Ok
I am sorry
Kindly help @SGS
I do not see any indication that Hyprland is installed.
Please describe how you have configured your triple boot setup. Are they all sharing one EFI partition? Can you see the other installations from Grub?
Let’s see more information please.
sudo parted -l | nc termbin.com 9999
lsblk -o name,type,fstype,size,mountpoint,uuid | nc termbin.com 9999
cat /etc/fstab | nc termbin.com 9999
efibootmgr | nc termbin.com 9999
termbin.com/gmml (parted)
termbin.com/d7zn (fstype)
termbin.com/9mau (fstab)
termbin.com/opw6 (efiboot)
I did triple boot
But then i removed all other distro and freshly installed the garuda hypr (i thinked might be prblm from triple boot).
But facing same issue after fresh install.
Please try from terminal
startx
OK, sorry, I see now the Hyprland doesn’t have the xorg-xinit
package installed. And normally shouldn’t need it, being based on Wayland.
So how to fix
Something is wrong with your installation. Hyprland can’t launch an Xorg session even if you wanted to, so whatever has happened here is not right.
Delete the ISO off your Ventoy, then re-download and be sure to verify the checksum.
You should be using garuda-hyprland-linux-zen-231029.iso
from the Downloads page: Garuda Linux | Download
Then reinstall again.
Ok
Let me try
termbin.com/wget (parted)
termbin.com/1ne0 (fstype)
termbin.com/wdk6 (fstab)
termbin.com/7zn0i (bootmgr)
termbin.com/v4bo3 (inxi)
termbin.com/jfn9 (network)
Kindly help
I have reinstall with corrected version
Please try running this command from the TTY:
hyprstart
If it fails, take a picture of the screen so we can see what happened.
Let’s take a look at that log.
cat /home/harsh/.hyprland/hyprlandCrashReport1917.txt | nc termbin.com 9999
Please post:
localectl list-keymaps | nc termbin.com 9999
cat /etc/vconsole.conf | nc termbin.com 9999
Ok
1 min
