Hello Garuda users.
I’ve got a headset with virtual 5.1 surround sound.
A Tronsmart Glary . When activate it in the audio settings with “digital surround 5.1 (IEC958/AC3)” the sound is just noise.
I found a similar topic which was closed, and the given solution did not help me.
As mentioned there, I added “options snd-hda-intel and power_save=0 power_save_controller=N” to the otherwise empty /etc/modprobe.d/local.conf .
I also tried “… snd_hda_intel and power_save…” as well as “… snd_usb_audio and power_save…” , without success.
The usual stereo mode of the headset works fine and.
On windows I also checked that 5.1 sound works on the headset. It does.
Thanks for any help or directions
Cell
# garuda-inxi
Kernel: 5.18.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=af9e0d6f-f9f5-4dff-9429-ccb173eea0f2 rw rootflags=subvol=@
loglevel=3 ibt=off
Type: Desktop Mobo: ASUSTeK model: ROG STRIX X570-F GAMING v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 2802
date: 10/21/2020
Info: model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201009
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3601 high: 3923 min/max: 2200/4650 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3596 2: 3591
3: 3593 4: 3593 5: 3591 6: 3371 7: 3610 8: 3584 9: 3586 10: 3591 11: 3923
12: 3592 bogomips: 88634
STIBP: always-on, RSB filling
Device-1: NVIDIA TU117 [GeForce GTX 1650] vendor: ZOTAC driver: nvidia
v: 470.129.06 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-05) arch: Turing pcie: gen: 2 speed: 5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 07:00.0
chip-ID: 10de:1f82 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: nvidia
Screen-1: 0 s-res: 1920x1080 s-dpi: 91 s-size: 535x301mm (21.06x11.85")
s-diag: 614mm (24.17")
Monitor-1: DP-0 pos: primary res: 1920x1080 dpi: 82
Monitor-2: HDMI-0 size-res: N/A modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2
v: 4.6.0 NVIDIA 470.129.06 direct render: Yes
Device-1: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 10de:10fa class-ID: 0403
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Barco Display Systems Tronsmart Glary type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4.2:5 chip-ID: 0600:8c16
Sound Server-1: ALSA v: k5.18.2-zen1-1-zen running: yes
Refusing to post the output of the required “garuda-inxi” on a help request will likely result in you not receiving any help from the Garuda team. A failure to provide your system specs may also result in your thread being closed without notice, (as without this information providing assistance is often next to impossible).
Before opening a new help request, please search the Arch and Garuda Wiki’s, and read any relevant sections related to your issue. Also, thoroughly search any error messages in the forum’s search engine and on the web. For in depth information on how to search for answers to Linux issues effectively read the tips on the Garuda Wiki:
