So 2-3 times a day FireDragon will hang and eventually have to be terminated to close. All other applications continue to work normally. If I'm running journalctl -xf I just get errors like
Dec 01 18:22:21 umbra-rogstrixg513qm ananicy-cpp[678]: [2021-12-01 18:22:21.739] [info] firedragon(196089)
Dec 01 18:22:21 umbra-rogstrixg513qm kwin_x11[7181]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13865, resource id: 85983239, major code: 18 (ChangeProperty), minor code: 0
Dec 01 18:22:21 umbra-rogstrixg513qm kwin_x11[7181]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 13886, resource id: 83886216, major code: 18 (ChangeProperty), minor code: 0
Any ideas on what to do o figure out the hang-up or something I can monitor to catch what is causing the hang?
I ran that string through Google and it came up with numerous hits on similar strings. So the questions become; what have you done so far to resolve your problem? What have you read? What have you tried? What were the results?
Disabling extensions
Re-install FireDragon
Ran with only FireDragon open to make sure it wasn't a second application
Browsed in Private Browsing to make sure it wasn't some sort of cookie issue.
None of them resolved it. With that error I wasn't understanding how a KDE error was making only FireDragon lock up; none of the results I found seemed to be affecting web browsers.
ATTENTION: default value of option mesa_glthread overridden by environment.
JavaScript warning: https://www-league.nhlstatic.com/nhl.com/builds/site-core/1b0537abbccc0707356f2da3f3f794e06472cbf3_1636047209/scripts/site-core.js.gz, line 20: Using //@ to indicate sourceMappingURL pragmas is deprecated. Use //# instead
JavaScript error: resource://gre/modules/PromiseWorker.jsm, line 106: Error: Could not get children of file(/home/umbra/.cache/firedragon/rs8toeq0.default-release/thumbnails) because it does not exist
JavaScript error: https://i5.wal.co/dfw/63fd9f59-b226/8bd6870f-321a-4b50-87bf-5857c87a981e/v2/_next/static/chunks/pages/_app-8d6a555c1b1a4de6092e.js-1eae6fe200e1bd6ab9a5987fd668b19530aa5344-br.js, line 1: TypeError: performance.getEntriesByType(...)[0] is undefined
JavaScript error: https://i5.wal.co/dfw/63fd9f59-7275/3dfe2698-6207-4315-89ae-23581b7a8107/v2/_next/static/chunks/pages/_app-51d59204bdd1146c7d84.js-c4df5def1126fb09336c3b1d9d0d66e77fa91991-br.js, line 1: TypeError: performance.getEntriesByType(...)[0] is undefined
Port.onMessage event fired while context is inactive.
JavaScript error: moz-extension://6e53f04a-ea1c-489a-9dc2-5a82383662bd/js/content.js, line 11: TypeError: a.data is undefined
JavaScript error: undefined, line 0: Error: sender.tab is undefined
JavaScript error: resource://gre/modules/XULStore.jsm, line 66: Error: Can't find profile directory.
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=ez9S8PS2E3I&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
JavaScript error: https://www.redditstatic.com/desktop2x/Chat~RedesignChat.6d8aa77626ea3a0c3f30.js, line 1: TypeError: window.navigator.serviceWorker is undefined
JavaScript error: https://assets.mofoprod.net/static/_js/bg-main.compiled.9e3dda22c337.js, line 23: TypeError:e is null
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=bLQvS2IxDtY&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=mZU9sbtU0mc&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=clNL1RdgRsI&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=651lQyuFtJE&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
JavaScript error: moz-extension://6dbfbe75-64ef-4e3e-bf07-c537ad52eb71/foreground.entry.js, line 4421: Error: https://www.googleapis.com/youtube/v3/videos?id=b1vnLKfHLqI&part=id%2CcontentDetails%2Csnippet%2Cstatistics&fields=items%28id%2CcontentDetails%28duration%29%2Csnippet%28title%2CpublishedAt%29%2Cstatistics%28viewCount%29%29&key=AIzaSyB8ufxFN0GapU1hSzIbuOLfnFC0XzJousw failed with status 400
Exiting due to channel error.
