Hey there guys, so I have a weird issue. It seems to be something related to me missing a package maybe to do with bat? Basically, there was an error in the config.fish file where the bat/cat alias would not work. I have now fixed that but after sourcing the file and relogging in, I get this message appearing when I do something such as sudo pacman -S xx. It happens when I press the tab button to autocomplete the text for installing a package and I don't know why. The error message is:
error: Invalid value "header--style" for '--style <components>': Unknown style, 'header--style'
Kernel: 5.19.9-2-bore arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-bore
root=UUID=95b636ca-42a5-47b4-9b7a-038581af6cdf rw rootflags=subvol=@
mitigations=off quiet splash rd.udev.log_priority=3
vt.global_cursor_default=0
resume=UUID=41193397-191d-45b5-8c2b-405cf71e73b2 loglevel=3
wm: kwin_wayland vt: 2 dm: SDDM Distro: Garuda Linux base: Arch Linux
Type: Laptop System: ASUSTeK product: X510UA v: 1.0
Mobo: ASUSTeK model: X510UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends v: X510UA.312 date: 04/29/2020
ID-1: BAT0 charge: 13.7 Wh (73.7%) condition: 18.6/42.1 Wh (44.3%)
volts: 11.5 min: 11.5 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: charging cycles: 511
Info: model: Intel Core i7-7500U bits: 64 type: MT MCP
arch: Amber/Kaby Lake note: check gen: core 7 level: v3 built: 2017
process: Intel 14nm family: 6 model-id: 0x8E (142) stepping: 9
microcode: 0xF0
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 495 high: 500 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 485 2: 500 3: 498 4: 500
bogomips: 23220
Type: l1tf mitigation: PTE Inversion; VMX: vulnerable
Type: mds status: Vulnerable; SMT vulnerable
Type: meltdown status: Vulnerable
Type: mmio_stale_data status: Vulnerable
Type: retbleed status: Vulnerable
Type: spectre_v2 status: Vulnerable, IBPB: disabled, STIBP: disabled,
PBRSB-eIBRS: Not affected
Type: srbds status: Vulnerable
Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel
empty: HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
Device-2: IMC Networks VGA UVC WebCam type: USB driver: uvcvideo
bus-ID: 1-6:2 chip-ID: 13d3:5a07 class-ID: 0e02 serial: <filter>
Display: wayland server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
alternate: fbdev,intel,vesa gpu: i915 display-ID: 0
OpenGL: renderer: Mesa Intel HD Graphics 620 (KBL GT2) v: 4.6 Mesa 22.1.7
direct render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK
Sound Server-1: ALSA v: k5.19.9-2-bore running: yes
Device-1: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:24fd class-ID: 0280
bus-ID: 1-8:3 chip-ID: 8087:0a2b class-ID: e001
address: <filter>
Local Storage: total: 931.52 GiB used: 580.42 GiB (62.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO M.2 500GB
ID-1: / raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 129.04 GiB
(28.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 32.1 MiB
(10.7%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 129.04
GiB (28.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-4: /var/log raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 129.04
ID-5: /var/tmp raw-size: 448.4 GiB size: 448.4 GiB (100.00%) used: 129.04
ID-1: swap-1 type: zram size: 15.52 GiB used: 2.5 MiB (0.0%)
ID-2: swap-2 type: partition size: 17.06 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 60.0 C pch: 41.0 C mobo: N/A
Fan Speeds (RPM): cpu: 2600
Processes: 247 Uptime: 43m wakeups: 4 Memory: 15.52 GiB used: 3.18 GiB
(20.5%) Init: systemd v: 251 default: graphical tool: systemctl
Compilers: gcc: 12.2.0 clang: 14.0.6 Packages: pm: pacman pkgs: 1629
libs: 377 tools: pamac,paru Shell: fish v: 3.5.1 running-in: yakuake
inxi: 3.3.21
Garuda (2.6.7-1):
System install date: 2022-05-27
Last full system update: 2022-09-21 ↻
Failed units: mnt-backups.mount systemd-sysctl.service```
