I think vkbasalt-cli needs to be recompiled. System default python is 3.11. I also have the python310 AUR package installed. For vkbasalt-cli, the one chaotic-aur installs into python3.10. Installing aur/vkbasalt-cli, installs into python3.11. Packages like bottles that rely on it moved to python3.11.
It does! Great catch, thank you!
There is YouTube Music app in AUR, I used it like few months ago and also it has adblocker built in!
python-inputs from chaotic-aur was also installing into python3.10.
Yep, that's known. The package is currently in need of packaging fix in order to update.
We're still having issues trying to build vkbasalt-cli
If one of you glorious humans get a chance could you add coolercontrol to the AUR?
I performed a garuda-update and this was shown. Should I be concerned, seems there is no chaotic-keyring or chaotic-mirrorlist anymore?
packages not in the AUR: ananicy-rules archlinux-appstream-data-pamac chaotic-keyring chaotic-mirrorlist
Edit to add: nevermind, I did a mirror-refresh and then it pulled in the missing pieces listed above.
python-dataclass-wizard hasn't been updated for python 3.11 yet, so there's a hold on this for now ![]()
This was a chaotic-aur package and its dependency is KDEâs Discover. Are we no longer using this package?
packages not in the AUR: archlinux-appstream-data-pamac
BTW, I did a mirror-refresh, but it is still missing.
A cleanup of packages no longer in AUR, as well as packages broken for quite some time happened as of late, this package is one of those we dropped due to no longer being present in AUR. I noticed pamac seems to contain the fix needed as a hook to make this package obsolete. Iâm very unsure how Discover fits into this tbh though ![]()
Further information on the whole process can be found here:
You could remove ananicy-rules from the dependency list of performance-tweaks.
could you add amulet-map-editor? It takes pretty long to build from my experience
Are there any plans to add input-remapper-git back into the Chaotic-AUR? I tried reinstalling it due to some technical issues but didn't find the target.
For now I'm using it from the AUR and it works well. If there's no plans to add it back in, maybe it should be removed from Garuda Gamer ![]()
Also, it seems that Joplin is missing from the Chaotic-AUR as well, unless I'm just typing the package name(s) wrong? (joplin-beta, joplin-appimage-beta, joplin-desktop, joplin)
yeah itâs just a wrong package name
ââsiddharth@siddharth in ~
ó°94%
â°âλ pacman -Ss joplin
chaotic-aur/joplin-beta-appimage 2.11.6-1
The latest beta AppImage of Joplin - a cross-platform note taking and to-do app
I donât know if this is a latest addition because of your request but here:
ó°94%
â°âλ pacman -Ss input-remapper
chaotic-aur/input-remapper-git 2.0.0.r10.g27d7b3e8-1
A tool to change and program the mapping of your input device buttons.
I like your distribution and I would like to the see this added to Chaotic-AUR:
- mediathekview-xdg: Access the Mediathek of many German TV stations (store data in XDG_DATA_HOME)
- youtube-to-mp3: YouTube to Mp3 converter\nDownloads audio from YouTube or Vimeo and saves it to mp3 or m4a format to listen to locally
The second one is the best one I know for this job
It would be nice if rtl8812au is also in the installation media or Chaotic-AUR to support my Zyxel Dual Band AC direct.
GPG keyring error on update. Tried garuda-update but was getting gpg keyring error so thought I would update the keyring....
EDIT: These is another thread
garuda-update remote keyring
gpg: /etc/pacman.d/gnupg/trustdb.gpg: trustdb created
gpg: no ultimately trusted keys found
gpg: starting migration from earlier GnuPG versions
gpg: porting secret keys from '/etc/pacman.d/gnupg/secring.gpg' to gpg-agent
gpg: migration succeeded
==> Generating pacman master key. This may take some time.
gpg: Generating pacman keyring master key...
gpg: directory '/etc/pacman.d/gnupg/openpgp-revocs.d' created
gpg: revocation certificate stored as '/etc/pacman.d/gnupg/openpgp-revocs.d/503176F1471F70B4FE1B76BC685C4611D36643EC.rev'
gpg: Done
==> Updating trust database...
gpg: marginals needed: 3 completes needed: 1 trust model: pgp
gpg: depth: 0 valid: 1 signed: 0 trust: 0-, 0q, 0n, 0m, 0f, 1u
==> Appending keys from archlinux.gpg...
==> Appending keys from chaotic.gpg...
==> Locally signing trusted keys in keyring...
-> Locally signed 11 keys.
==> Importing owner trust values...
gpg: setting ownertrust to 4
gpg: inserting ownertrust of 4
==> Disabling revoked keys in keyring...
