Hi,
I have problem with brave-bin update. It is a signature problem.
The output of garuda-update
╰─λ garuda-update
:: Sincronizzazione dei database in corso...
garuda è aggiornato
core è aggiornato
extra è aggiornato
multilib è aggiornato
chaotic-aur è aggiornato
warning: reflector-simple: local (3.2-1) is newer than garuda (2.0-1)
resolving dependencies...
Packages (1) brave-bin-1:1.52.126-1
Total Download Size: 140.64 MiB
Total Installed Size: 324.31 MiB
Net Upgrade Size: 2.72 MiB
:: Proceed with installation? [Y/n] Y
:: Retrieving packages...
brave-bin-1:1.52.126-1-x86_64 140.6 MiB 1515 KiB/s 01:35 [--------------------------------------------------------------------] 100%
(1/1) checking keys in keyring [--------------------------------------------------------------------] 100%
(1/1) checking package integrity [--------------------------------------------------------------------] 100%
error: brave-bin: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/brave-bin-1:1.52.126-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n] y
error: failed to commit transaction (invalid or corrupted package (PGP signature))
my garuda-inxi
Kernel: 6.3.8-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=e1b87af6-67e0-4350-97cb-8bdfe430d209 rw rootflags=subvol=@
quiet
cryptdevice=UUID=735c2a29-e901-4fc7-893a-52a88bf43878:luks-735c2a29-e901-4fc7-893a-52a88bf43878
root=/dev/mapper/luks-735c2a29-e901-4fc7-893a-52a88bf43878 splash
resume=/dev/mapper/luks-23c04b79-4698-461f-ade3-f485919f86ca loglevel=3
Desktop: KDE Plasma v: 5.27.5 tk: Qt v: 5.15.10 wm: kwin_wayland dm: SDDM
Type: Laptop System: FUJITSU product: LIFEBOOK A544 v: N/A serial: <filter>
Chassis: type: 10 serial: <filter>
Mobo: FUJITSU model: FJNBB35 serial: <filter> UEFI: FUJITSU // Phoenix
v: Version 1.13 date: 11/18/2013
ID-1: BAT0 charge: 0.7 Wh (100.0%) condition: 0.7/4.5 Wh (15.6%) volts: 12.2
min: 10.8 model: PTL CP651527-01 type: Li-ion serial: <filter> status: full
cycles: 275
Info: model: Intel Core i7-4702MQ socket: rPGA988B (On Board) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x3C (60)
stepping: 3 microcode: 0x16
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 2198 high: 2200 min/max: 800/3200 base/boost: 2200/2200
scaling: driver: intel_cpufreq governor: performance volts: 0.7 V
ext-clock: 100 MHz cores: 1: 2195 2: 2200 3: 2200 4: 2195 5: 2200 6: 2200
7: 2200 8: 2196 bogomips: 35120
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Fujitsu
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: HDMI-A-1 off: eDP-1 empty: VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: Importek FJ Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:5 chip-ID: 10f1:1a58
class-ID: 0e02
Display: server: X.Org v: 23.1.2 with: Xwayland v: 23.1.2
alternate: fbdev,intel,vesa dri: crocus gpu: i915 display-ID: :1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-1 res: 1920x1080 hz: 60 dpi: 102
size: 480x270mm (18.9x10.63") diag: 551mm (21.68") modes: N/A
API: OpenGL v: 4.6 Mesa 23.1.2 renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) direct-render: Yes
vendor: Fujitsu driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Fujitsu . 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
API: ALSA v: k6.3.8-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.71 status: n/a (root, process) with:
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b1 class-ID: 0280
vendor: Fujitsu driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF-ID-2: virbr1 state: down mac: <filter>
IF-ID-3: virbr2 state: down mac: <filter>
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:7 chip-ID: 8087:07dc
address: <filter>
Local Storage: total: 931.51 GiB used: 121.76 GiB (13.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 QVO 1TB
family: based SSDs size: 931.51 GiB block-size: physical: 512 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 1B6Q temp: 37 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 186d 14h cycles: 1843
written: 10.79 TiB
ID-1: / raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
used: 121.76 GiB (13.2%) fs: btrfs block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: luks-735c2a29-e901-4fc7-893a-52a88bf43878
used: 694 KiB (0.3%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-4: /var/log raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 922.45 GiB size: 922.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.67 GiB used: 0 KiB (0.0%) priority: 100
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-23c04b79-4698-461f-ade3-f485919f86ca
System Temperatures: cpu: 71.0 C pch: 61.0 C mobo: N/A
Processes: 268 Uptime: 1m wakeups: 1 Memory: available: 7.67 GiB
used: 2.07 GiB (27.0%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 clang: 15.0.7 Packages: pm: pacman
pkgs: 1844 libs: 422 tools: pamac,paru Shell: garuda-inxi (sudo)
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.27
System install date: 2021-03-13
Last full system update: 2023-06-15
My work-around is to add brave-bin to Not updatable packages list
