I just tried it again to make sure, if you exchange the amd-ucode for the git version after the installation with chroot, it boots normally for me.
Although I was having trouble with the main iso, off the website, I wonder if the random reboot during install problems I had might be related? I posted a report, but it might be in the wrong place⦠itās under KDE because Iām using the KDE version, but itās not a KDE problem. It is something to do with pacman. Oddly enough I am trying it out on my old laptop prior to putting on my Intel NUC⦠But as I see in the comments, itās getting tested on NUCs, so it might be smooth sailing if I just put it on the NUC from the beginning.
Can confirm garuda-sway-linux-zen-240319.iso fresh install on its own ssd would go to grub hit enter it would flash once an stay in grub hit it one more time black screen then it would disable the keyboard an shut off its backlight. then sit there. open source driver, amd 3700x cpu.
Device-1: NVIDIA GM204 [GeForce GTX 980] driver: nvidia v: 550.67
unloaded: modesetting,nouveau gpu: nvidia resolution: 3440x1440
API: EGL v: 1.5 drivers: nvidia,swrast,zink
platforms: gbm,wayland,x11,surfaceless,device
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.67
renderer: NVIDIA GeForce GTX 980/PCIe/SSE2
API: Vulkan v: 1.3.279 drivers: nvidia surfaces: xcb,xlib,wayland
I assume from up above, this is all known but just adding it just in case.
It would be more helpful to have your video card info. Do inxi -G in your terminal and post it here.
sorry about that was super late for me when i posted
If you are willing to test, I would be curious to see if installing amd-ucode-git resolves the issue for you as well. You would have to boot to the live environment and install it from a chroot.
I donāt think this bug is related to the video card at all.
This thread is for the new megarelease which are linked to in the first post of the thread.
The version you referred to from the website is the old version from October of last year.
Yes, installing amd-ucode-git allows you to boot into the system.
New ISO for testing (dr460nized only) the post-installation boot-up process on AMD devices:
It has microcode loading via GRUB disabled since Dracut already includes it. Double loading might cause our situation.
hi, booting the new iso works for me without any problems.
i canāt say it often enough, thank you all so much for all your work and support. ![]()
āābuccaneer@Garuda in ~
ā°āĪ» garuda-inxi
Kernel: 6.8.1-3-cachyos arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=c24fc102-bfe9-4625-9d99-b8affc54a8f7 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: Gigabyte product: X670 GAMING X AX v: -CF
Mobo: Gigabyte model: X670 GAMING X AX v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 09/12/2022
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
model-id: 0x61 (97) stepping: 2 microcode: 0xA601201
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1083 high: 4173 min/max: 400/5733 scaling:
4: 400 5: 400 6: 400 7: 3483 8: 400 9: 3622 10: 400 11: 400 12: 400
13: 400 14: 400 15: 400 16: 400 17: 400 18: 400 19: 400 20: 400 21: 4173
22: 3434 23: 400 24: 3692 bogomips: 225177
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 3840x1080 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-3-cachyos) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.2 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-3-cachyos status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 11:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp17s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0e8d:0616
Local Storage: total: 2.16 TiB used: 12.9 GiB (0.6%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 37.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 120.28 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: DL17 scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 12.9 GiB (0.7%)
used: 12.9 GiB (0.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 41.9 C mobo: 36.0 C gpu: amdgpu temp: 40.0 C
mem: 36.0 C
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 3.53 GiB (11.4%)
Processes: 480 Power: uptime: 7m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1784 libs: 539 tools: octopi,pacseek,paru
Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi default: fish
