i915 tty: 240x75
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1457 built: 2022 res: 1920x1200 dpi: 162 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10 modes: 1920x1200
API: Vulkan v: 1.3.269 layers: 3 device: 0 type: integrated-gpu name: Intel Graphics (ADL GT2)
driver: mesa intel v: 23.2.1-arch1.2 device-ID: 8086:46a3 surfaces: N/A device: 1 type: cpu
name: llvmpipe (LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 23.2.1-arch1.2 (LLVM 16.0.6)
API: OpenGL Message: GL data unavailable in console, glxinfo missing.
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo driver: snd_hda_intel
v: kernel alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0403
Server-2: PipeWire v: 0.3.83 status: off with: 1: pipewire-pulse status: off 2: wireplumber
status: off 3: pipewire-alsa type: plugin 4: pw-jack type: plugin
Device-1: Realtek vendor: Lenovo driver: rtw89_8852be v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:b852 class-ID: 0280
Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 0bda:4853 class-ID: e001 serial: <filter>
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 5.3 lmp-v: 12 status:
discoverable: no pairing: no class-ID: 10c
Local Storage: total: 505.81 GiB used: 3.67 GiB (0.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: WD PC SN740 SDDPMQD-512G-1101
size: 476.94 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 73110001 temp: 37.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Sony model: Storage Media size: 28.88 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A
serial: <filter> fw-rev: PMAP scheme: GPT
ID-1: / raw-size: 100 GiB size: 100 GiB (100.00%) used: 3.64 GiB (3.6%) fs: btrfs
dev: /dev/nvme0n1p7 maj-min: 259:7
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 35.7 MiB (37.2%) fs: vfat
ID-3: /home raw-size: 100 GiB size: 100 GiB (100.00%) used: 3.64 GiB (3.6%) fs: btrfs
ID-4: /var/log raw-size: 100 GiB size: 100 GiB (100.00%) used: 3.64 GiB (3.6%) fs: btrfs
ID-5: /var/tmp raw-size: 100 GiB size: 100 GiB (100.00%) used: 3.64 GiB (3.6%) fs: btrfs
ID-1: swap-1 type: zram size: 15.35 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo,lzo-rle,lz4,lz4hc,842 max-streams: 12 dev: /dev/zram0
Src: /sys System Temperatures: cpu: 41.0 C mobo: N/A
Processes: 214 Uptime: 36m wakeups: 8120 Memory: total: 16 GiB note: est. available: 15.35 GiB
used: 915.4 MiB (5.8%) Init: systemd v: 254 default: graphical tool: systemctl Compilers:
gcc: 13.2.1 Packages: pm: pacman pkgs: 1189 libs: 354 tools: paru Shell: Bash v: 5.2.15
running-in: tty 5 inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2023-11-08
Last full system update: 2023-11-08
This is output from garuda-inxi
sddm.service - Simple Desktop Display Manager
Loaded: loaded (/usr/lib/systemd/system/sddm.service; enabled; preset: disabled)
Active: active (running) since Wed 2023-11-08 17:29:23 IST; 35min ago
Docs: man:sddm(1)
man:sddm.conf(5)
Main PID: 766 (sddm)
Tasks: 26 (limit: 18816)
Memory: 201.1M
CPU: 2.300s
CGroup: /system.slice/sddm.service
├─ 766 /usr/bin/sddm
└─3343 /usr/lib/Xorg -nolisten tcp -background none -seat seat0 vt2 -auth /run/sddm/xauth_TmhqOn -noreset -displayfd 18
Nov 08 17:49:38 Lenovo-HyPr sddm[766]: Loading theme configuration from "/usr/share/sddm/themes/Sweet/theme.conf"
Nov 08 17:49:38 Lenovo-HyPr sddm[766]: Greeter starting...
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: [PAM] Starting...
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: [PAM] Authenticating...
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: [PAM] returning.
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: pam_unix(sddm-greeter:session): session opened for user sddm(uid=958) by (uid=0)
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: Writing cookie to "/tmp/xauth_JpngAQ"
Nov 08 17:49:38 Lenovo-HyPr sddm-helper[3371]: Starting X11 session: "" "/usr/bin/sddm-greeter --socket /tmp/sddm-:0-ZbXKtR --theme /usr/share/sddm/themes/Sweet"
Nov 08 17:49:38 Lenovo-HyPr sddm[766]: Greeter session started successfully
Nov 08 17:49:38 Lenovo-HyPr sddm[766]: Message received from greeter: Connect
This is fromsystemctl status display-manager
@SGS @BluishHumility @NaN @filo
Please, do not ping the mods.