Crash Annotation GraphicsCriticalError: |[C0][GFX1-]: Receive IPC close with reason=AbnormalShutdown (t=21914.8) Exiting due to channel error.
fish: Job 1, 'firedragon' terminated by signal SIGKILL (Forced quit)
This is what it showed when it ended, before this was JS errors that something on reddit was undefined
Scrolled up and saw this chain too after a critical flag
(FireDragon:10103): LIBDBUSMENU-GTK-CRITICAL **: 00:34:44.600: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed
JavaScript error: , line 0: NotAllowedError: The play method is not allowed by the user agent or the platform in the current context, possibly because the user denied permission.
JavaScript error: https://toddshelton.com/blog/wp-content/cache/autoptimize/js/autoptimize_f51cc930326d1194394a65d0f320f742.js, line 33: TypeError: i is null
JavaScript error: moz-extension://9d15809b-73dc-48da-8914-5be5143cd1a3/core_js/google_link_fix.js, line 38: TypeError: s is undefined
JavaScript error: moz-extension://b092fe9b-f2d2-41c6-ab57-522f69482f59/content-script.js, line 901: InvalidCharacterError: String contains an invalid character
JavaScript error: resource://gre/modules/ConduitsChild.jsm, line 63: InvalidStateError: JSWindowActorChild.sendAsyncMessage: JSWindowActorChild cannot send at the moment
JavaScript error: moz-extension://65881c0a-fa80-4e4c-8426-2e28cedaa678/js/vapi-client.js, line 228: InvalidStateError: An exception was thrown
JavaScript error: resource://gre/modules/ExtensionContent.jsm, line 489: TypeError: window is null
JavaScript error: , line 0: uncaught exception: Object
JavaScript error: , line 0: TypeError: NetworkError when attempting to fetch resource.
JavaScript error: , line 0: uncaught exception: undefined
Looks like a lot of extensions, and a lot of javascript. Each of these extensions is like a whole other program running inside your browser. Even with 16GiB RAM there’s only so much you can expect. Consider trying to run a more minimalist configuration of Firedragon and see there is improvement.
I ran no extensions and it sill happened in earlier testing.
I tried to launch FireDragon again while it was hung-up and this is the error I got
╭─umbra@umbra in ~ took 25s
[🧱] × firedragon
(FireDragon:328023): Gtk-WARNING **: 20:30:03.488: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is not a valid color name
(FireDragon:328023): Gtk-WARNING **: 20:30:03.488: Theme parsing error: gtk-dark.css:5825:14: not a number
(FireDragon:328023): Gtk-WARNING **: 20:30:03.488: Theme parsing error: gtk-dark.css:5826:13: not a number
(FireDragon:328023): Gtk-WARNING **: 20:30:03.488: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Well that's not helpful isn't it I don't know what to tell you - mine also crashes every so often but not too often to annoy me yet. Could be there's an actual stability issue in the most recent release of Firefox, or in the build
Full error if I try to launch a second firedragon while it's hanging up
╭─umbra@umbra in ~
╰─λ firedragon
(FireDragon:341577): Gtk-WARNING **: 07:19:44.797: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is nota valid color name
(FireDragon:341577): Gtk-WARNING **: 07:19:44.797: Theme parsing error: gtk-dark.css:5825:14: not a number
(FireDragon:341577): Gtk-WARNING **: 07:19:44.797: Theme parsing error: gtk-dark.css:5826:13: not a number
(FireDragon:341577): Gtk-WARNING **: 07:19:44.797: Theme parsing error: gtk-dark.css:5827:11: Expected a length
^[[A
(FireDragon:341577): Gtk-WARNING **: 07:20:15.081: Theme parsing error: gtk.css:5822:26: '-shadow' is not a valid color name
(FireDragon:341577): Gtk-WARNING **: 07:20:15.081: Theme parsing error: gtk.css:5825:14: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.081: Theme parsing error: gtk.css:5826:13: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.081: Theme parsing error: gtk.css:5827:11: Expected a length
