Hi I just installed Garuda and I noticed a buzz coming from my speakers plugged into the headphone jack. the sound that they make when you touch the jack. I had this same problem in Pop os but fixed it by adding options snd-hda-intel and power_save=0 power_save_controller=N to /etc/modprobe.d/alsa-base.conf I noticed that garuda has modprobe.d but its missing the alsa-base.conf file. Is there any other way to fix this?
Welcome Nefarious,
So we can help, please ensure to post your:
inxi -Fxz
BTW, we have changed the template to
Ah ah ah good one!
Has it been announced somewhere? I may have missed it!
Good on ya, easier to remember than the parameters for noob like me
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=8141bf77-a4ed-4386-ac72-cc09b3a7990b rw rootflags=subvol=@
Type: Laptop System: Dell product: Latitude E5540 v: 01
Mobo: Dell model: 077XV9 v: A00 serial: <superuser required> BIOS: Dell
v: A06 date: 05/01/2014
ID-1: BAT0 charge: 38.1 Wh (100.0%) condition: 38.1/66.6 Wh (57.2%)
volts: 12.9 min: 11.1 model: Sanyo DELL M7T5F48 type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i5-4210U bits: 64 type: MT MCP arch: Haswell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2395 high: 2397 min/max: 800/2700 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2395 2: 2395 3: 2395
4: 2397 bogomips: 19155
Type: l1tf
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Dell driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0a16 class-ID: 0300
Device-2: Microdia Integrated Webcam type: USB driver: uvcvideo
bus-ID: 1-1.6:3 chip-ID: 0c45:64d0 class-ID: 0e02
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
s-diag: 414mm (16.3")
Monitor-1: eDP1 res: 1366x768 hz: 60 dpi: 102 size: 340x190mm (13.4x7.5")
diag: 389mm (15.3")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4400 (HSW GT2)
v: 4.5 Mesa 21.3.4 compat-v: 3.0 direct render: Yes
Device-1: Intel Haswell-ULT HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Dell driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-2: PulseAudio v: 15.0 running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
port: f080 bus-ID: 00:19.0 chip-ID: 8086:155a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel bus-ID: 02:00.0
chip-ID: 8086:08b1 class-ID: 0280
bus-ID: 1-1.8.2:5 chip-ID: 8087:07dc class-ID: e001
v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A
class-ID: 0104
Local Storage: total: 931.51 GiB used: 21.56 GiB (2.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM024 HN-M101MBB
speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: 0001
scheme: MBR
used: 21.56 GiB (2.3%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-1: swap-1 type: zram size: 3.74 GiB used: 329.2 MiB (8.6%)
System Temperatures: cpu: 46.0 C mobo: 36.0 C sodimm: SODIMM C
Fan Speeds (RPM): cpu: 3173
Processes: 224 Uptime: 40m wakeups: 2 Memory: 3.74 GiB
used: 2.59 GiB (69.3%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1715 lib: 511 Shell: fish
Garuda:
System install date: 2022-01-26
Last full system update: 2022-01-27
EFI variables are not supported on this system.
Using TLP: No
also sorry for not adding this in the beginning but there is also no sound like when I play a video the buzz goes away but there is no sound from the video
I am not an expert, but Garuda changed to PipeWire
You are running alsa and pipewire.
yeah I kinda changed it in the assistant to alsa to see if i could remove the noise but then i saw there was no alsa-base.conf file so i think I messed up somewhere i will reinstall if i messed something up because i have no sound now but then I still need to somehow fix the noise lol does pipewire have a .conf file?
If it is the same hardware as you had on Pop_OS, I would try the same fix. Don't worry about the missing file, you should be able to use any file ending with .conf in /etc/modprobe.d to specify sound card changes you need. You can just make a file called local.conf, add your options snd_hda_intel power_save=0 or whatever you want to try, and see if that's a fix.
More here: Advanced Linux Sound Architecture - ArchWiki
Sounds good but how can i make a file in this folder? It wont allow me to run dolpun as root
sudo micro /path/to/file/your.config
So the path would then be /etc/modprobe.d/local.conf? Or am l missing something?
Yes, exactly. Go for it!
it is FIXED thanks you guys are awesome. Also I would like to add that this fix on pop_os messed with the mic somehow and when using it people on the recieving end will have a sound like a train driving over the mic! Another thing I would like to ask without opening another issue if thats okay? What is the default software store? because octopi is always saying that the pacman database is missing.
That’s what currently is the “default” software store recommendation on new-ish installs. That problem should be opened up in a new thread if you can’t find a solution through a forum search.
alright thanks!
Also don't forget to mark @BluishHumility 's post as the solution here
Done.
Use
garuda-update
in terminal.
