I guess we can!
what's adding the bleeding edge currently? ![]()
A calculator?
Sorry, I canโt parse this. If you mean whatโs the latest GIT version, itโs 2023.07.06.r58.g6014355c6-1
mpv-full is failing (again), may need recompilation
mpv: error while loading shared libraries: libplacebo.so.296: cannot open shared object file: No such file or directory
btw mvp-full now relies on ffmpeg-git instead of ffmpeg, that's new? It replaced it on my system after the last update.
Oh sorry, I meant what feature the git version has, which is not available in the regular one ![]()
Completed ![]()
Oh! Nothing new, just updates for the usual ongoing changes on various hosting sites.
This is now also done ![]()
Thanks!
Hy, is possible to have Hypnotix-wayland on chaotic-AUR?
The X11 version is available (and "Garuda welcome" app install this version) but using wayland on KDE I found that video goes to suspend mode when hypnotix is playing streaming, so it doesn't use the inhibit in that case. Probably is a mpv issue in wayland (hypnotics use mpv as base), so I want see if hypnotix-wayland solve the issue or not.
Thanks
You can not, just to test, build it yourself?
paru hypnotix-wayland
1 aur/hypnotix-wayland 3.5-1 [+3 ~0.03]
An IPTV streaming application. (With Wayland support).
:: Zu installierende Pakete(z.B: 1 2 3, 1-3):
yes I think the same but I have never installed AUR package in my life (I use chaotic even when I try Arch or Endeavours because I'm addicted with it
or because I'm lazy)
I try installed it via PARU but at the end after some RETURN key pressed there is a END on terminal and I' don't know how to do to continue, I thhought it was installed but if I close the terminal window the package is not installed.
Press q at "end" , enter.
ahh q ..ok installed thanks
just if someone need feedback, wayland edition doesn't solve the issue so i revert back to X11 version of Hypnotix
libcamera/pipewire is resolved. thx, you are the greatest.
mpv-full borked again and needs rebuilt. Is there any way to prevent this from happening all the time?
mpv: error while loading shared libraries: libplacebo.so.300: cannot open shared object file: No such file or directory
can you please rebuild wlroots-git ?
Done!
Can you please add add Vinegar to the repo?
HI there.
There are two versions of GraalVM in Chaotic. Both are not maintained.
I recommend replacing them with the two currently supported versions:
Old:
https://aur.archlinux.org/packages/jdk8-graalvm-bin
https://aur.archlinux.org/packages/jdk16-graalvm-bin
New:
AUR (en) - jdk17-graalvm-bin (LTS)
AUR (en) - jdk20-graalvm-bin
Or just ditching them altogether. They are binary packages anyway, so downloading them from extra doesnt yield any benefit, or?
Mhm I had a look at the package lists and it seems we may in fact drop those.
Done!
Done as well.