v: 3.7.0 running-in: konsole inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-25
Last full system update: 2024-03-25
āābuccaneer@Garuda in ~ took 1s
ā°āĪ»
Yes it boots fine on every PC, but we need tester for installing it on metal![]()
Wait
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=de_DE keytable=de
tz=Europe/Berlin misobasedir=garuda
root=miso:LABEL=GARUDA_DR460NIZED_SPIZAETUS quiet systemd.show_status=1
checksum=y driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Type: Laptop System: LENOVO product: 82MS v: Yoga Slim 7 Pro 14ACH5
serial: <superuser required> Chassis: type: 10 v: Yoga Slim 7 Pro 14ACH5
Mobo: LENOVO model: LNVNB161216 v: SDK0R32862WIN
serial: <superuser required> part-nu: LENOVO_MT_82MS_BU_idea_FM_Yoga Slim 7
Pro 14ACH5 uuid: <superuser required> UEFI: LENOVO v: GZCN34WW
date: 08/28/2023
ID-1: BAT0 charge: 32.6 Wh (56.5%) condition: 57.7/61.0 Wh (94.7%)
volts: 15.6 min: 15.4 model: Sunwoda L19D4PH3 type: Li-poly serial: <filter>
status: not charging cycles: 78
microcode: 0xA50000B
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 1029 high: 2395 min/max: 400/4680 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1915 2: 400 3: 400
4: 400 5: 400 6: 1889 7: 2118 8: 400 9: 2390 10: 400 11: 400 12: 400
13: 1772 14: 400 15: 400 16: 2395 bogomips: 105400
vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
link-max: gen: 4 speed: 16 GT/s ports: active: eDP-1 empty: DP-1,DP-2
bus-ID: 03:00.0 chip-ID: 1002:1638 class-ID: 0300 temp: 45.0 C
Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:3 chip-ID: 13d3:5419
Monitor-1: eDP-1 res: 1440x900 size: N/A modes: N/A
drv: radeonsi inactive: gbm
renoir LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:1638
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: AMD
Radeon Graphics (RADV RENOIR) driver: mesa radv v: 24.0.3-arch1.2
device-ID: 1002:1638 surfaces: xcb,xlib,wayland device: 1 type: cpu
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637
snd_sof_amd_rembrandt, snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 3
speed: 8 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.5
speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Device-1: Realtek RTL8852AE 802.11ax PCIe Wireless Network Adapter
vendor: Lenovo driver: rtw89_8852ae v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: 2000 bus-ID: 01:00.0 chip-ID: 10ec:8852 class-ID: 0280
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-4:2 chip-ID: 0bda:4852
Local Storage: total: 1012.46 GiB used: 0 KiB (0.0%)
model: MZVLB1T0HBLR-000L2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: 3L1QEXF7 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Intenso model: cMobile size: 58.59 GiB
block-size: physical: 512 B logical: 512 B type: USB rev: 3.1 spd: 5 Gb/s
lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter> fw-rev: 1100
scheme: MBR
ID-1: swap-1 type: zram size: 13.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 69.6 C mobo: N/A gpu: amdgpu temp: 45.0 C
Memory: total: 16 GiB note: est. available: 13.5 GiB used: 4.71 GiB (34.9%)
Processes: 301 Power: uptime: 52m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.36 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1289 libs: 374 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
Last full system update: 2024-03-25 ā»
den kernel habe ich erst nach dem 2 oder 3 mal booten installiert
edit: I only installed the kernel after booting 2 or 3 times
sorry forgot better in english
no not OC, the bogomips are normal with zen kernel as well, with cachy-bore or tkg-pds they are a little bit higher.
really you mean itās too warm
, itās actually normal, only when gaming the temp goes up to 70 degrees celsius or so thatās too warm for me now iām thinking about installing a water cooling system.
they normally get installed on the first boot welcome screen that has you update right after that it scans for nvidia drivers an asks to install
Installed & booted just fine. The only issues I see are post instillation during the first boot garuda assistant is skipping over the driver detection. it will show it for about 3 seconds then move on to the app install prompt. When going to garuda settings ā hardware config. It only shows āauto install open source driverā. So would require the user to install manually.
