This is related to this issue of SVP not launching that is still unresolved.
clinfo command gives this
Abort was called at 36 line in file:
/usr/src/debug/intel-compute-runtime/compute-runtime-23.09.25812.14/shared/source/built_ins/built_ins.cpp
fish: Job 1, 'clinfo' terminated by signal SIGABRT (Abort)
I ran garuda-update and re-installed NVidia drivers with nvidia-all.
My inxi
Kernel: 6.3.8-x64v1-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw rootflags=subvol=@
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_x11 vt: 1
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 42.4 Wh (100.0%) condition: 42.4/58.8 Wh (72.2%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1891 high: 2600 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 2600 2: 2600 3: 900
4: 2600 5: 900 6: 2600 7: 2600 8: 900 9: 900 10: 900 11: 2600 12: 2600
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 535.54.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6.0 NVIDIA 535.54.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.3.8-x64v1-xanmod1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.71 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
address: <filter>
Local Storage: total: 6.83 TiB used: 1.28 TiB (18.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 54.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
model: WD40NDZW-11A8JS1 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B type: USB rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
tech: HDD rpm: 5400 serial: <filter> fw-rev: 1023 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 472.96 GiB (25.5%)
fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 472.96 GiB (25.5%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 14.5 MiB (0.1%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
System Temperatures: cpu: 52.0 C pch: 72.0 C mobo: N/A gpu: nvidia
temp: 53 C
Processes: 380 Uptime: 3m wakeups: 1 Memory: available: 15.45 GiB
used: 3.76 GiB (24.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 11/12 clang: 15.0.7 Packages:
pm: pacman pkgs: 2130 libs: 559 tools: octopi,pamac,paru Shell: fish
v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2021-11-24
Last full system update: 2023-06-17
