Kernel: 5.18.3-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=40063dbf-d91d-46fd-90a6-9381ac54e802 rw rootflags=subvol=@
Type: Convertible System: LENOVO product: 81X2 v: IdeaPad Flex 5 14ARE05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14ARE05
Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
serial: <superuser required> UEFI: LENOVO v: EECN36WW date: 05/17/2021
ID-1: BAT0 charge: 33.7 Wh (63.6%) condition: 53.0/52.5 Wh (100.9%)
volts: 11.8 min: 11.6 model: LGC L19L3PD6 type: Li-poly serial: <filter>
status: discharging cycles: 527
Info: model: AMD Ryzen 7 4700U with Radeon Graphics bits: 64 type: MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x60 (96) stepping: 1
microcode: 0x8600106
Topology: cpus: 1x cores: 8 smt: <unsupported> cache: L1: 512 KiB
desc: d-8x32 KiB; i-8x32 KiB L2: 4 MiB desc: 8x512 KiB L3: 8 MiB
desc: 2x4 MiB
Speed (MHz): avg: 1403 high: 1453 min/max: 1400/2000 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1397 2: 1397
3: 1397 4: 1453 5: 1397 6: 1397 7: 1394 8: 1398 bogomips: 31941
STIBP: disabled, RSB filling
Device-1: AMD Renoir vendor: Lenovo driver: amdgpu v: kernel pcie: gen: 3
active: eDP-1 empty: HDMI-A-1 bus-ID: 04:00.0 chip-ID: 1002:1636
Device-2: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 1-4:3
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 mapped: eDP model: ChiMei InnoLux 0x1406 built: 2019
res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
OpenGL: renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.46 5.18.3-zen1-1-zen)
v: 4.6 Mesa 22.1.1 direct render: Yes
speed: 16 GT/s bus-ID: 04:00.1 chip-ID: 1002:1637 class-ID: 0403
snd_pci_acp6x, snd_acp_pci, snd_sof_amd_renoir
link-max: gen: 4 speed: 16 GT/s bus-ID: 04:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.18.3-zen1-1-zen running: yes
vendor: Lenovo driver: rtw_8822ce v: N/A modules: rtw88_8822ce pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 2000 bus-ID: 02:00.0 chip-ID: 10ec:c822
bus-ID: 3-4:3 chip-ID: 0bda:c123 class-ID: e001 serial: <filter>
address: <filter>
Local Storage: total: 476.94 GiB used: 30.16 GiB (6.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 model: NVME 512G size: 476.94 GiB
type: SSD serial: <filter> rev: T1102A0L temp: 35.9 C scheme: GPT
ID-1: / raw-size: 317.54 GiB size: 317.54 GiB (100.00%)
used: 29.75 GiB (9.4%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 8.6 MiB (2.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 317.54 GiB size: 317.54 GiB (100.00%)
ID-4: /var/log raw-size: 317.54 GiB size: 317.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 317.54 GiB size: 317.54 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.14 GiB used: 38.8 MiB (0.5%)
ID-2: swap-2 type: partition size: 10 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p7 maj-min: 259:7
System Temperatures: cpu: 40.0 C mobo: 39.0 C gpu: amdgpu temp: 39.0 C
Processes: 343 Uptime: 58m wakeups: 5 Memory: 7.14 GiB
used: 4.08 GiB (57.1%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1679 lib: 373 Shell: fish
v: 3.4.1 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-06-04
Last full system update: 2022-06-11 ↻
my problem is this
getting like this problem on every app i open how can i fix it