root=UUID=0eff8803-a8f5-4131-b025-0cebb93fb993 rw rootflags=subvol=@
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
UEFI: American Megatrends v: 4802 date: 06/15/2023
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
family: 0x17 (23) model-id: 0x71 (113) stepping: 0 microcode: 0x8701030
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 2411 high: 4347 min/max: 2200/4426 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2200 2: 3600
3: 2200 4: 2057 5: 4347 6: 2200 7: 2175 8: 2200 9: 2200 10: 2200 11: 2200
12: 2200 13: 2200 14: 2200 15: 2200 16: 2200 bogomips: 115209
Device-1: NVIDIA GM204 [GeForce GTX 980] vendor: Gigabyte driver: nouveau
v: kernel non-free: 545.xx+ status: current (as of 2024-02; EOL~2026-12-xx)
arch: Maxwell code: GMxxx process: TSMC 28nm built: 2014-2019 pcie: gen: 1
speed: 2.5 GT/s lanes: 8 link-max: gen: 3 speed: 8 GT/s lanes: 16 ports:
active: DP-3 empty: DP-1, DP-2, DVI-I-1, HDMI-A-1 bus-ID: 0a:00.0
chip-ID: 10de:13c0 class-ID: 0300 temp: 32.0 C
compositor: kwin_wayland driver: X: loaded: nouveau unloaded: modesetting
alternate: fbdev,nv,vesa dri: nouveau gpu: nouveau display-ID: 0
Monitor-1: DP-3 res: 3440x1440 size: N/A modes: N/A
API: EGL v: 1.5 hw: drv: nvidia nouveau platforms: device: 0 drv: nouveau
device: 1 drv: swrast gbm: drv: nouveau surfaceless: drv: nouveau wayland:
drv: nouveau x11: drv: nouveau
API: OpenGL v: 4.5 compat-v: 4.3 vendor: mesa v: 24.0.3-arch1.2 glx-v: 1.4
direct-render: yes renderer: NV124 device-ID: 10de:13c0 memory: 3.87 GiB
unified: no display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: cpu name: llvmpipe (LLVM
17.0.6 256 bits) driver: mesa llvmpipe v: 24.0.3-arch1.2 (LLVM 17.0.6)
Device-1: NVIDIA GM204 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 8
link-max: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 0a:00.1
chip-ID: 10de:0fbb class-ID: 0403
bus-ID: 0d:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Texas Instruments PCM2900C Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-3:2 chip-ID: 08bb:29c0 class-ID: 0300
speed: 2.5 GT/s lanes: 1 bus-ID: 05:00.0 chip-ID: 8086:08b1 class-ID: 0280
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 06:00.0
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:3 chip-ID: 8087:07dc
Local Storage: total: 6.53 TiB used: 4.28 GiB (0.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T2IA temp: 33.9 C
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
ID-3: /dev/nvme2n1 maj-min: 259:11 vendor: Western Digital
model: WD BLACK SN770 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 731100WD temp: 39.9 C scheme: GPT
ID-4: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
serial: <filter> fw-rev: 2.22 scheme: GPT
ID-5: /dev/sdb maj-min: 8:16 vendor: Western Digital
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-6: /dev/sdc maj-min: 8:32 vendor: Toshiba model: TransMemory
size: 29.08 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: PMAP scheme: MBR
ID-1: / raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
used: 4.28 GiB (3.8%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-4: /var/log raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-5: /var/tmp raw-size: 111.49 GiB size: 111.49 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.52 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 33.0 C mobo: 35.0 C gpu: nouveau temp: 32.0 C
Fan Speeds (rpm): N/A gpu: nouveau fan: 2023
Memory: total: 16 GiB available: 15.52 GiB used: 2.29 GiB (14.7%)
Processes: 373 Power: uptime: 1m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1249 libs: 372 tools: octopi,paru Compilers:
inxi: 3.3.33
Garuda (2.6.23-1):
the other small issue i saw was in the live iso when clicking on firedragon in the dock it said it could not be found but using it in the application launcher it worked just fine.
Nvidia proprietary drivers are installed by the setup assistant, the choice during live boot does not actually install the driverās in the installed system.
Thanks for the valuable feedback guys ![]()
This is supposed to be an extra prompt after the initial update as far as I know. I never had an NVIDIA device so no way to test that.
What does mhwd -l (not sure if it was -I or -l) tell?
The newest Dragonized ISO is working well on my system. The earlier Garuda Lite versions LTS & Zen both did not boot with AMD/APU.
You need to install the DKMS driver an rebuild the intrams if you want them āfor those with older gpus you need the 340/390/470 dkmsā
