This is also done now ![]()
Could gcc11 and gcc11-libs be added? There's a AUR library that uses it and it's a REAL pain to compile!
I can try building it for sure! GCC always was a behemoth to build, I remember it from Gentoo days ![]()
A post was merged into an existing topic: 'clinfo' terminated by signal SIGABRT
This is now available! ![]()
Just out of curiosity, long did it take? ![]()
Why does pamac-nosnap conflict with gnome-software, whereas pamac-aur doesn't?
Repository : chaotic-aur
Version : 10.5.1-1
Conflicts With : pamac pamac-all pamac-gtk pamac-cli pamac-common pamac-aur pamac-aur-git
pamac-flatpak pamac-flatpak-gnome gnome-software gnome-software-git
There are many packages in the conflict list that no longer even exist.
I suppose the conflict list is outdated.
Even the package itself is outdated.
You could replace it with pamac-all, that's up-to-date. Otherwise, there's no need for it, if it isn't for flatpaks, we have pamac-aur
Version : 11.0.1-2
Conflicts With : pamac pamac-tray-appindicator pamac-cli
|real|92m54.294s|
|user|478m37.903s|
|sys|118m47.747s|
Gotta ask the package maintainer.
We banned Snapd, so no pamac-all in Chaotic
I agree that this needs to be updated - notified the AUR maintainer and flagged it out of date… lets see.
2 hours to build, great! At least I won't have to spend those 2 hours on every build anymore.
Told you it was kind of a pain...
(how long did it take to build on 6-year-old laptops? 3 days? High suicide rate)
That is 2hrs of his own time + power so you can have a life how better can it get for you ? It does not matter that there are more important things to do like fix Garuda.
Server builds it automatically in the background
sorry to disturb you nico but I think you might need to look at this
:: installing virtualbox (7.0.10-1) breaks dependency 'virtualbox=7.0.8' required by virtualbox-ext-oracle
I think it's time to rebuild virtualbox-ext-oracle in chaotic-aur
╰─λ paru -Si virtualbox-ext-oracle
Version : 7.0.8-1
Description : Oracle VM VirtualBox Extension Pack
Architecture : any
URL : https://www.virtualbox.org/
Licenses : custom:PUEL
Groups : None
Provides : None
Depends On : virtualbox=7.0.8
Optional Deps : rdesktop: client to connect vm via RDP
Conflicts With : None
Replaces : None
Download Size : 2.45 MiB
Installed Size : 2.47 MiB
Packager : Nico Jensch <dr460nf1r3@chaotic.cx>
Build Date : Wednesday 19 April 2023 04:31:04 AM
Validated By : MD5 Sum SHA-256 Sum Signature
╭─siddharth@siddharth in ~ as 🧙 took 1s
97%
╰─λ paru -Si aur/virtualbox-ext-oracle
Repository : aur
Version : 7.0.10-1
AUR URL : https://aur.archlinux.org/packages/virtualbox-ext-oracle
Groups : None
Provides : None
Depends On : virtualbox=7.0.10
Make Deps : None
Check Deps : None
Maintainer : seblu
Votes : 1368
Popularity : 3.727477
First Submitted : Fri, 24 Dec 2010 16:48:19 +0000
Last Modified : Tue, 18 Jul 2023 21:30:01 +0000
Out Of Date : No
Noticed today that 'thunderbird-appmenu' in chaotic-aur is a really old version 102.10. There is a 'thunderbird-appmenu' in AUR that is at the new 115 version talked about here;
Can this be updated?
Something seems to have been wrong with it for a while now. Turns out that there's an extra SKIP that shouldn't exist, which seems to have been added in the last commit that replaced existing md5sums. I built it for now, but I'll mark the package out of date with that reason, and it'll rebuild as normal when the nightly routine runs. In the meantime: Finished making: thunderbird-appmenu 115.0.1-5 ![]()
Thank you! I just updated, WOW, what a nice new interface. I did need to import my old Thunderbird profile and I see that the old version 102 had the profile in .mozilla/thunderbird...and I think the new 115 has it back to .thunderbird, just fyi if people are migrating.
Hi all.
:: installing libcamera (0.1.0-1) breaks dependency 'libcamera-base.so=0.0.5-64' required by pipewire-common-git
:: installing libcamera (0.1.0-1) breaks dependency 'libcamera.so=0.0.5-64' required by pipewire-common-git
please trigger a rebuild for olive-git:
olive-editor: error while loading shared libraries: libavutil.so.57: cannot open shared object file: No such file or directory
Done, thanks!
Hewwo!
Could you do your magic for yt-dlp-git?
