Were you able to find a package that works for certain?
Yes
works perfect
thank you
Unable to install libadwaita-without-adwaita-git
failed to resolve glib2-devel
dependency
for a second I thought âIsnât that one of Arnold Schönbergâs students?â Schönberg invented dodekaphony, which is why I got really confused lol.
His studentâs name wasnât âAlan Bergâ. It was âAlban BergââŠ
Iâm not sure what would cause this. Do you by chance have unmerged .pacnew
files? glib2-devel is in core so not something I can simply rebuild to fix Arch Linux - glib2-devel 2.80.3-2 (x86_64)
A post was split to a new topic: Mint-Y-Purple theme makes the buttons and highlights green
The dependencies for hyprland-git
in chaotic-aur donât match the AUR repo causing updates to be blocked. The chaotic-aur
has hard dep on libdisplay-info
v1-64 when itâs been updated to v2-64 in the upstream arch repos.
chaotic-aur/hyprland-git
Depends On : cairo gcc-libs glib2 glibc glslang hyprutils hyprcursor hyprwayland-scanner libdisplay-info libdrm libglvnd libinput libliftoff libx11 libxcb libxcomposite libxfixes libxkbcommon libxrender mesa opengl-driver pango pixman polkit seatd systemd-libs tomlplusplus wayland wayland-protocols xcb-proto xcb-util xcb-util-errors xcb-util-image xcb-util-keysyms xcb-util-renderutil xcb-util-wm xorg-xinput xorg-xwayland libdisplay-info.so=1-64 libhyprlang.so=2-64
AUR/hyprland-git
Depends On : cairo gcc-libs glib2 glibc glslang hyprutils hyprcursor hyprlang hyprwayland-scanner libdisplay-info libdrm libglvnd libinput libliftoff libx11 libxcb libxcomposite libxfixes libxkbcommon libxrender mesa opengl-driver pango pixman polkit seatd systemd-libs tomlplusplus wayland wayland-protocols xcb-proto xcb-util xcb-util-errors xcb-util-image xcb-util-keysyms xcb-util-renderutil xcb-util-wm xorg-xinput xorg-xwayland libdisplay-info.so
Should be able to just rebuild against new libs. If that doesnât help, then we have bigger problems caused by the interfere we use for deps.
@NaN Can you confirm fix? Finished making: hyprland-git 0.41.1.r57.0b924f54-1.1 (Sat 22 Jun 2024 07:29:28 PM CEST)
Yup, can install updated version of hyprland-git
now.
Any chance on adding Superfile the chaotic?
Hi all!
I would like to request Surfsharkâs client to be added to the chaotic-aur:
https://aur.archlinux.org/packages/surfshark-client
Thank you!
Unfortunately that would not be a great thing for us to add. Itâs currently a Debian deb file for source (we try to avoid those as much as possible), and doesnât actually take much (if any) power to compile, so it would effectively be âwastedâ mirror space. Thanks for politely requesting
See also my reply about surfshark here:
Thatâs good to know, Iâll keep in mind for the future!
Thankfully as you say, building it from the AUR doesnât take long.
Cheers!
A post was split to a new topic: Request for the gutenprint package to be apart of the ISO
Cava fails after install. Building the cava-git from the aur. The pkg works as expected.
cava
cava: error while loading shared libraries: libiniparser.so.1: cannot open shared object file: No such file or directory
I bumped to rebuild, give it a try?
Finished making: cava 0.10.2-2.1 (Thu 11 Jul 2024 04:00:15 PM CEST)
No luck sadly looks like a upstream issue or at least that lib.
⯠cava
Here is the only âfixâ I can give then:
Finished making: cava-git r955.3f6e931-1 (Thu 11 Jul 2024 06:11:17 PM CEST)
I can drop this when cava
isnât broken
