Hi I have a problem with my speakers.
my speaker have buzzing noise problem.
it is like this : when I using an app that make sound I dont have noise problem but when I don't use any app that make sounds then it start to making buzzing noise sound.
and when I have noise I go to sound settings and change the colume and noise gone for some seconds but after that again it is buzzing.( I say this one because maybe it will help you to know the problem better)
I should notice that I dont have this problem on windows 10 and 11 but at ubuntu and arcolinux I see this problem too like garuda linux.
`Kernel: 5.16.8-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0`
root=UUID=2adb3662-5c5c-40c0-8707-e5e5b172df3c rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.0 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: ASUSTeK model: TUF X470-PLUS GAMING v: Rev X.0x
serial: UEFI: American Megatrends v: 5861
date: 08/10/2021
Info: model: AMD Ryzen 7 2700X bits: 64 type: MT MCP arch: Zen+
L3: 16 MiB desc: 2x8 MiB
Speed (MHz): avg: 2355 high: 4212 min/max: 2200/3700 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 2466 2: 2891
3: 1780 4: 1776 5: 2029 6: 1995 7: 4212 8: 2092 9: 2043 10: 2844 11: 1719
12: 1719 13: 1872 14: 1960 15: 4191 16: 2102 bogomips: 118181
STIBP: disabled, RSB filling
Device-1: NVIDIA GP104 [GeForce GTX 1070 Ti] vendor: Micro-Star MSI
driver: nvidia v: 510.47.03 alternate: nouveau,nvidia_drm bus-ID: 09:00.0
chip-ID: 10de:1b82 class-ID: 0300
Display: x11 server: [X.Org](http://X.Org) 1.21.1.3 compositor: kwin_x11 driver:
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 1600x900 s-dpi: 90 s-size: 452x251mm (17.8x9.9")
s-diag: 517mm (20.4")
Monitor-1: HDMI-0 res: 1600x900 hz: 60 dpi: 92
size: 443x249mm (17.4x9.8") diag: 508mm (20")
OpenGL: renderer: NVIDIA GeForce GTX 1070 Ti/PCIe/SSE2
v: 4.6.0 NVIDIA 510.47.03 direct render: Yes
Device-1: NVIDIA GP104 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 09:00.1 chip-ID: 10de:10f0
v: kernel bus-ID: 0b:00.3 chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.16.8-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
vendor: ASUSTeK PRIME B450M-A driver: r8169 v: kernel port: f000
bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp3s0 state: down mac:
Device-2: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u
bus-ID: 1-13:3 chip-ID: 148f:7601 class-ID: 0000 serial:
IF: wlp1s0f0u13 state: up mac:
Local Storage: total: 2.05 TiB used: 918.4 GiB (43.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 EVO 250GB
type: SSD serial: rev: 4B6Q scheme: GPT
model: WD20EZRZ-00Z5HB0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 5400 serial:
rev: 0A80 scheme: GPT
ID-1: / raw-size: 40.64 GiB size: 40.64 GiB (100.00%)
used: 7.21 GiB (17.7%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
used: 576 KiB (0.1%) fs: vfat dev: /dev/sda6 maj-min: 8:6
ID-3: /home raw-size: 49.33 GiB size: 49.33 GiB (100.00%)
used: 147 MiB (0.3%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 40.64 GiB size: 40.64 GiB (100.00%)
ID-5: /var/tmp raw-size: 40.64 GiB size: 40.64 GiB (100.00%)
ID-1: swap-1 type: zram size: 31.32 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 42.5 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 383 Uptime: 1h 3m wakeups: 0 Memory: 31.32 GiB
used: 3.27 GiB (10.4%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 Packages: pacman: 1199 lib: 289 Shell: fish v: 3.3.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.4-2):
System install date: 2022-02-10
Last full system update: 2022-02-11