-> Disabled 36 keys.
gpg: depth: 0 valid: 1 signed: 9 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 9 signed: 96 trust: 0-, 0q, 0n, 9m, 0f, 0u
gpg: depth: 2 valid: 73 signed: 27 trust: 73-, 0q, 0n, 0m, 0f, 0u
gpg: next trustdb check due at 2023-07-12
gpg: key A6234074498E9CEE: 4 duplicate signatures removed
gpg: key A6234074498E9CEE: 1 signature reordered
gpg: key A6234074498E9CEE: "Christian Hesse <eworm@archlinux.org>" 8 signatures cleaned
gpg: key FBA220DFC880C036: "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" not changed
gpg: Total number processed: 2
gpg: unchanged: 1
gpg: signatures cleaned: 8
-> Locally signed 2 keys.
gpg: depth: 0 valid: 1 signed: 10 trust: 0-, 0q, 0n, 0m, 0f, 1u
gpg: depth: 1 valid: 10 signed: 95 trust: 1-, 0q, 0n, 9m, 0f, 0u
gpg: depth: 2 valid: 72 signed: 27 trust: 72-, 0q, 0n, 0m, 0f, 0u
garuda 96.0 KiB 171 KiB/s 00:01 [------------------------------------] 100%
core 132.1 KiB 120 KiB/s 00:01 [------------------------------------] 100%
extra 8.3 MiB 369 KiB/s 00:23 [------------------------------------] 100%
community 45.0 B 121 B/s 00:00 [------------------------------------] 100%
multilib 140.9 KiB 124 KiB/s 00:01 [------------------------------------] 100%
chaotic-aur 2.5 MiB 4.02 MiB/s 00:01 [------------------------------------] 100%
warning: archlinux-keyring-20230504-1 is up to date -- reinstalling
warning: chaotic-keyring-20220803-1 is up to date -- reinstalling
resolving dependencies...
Package (2) Old Version New Version Net Change Download Size
core/archlinux-keyring 20230504-1 20230504-1 0.00 MiB 1.14 MiB
chaotic-aur/chaotic-keyring 20220803-1 20220803-1 0.00 MiB 0.03 MiB
Total Download Size: 1.16 MiB
Total Installed Size: 1.64 MiB
Net Upgrade Size: 0.00 MiB
:: Retrieving packages...
chaotic-keyring-20220803-1-any 26.9 KiB 93.2 KiB/s 00:00 [------------------------------------] 100%
archlinux-keyring-20230504-1-any 1164.5 KiB 181 KiB/s 00:06 [------------------------------------] 100%
Total (2/2) 1191.5 KiB 183 KiB/s 00:07 [------------------------------------] 100%
(2/2) checking keys in keyring [------------------------------------] 100%
(2/2) checking package integrity [------------------------------------] 100%
error: chaotic-keyring: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: File /var/cache/pacman/pkg/chaotic-keyring-20220803-1-any.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: failed to commit transaction (invalid or corrupted package (PGP signature))
update works without problem but
Warnung: chaotic-keyring-20220803-1 ist aktuell -- Reinstalliere
AbhĂ€ngigkeiten werden aufgelöst âŠ
Nach in Konflikt stehenden Paketen wird gesucht âŠ
Paket (2) Alte Version Neue Version Netto-VerĂ€nderung GröĂe des Downloads
core/archlinux-keyring 20230504-1 20230504-1 0,00 MiB 1,14 MiB
chaotic-aur/chaotic-keyring 20220803-1 20220803-1 0,00 MiB 0,03 MiB
GesamtgröĂe des Downloads: 1,16 MiB
GesamtgröĂe der installierten Pakete: 1,64 MiB
GröĂendifferenz der Aktualisierung: 0,00 MiB
:: Installation fortsetzen? [J/n]
:: Pakete werden empfangen âŠ
archlinux-keyring-20230504-1-any 1164,5 KiB 5,69 MiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
chaotic-keyring-20220803-1-any 26,9 KiB 59,6 KiB/s 00:00 [----------------------------------------------------------------------------------------] 100%
Gesamt (2/2) 1191,5 KiB 1158 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
(2/2) SchlĂŒssel im SchlĂŒsselbund werden geprĂŒft [----------------------------------------------------------------------------------------] 100%
(2/2) Paket-IntegritĂ€t wird ĂŒberprĂŒft [----------------------------------------------------------------------------------------] 100%
Fehler: chaotic-keyring: signature from "Nico Jensch (Chaotic-AUR) <dr460nf1r3@garudalinux.org>" is unknown trust
:: Datei /var/cache/pacman/pkg/chaotic-keyring-20220803-1-any.pkg.tar.zst ist beschĂ€digt (UngĂŒltiges oder beschĂ€digtes Paket (PGP-Signatur)).
Soll die Datei entfernt werden? [J/n]
Fehler: Der Vorgang konnte nicht durchgefĂŒhrt werden (UngĂŒltiges oder beschĂ€digtes Paket (PGP-Signatur))
Fehler sind aufgetreten, keine Pakete wurden aktualisiert.
