I tried again with the Dr460nized-zen, this time I used the delete hard disk and the already mentioned error occurs at the first boot.
then tried it as you described, the error remains
==> Mounting (Garuda_Linux) [/dev/nvme0n1p2]
--> mount: [/mnt]
--> mount: [/mnt/boot/efi]
--> mount: [/mnt/home]
--> mount: [/mnt/root]
--> mount: [/mnt/srv]
--> mount: [/mnt/var/cache]
--> mount: [/mnt/var/log]
--> mount: [/mnt/var/tmp]
[root@garuda-dr460nized /]# dracut-rebuild
:: Building initramfs for linux-zen (6.8.1-zen1-1-zen)
:: Building fallback initramfs for linux-zen (6.8.1-zen1-1-zen)
[root@garuda-dr460nized /]# ls -la
total 20
drwxr-xr-x 1 root root 168 Mar 20 14:39 .
drwxr-xr-x 1 root root 168 Mar 20 14:39 ..
-rw-r--r-- 1 root root 7 Mar 19 12:10 .garuda-tools
drwxr-xr-x 1 root root 0 Mar 20 14:39 .snapshots
lrwxrwxrwx 1 root root 7 Jan 19 18:10 bin -> usr/bin
drwxr-xr-x 1 root root 204 Mar 20 14:44 boot
drwxr-xr-x 20 root root 4560 Mar 20 14:43 dev
drwxr-xr-x 1 root root 4108 Mar 20 14:39 etc
drwxr-xr-x 1 root root 30 Mar 20 14:39 home
lrwxrwxrwx 1 root root 7 Jan 19 18:10 lib -> usr/lib
lrwxrwxrwx 1 root root 7 Jan 19 18:10 lib64 -> usr/lib
drwxr-xr-x 1 root root 0 Jan 19 18:10 mnt
drwxr-xr-x 1 root root 0 Mar 20 14:39 opt
dr-xr-xr-x 539 root root 0 Mar 20 14:43 proc
drwxr-x--- 1 root root 178 Mar 20 14:39 root
drwxr-xr-x 3 root root 60 Mar 20 14:44 run
lrwxrwxrwx 1 root root 7 Jan 19 18:10 sbin -> usr/bin
drwxr-xr-x 1 root root 14 Mar 19 12:09 srv
dr-xr-xr-x 13 root root 0 Mar 20 14:42 sys
drwxrwxrwt 2 root root 40 Mar 20 14:43 tmp
drwxr-xr-x 1 root root 94 Mar 20 14:39 usr
drwxr-xr-x 1 root root 110 Mar 19 12:09 var
[root@garuda-dr460nized /]# ls -la /boot
total 80488
drwxr-xr-x 1 root root 204 Mar 20 14:44 .
-rw-r--r-- 1 root root 81920 Mar 13 12:34 amd-ucode.img
drwxr-xr-x 3 root root 4096 Jan 1 1970 efi
drwxr-xr-x 1 root root 84 Mar 20 14:39 grub
-rw------- 1 root root 49161345 Mar 20 14:44 initramfs-linux-zen-fallback.img
-rw------- 1 root root 19270067 Mar 20 14:44 initramfs-linux-zen.img
drwxr-xr-x 1 root root 22 Mar 19 12:09 memtest86+
-rw-r--r-- 1 root root 13898240 Mar 19 12:09 vmlinuz-linux-zen
I did it again and partitioned it manually
boot/efi 300MB marked as boot
boot 10024MB marked as boot
/ the rest marked as root
now it boots normally
ââbuccaneer@garuda in ~
â°âλ garuda-inxi
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8fd033cf-a6a1-4820-bb48-ec3e0740b2d5 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Desktop System: Gigabyte product: X670 GAMING X AX v: -CF
Mobo: Gigabyte model: X670 GAMING X AX v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F2
date: 09/12/2022
Info: model: AMD Ryzen 9 7900X bits: 64 type: MT MCP arch: Zen 4 gen: 5
model-id: 0x61 (97) stepping: 2 microcode: 0xA601201
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 12 MiB desc: 12x1024 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 1458 high: 3849 min/max: 400/5733 scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 400 2: 3310 3: 400
4: 400 5: 400 6: 400 7: 400 8: 3391 9: 400 10: 3377 11: 400 12: 3686
13: 3849 14: 3593 15: 3619 16: 400 17: 400 18: 400 19: 400 20: 400
21: 3769 22: 400 23: 400 24: 400 bogomips: 225176
vendor: XFX driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, Writeback-1
bus-ID: 03:00.0 chip-ID: 1002:73df class-ID: 0300
gpu: amdgpu display-ID: 0
Monitor-1: HDMI-A-1 res: 3840x1080 size: N/A modes: N/A
drv: radeonsi inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6750 XT (radeonsi
navi22 LLVM 17.0.6 DRM 3.57 6.8.1-zen1-1-zen) device-ID: 1002:73df
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: discrete-gpu name: AMD
Radeon RX 6750 XT (RADV NAVI22) driver: mesa radv v: 24.0.3-arch1.1
device-ID: 1002:73df surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
Device-2: AMD Family 17h/19h HD Audio vendor: Gigabyte
bus-ID: 17:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
bus-ID: 11:00.0 chip-ID: 14c3:0616 class-ID: 0280
IF: wlp17s0 state: down mac: <filter>
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 0e8d:0616
Local Storage: total: 2.16 TiB used: 166.73 GiB (7.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 36.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
ID-3: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SanDisk 3.2 Gen1
size: 120.28 GiB block-size: physical: 512 B logical: 512 B type: USB
fw-rev: DL17 scheme: GPT
ID-1: / raw-size: 976.56 GiB size: 976.56 GiB (100.00%) used: 4.2 GiB (0.4%)
ID-2: /boot raw-size: 1024 MiB size: 1022 MiB (99.80%)
used: 45.8 MiB (4.5%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%)
used: 288 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /home raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
used: 4.2 GiB (0.4%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-5: /var/log raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-6: /var/tmp raw-size: 976.56 GiB size: 976.56 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.08 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 48.1 C mobo: 34.0 C gpu: amdgpu temp: 40.0 C
mem: 36.0 C
Memory: total: 32 GiB note: est. available: 31.08 GiB used: 3.45 GiB (11.1%)
Processes: 420 Power: uptime: 17m states: freeze,mem,disk suspend: deep
Packages: pm: pacman pkgs: 1248 libs: 371 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2024-03-20
Last full system update: 2024-03-20
ââbuccaneer@garuda in ~ took 1s
â°âλ