(FireDragon:341577): Gtk-WARNING **: 07:20:15.129: Theme parsing error: gtk.css:5822:26: '-shadow' is not a valid color name
(FireDragon:341577): Gtk-WARNING **: 07:20:15.129: Theme parsing error: gtk.css:5825:14: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.129: Theme parsing error: gtk.css:5826:13: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.129: Theme parsing error: gtk.css:5827:11: Expected a length
(FireDragon:341577): Gtk-WARNING **: 07:20:15.152: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is nota valid color name
(FireDragon:341577): Gtk-WARNING **: 07:20:15.152: Theme parsing error: gtk-dark.css:5825:14: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.152: Theme parsing error: gtk-dark.css:5826:13: not a number
(FireDragon:341577): Gtk-WARNING **: 07:20:15.152: Theme parsing error: gtk-dark.css:5827:11: Expected a length
Step 3: Now in the cart, I click back on the name of the mask to be re-directed back to the store page for the mask.
Step 4: Click 'Add to Cart'.
Step 5: Repeat.
Currently I get the hang-up until killed error every time after 1-3 times of clicking 'Add to Cart'
Below is full terminal output with the Garuda FireDragon theme disabled and all extensions off.
╰─λ firedragon
(FireDragon:369558): Gtk-WARNING **: 08:30:39.881: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is nota valid color name
(FireDragon:369558): Gtk-WARNING **: 08:30:39.881: Theme parsing error: gtk-dark.css:5825:14: not a number
(FireDragon:369558): Gtk-WARNING **: 08:30:39.881: Theme parsing error: gtk-dark.css:5826:13: not a number
(FireDragon:369558): Gtk-WARNING **: 08:30:39.881: Theme parsing error: gtk-dark.css:5827:11: Expected a length
console.error: Enterprise Policies:
Unknown policy: policies
Icon theme "gnome" not found.
(FireDragon:369558): Gtk-WARNING **: 13:30:40.154: Theme parsing error: gtk.css:5822:26: '-shadow' is not a valid color name
(FireDragon:369558): Gtk-WARNING **: 13:30:40.154: Theme parsing error: gtk.css:5825:14: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.154: Theme parsing error: gtk.css:5826:13: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.154: Theme parsing error: gtk.css:5827:11: Expected a length
(FireDragon:369558): Gtk-WARNING **: 13:30:40.196: Theme parsing error: gtk.css:5822:26: '-shadow' is not a valid color name
(FireDragon:369558): Gtk-WARNING **: 13:30:40.196: Theme parsing error: gtk.css:5825:14: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.196: Theme parsing error: gtk.css:5826:13: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.196: Theme parsing error: gtk.css:5827:11: Expected a length
(FireDragon:369558): Gtk-WARNING **: 13:30:40.218: Theme parsing error: gtk-dark.css:5822:26: '-shadow' is nota valid color name
(FireDragon:369558): Gtk-WARNING **: 13:30:40.218: Theme parsing error: gtk-dark.css:5825:14: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.218: Theme parsing error: gtk-dark.css:5826:13: not a number
(FireDragon:369558): Gtk-WARNING **: 13:30:40.218: Theme parsing error: gtk-dark.css:5827:11: Expected a length
(FireDragon:369558): LIBDBUSMENU-GTK-CRITICAL **: 13:30:40.705: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed
Hello, i had similar issues and there was another post for probably the same issue:
Disabling hardware acceleration in firedragon fixed the issue for me, though i still get the same errors when starting firedragon from commandline. All it fixed was the freezing of firedragon i got.
Tried it, makes my firedragon freeze even with HA disabled. HA appearently just fixed my freezes when resizing or dragging the window.
Let's hope next version will fix the issue
