SVP Fails to Start
SVP has been working fine on Linux up until last week. Now I get this:
15:58:56.181 [i]: Main: starting up SVP 4 Linux [4.5.0.210]...
15:58:56.182 [i]: Main: args: none
15:58:56.182 [i]: Main: working dir is /home/hanuman/Apps/SVP 4/
15:58:56.182 [i]: Main: data dir set to /home/hanuman/.local/share/SVP4/
15:58:56.182 [i]: Settings: loading reg.cfg OK
15:58:56.183 [i]: Settings: loading main.cfg OK
15:58:56.183 [i]: Settings: loading ui.cfg OK
15:58:56.183 [i]: Settings: loading frc.cfg OK
15:58:56.183 [i]: Settings: loading profiles.cfg OK
15:58:56.184 [i]: Settings: loading custom.cfg OK
15:58:56.184 [i]: Settings: loading lights.cfg OK
15:58:56.184 [i]: Main: using Qt 5.15.9 (x86_64-little_endian-lp64 shared (dynamic) release build; by GCC 12.2.1 20230201)
15:58:56.184 [i]: Main: device scale is 1.00132, user defined scale is 1
15:58:56.185 [i]: Main: system locale is [en]
15:58:56.185 [i]: Main: preferred language is [en-us]
15:58:56.186 [i]: Main: setting language file to en.qm...
15:58:56.189 [i]: Main: collecting system information...
15:58:56.190 [i]: Main: module 'plugins/libsvpflow1_vs64.so': 4.5.0.205
15:58:56.190 [i]: Main: module 'plugins/libsvpflow2_vs64.so': 4.5.0.212
15:58:56.191 [i]: Main: VLC filter (64 bit): 1.0.0.182
15:58:56.195 [i]: OS: Linux 6.3.2-x64v1-xanmod1-1 #1 SMP PREEMPT_DYNAMIC Sat, 13 May 2023 04:32:43 +0000 x86_64
15:58:56.210 [i]: Desktop environment: /usr/bin/sddm / plasma / kde
15:58:56.212 [i]: CPU: Intel Core i7-10750H [base frequency 3560 MHz, 12 threads]
15:58:56.212 [i]: Video: reading OpenCL info...
Abort was called at 36 line in file:
Asked the dev, he says "Looks like corruption in OpenCL."
Is there a bug in recent driver updates or something?
Kernel: 6.3.2-x64v1-xanmod1-1 arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-xanmod
root=UUID=58203bda-e2e2-4c32-a006-c91d933cad4e rw [email protected]
loglevel=3 quiet intel_iommu=on iommu=pt ibt=off
Type: Laptop System: Acer product: Predator PH315-53 v: V1.01
Mobo: CML model: QX50_CMS v: V1.01 serial: <superuser required>
UEFI: Insyde v: 1.01 date: 04/27/2020
ID-1: BAT1 charge: 42.6 Wh (100.0%) condition: 42.6/58.8 Wh (72.5%)
volts: 16.4 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF6
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 1960 high: 2600 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 1800 2: 1800 3: 2103
4: 1800 5: 1818 6: 1804 7: 2600 8: 2600 9: 1800 10: 1800 11: 1800 12: 1800
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-1 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 530.41.03
alternate: nvidiafb,nouveau,nvidia_drm non-free: 530.xx+
status: current (as of 2023-05) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:1f15 class-ID: 0300
Device-3: Quanta HD User Facing driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 0408:a061
class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Monitor-1: HDMI-A-2 mapped: HDMI-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: 1920x1080 hz: 60 dpi: 40
gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 1168mm (46") ratio: 16:9
Monitor-2: eDP-1 mapped: eDP-1-1 note: disabled model: AU Optronics 0x82ed
built: 2018 res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
API: OpenGL v: 4.6.0 NVIDIA 530.41.03 renderer: NVIDIA GeForce RTX
2060/PCIe/SSE2 direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_cnl
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.3:6 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.3.2-x64v1-xanmod1-1 status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks
driver: iwlwifi v: kernel bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
Device-2: Realtek vendor: Acer Incorporated ALI driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 08:00.0
chip-ID: 10ec:2600 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Report: bt-adapter ID: hci0 rfk-id: 1 state: down
address: <filter>
Local Storage: total: 3.19 TiB used: 1.22 TiB (38.1%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 50.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.81 TiB size: 1.81 TiB (100.00%) used: 473.1 GiB (25.6%)
used: 51.2 MiB (53.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
used: 473.1 GiB (25.6%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
ID-4: /var/log raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.81 TiB size: 1.81 TiB (100.00%)
ID-1: swap-1 type: zram size: 15.45 GiB used: 11.8 MiB (0.1%)
ID-2: swap-2 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p2 maj-min: 259:4
System Temperatures: cpu: 55.0 C pch: 66.0 C mobo: N/A gpu: nvidia
temp: 54 C
Processes: 394 Uptime: 8h 23m wakeups: 1 Memory: available: 15.45 GiB
used: 5.64 GiB (36.5%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 alt: 11/12 clang: 15.0.7 Packages:
pm: pacman pkgs: 2116 libs: 558 tools: octopi,pamac,paru pm: appimage
pkgs: 0 Shell: fish v: 3.6.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.27
System install date:     2021-11-24
Last full system update: 2023-05-14
Failed units:            systemd-oomd.socket
I tried re-installing the latest video drivers with nvidia-all but that did not solve the issue.
